Author Topic: STM32 MCUs interfacing with LCD screens  (Read 5252 times)
Offline Nominal Animal
Re: STM32 MCUs interfacing with LCD screens
« Reply #25 on: February 23, 2026, 10:18:23 am »
A question: why are some of these screens called 16-bit, 24-bit?
It refers to the number of colors the RGB/LVDS/MIPI DSI display can reproduce, or to the 8080/68k data bus width.  So, it depends on the interface.
Most often, 16-bit color uses RGB565, which means you have 2⁵ = 32 possible red intensities, 2⁶ = 64 possible green intensities, and 2⁵ = 32 possible blue intensities.  Human eye is slightly more sensitive to green than it is to blue or red, which is why it makes sense to use the extra bit for green.
Most common is 18-bit color, RGB666, where red, green, and blue all have 64 possible intensities.  64·64·64 = 2¹⁸ = 262,144.
24-bit color is RGB888, or a full byte per red, green, and blue. 2⁸ = 256.
If your image source has fewer bits per color than your display, you can repeat the most significant bits to the "unused" bits.
For example, if you have just 9 bits of color out from your MCU, for 512 colors (RGB333), but the display has 16 bits:
    R2 R1 R0 → R2 R1 R0 R2 R1
    G2 G1 G0 → G2 G1 G0 G2 G1 G0
    B2 B1 B0 → B2 B1 B0 B2 B1
This means you connect the MCU most significant red bit to display red bits 1 and 4, middle bit to display bits 0 and 3, and least significant red bit to display bit 2.  No resistors or such are needed, just direct wires, because the RGB bus signals are 3.3V CMOS (or 5V TTL) logic.
Some datasheets tell you to pull any unused least significant color bits to ground, but that can actually reduce your maximum intensity.  With the above example, maximum green component would be 111000₂ = 56 instead of 111111₂ = 63, for 56/63 ≃ 89% intensity, or 11% drop in maximum green intensity.
The displays with built-in framebuffers (ILI9341, ST7789, etc.) typically use a 18-bit framebuffer, and do that bit copying automatically when writing framebuffer data, from the configured format, using the above bit replication scheme.  This means that they can support different input pixel data width, even two or three data words per pixel, compared to the actual display.  With RGB/TTL, the input data width is the number of colors the display can display.  With LVDS/MIPI DSI, the data rate is higher than the output pixel rate, so they again can support different number of color bits per input pixel than the display itself can reproduce.
If you wonder about the "DITHER" pin on some displays, that is a mechanism that attempts to increase the number of intensities the display can reproduce by changing (dithering) the intensity by one step in successive frames.  I don't like it myself, but some do.
So how will you go about figuring out what the pins/connections are on that screen? As a noob all I can see is a ribbon with no idea where to start.
The datasheet.
BuyDisplay and some vendors do provide the datasheet openly.  For example, take a look at ER-TFT101B4-1, and the linked datasheet.  You can find the pinout on pages 9 and 10.  On page 11, section 4.3 Electrical Characteristics, you can find the expected voltages: VCC = 3.3V±0.3V, VGH = 18.0V±0.4V, VGL = -6V±0.4V, VCOM = 4.2V±0.4V, and AVDD = 9.6V±0.2V.  The next section, 4.4 Backlight Characteristics, tells you that the backlight (separate cable) is best run at max. 180mA – 200mA constant current, at which the forward voltage is around 9 volts; very suitable for use with my favourite backlight boost driver (from 2.7V - 5.5V supply), TI TPS92360.
Sometimes the pinout you get at e.g. this AliExpress 10.1" 1024×600 display when you expand the product description:
(click to embiggen)
can suffice.  Then, the video timings you need to use for the display are usually the standard Coordinated Video Timings, Reduced Blanking (CVT-R); hopefully per CEA-861-I.  There are online calculators for this.  Or, you can test if the ones in similar displays' datasheets work.
Without a datasheet or pinout, I would not bother.  Yes, there are lots of very nice cheap displays at AliExpress without datasheets, especially as replacements for car displays and tablets and even handheld consoles, but it is a LOT of work to reverse-engineer the pinout, and it usually involves the destructive deconstruction of at least one unit, likely more during testing.
Offline John Celo
  • Country: lt
« Reply #26 on: February 23, 2026, 06:21:57 pm »
I have had no issues driving SPI displays @ 320x240 transferring 16bpp at 50fps (maybe even at 60fps, but don't quote me on that). At this resolution it's most commonly either 2.4" or 2.8".
3.5" and 4.0" SPI are 320x480 (so that's twice as many pixels), and I dont have any on hand so I can't test, but 24/30fps probably should work.
What are you making? Is this a commercial endeavour? Is this for a one off unit? How price sensitive are you? Do you primarily care about size or resolution or both? etc
It's really hard to beat the commonly used 2.4"/2.8"/3.5"/4.0" SPI displays both in price, sourceability and implementation complexity. (those also often have 8080 8bit/16bit interface, but i haven't tried using that interface myself yet) These are very cheap, very easy to source and (especially in case of SPI) very easy to implement.
Going above this seems to have a rather notable bump in price and implementation complexity (stm32 h7 series mcus, etc)
« Last Edit: February 23, 2026, 06:25:06 pm by John Celo »
Offline bson
« Reply #27 on: February 24, 2026, 02:29:31 am »
8080 (RD/WR) or 6800 (E/RW) and then use the FMC controller.  Configure as SRAM (or PSRAM, oddly), 8 or 16 bit bus.  I've used this with an SSD1963 display.  It's usually BANK1 or BANK2 (0x60000000 or 0x68000000).  Pick an unused address bit for the CMD signal.  Works fine using the stock F4x and H7x DMA1 & DMA2.  Presumably also F7x and H4x.  The FMC controller is nearly identical (H adds an FMCEN enable bit), as is the DMA stream-based controller.  The H DMAMUX1/2 is new but a huge simplification since now any peripheral generating DMA requests can be used with any stream.  No more sparse interconnect matrix.
« Last Edit: February 24, 2026, 02:32:21 am by bson »
