Hi
I am loading and working with sample sources that come in the STM32Cubeide for the STM32H747.
The problem I see is that all these sources are not created with Cube, so if I want to modify anything in the configuration, for example the clock instead of with an external oscillator that is with crystal, add a serial port, interrupts, DMA, etc, I have to do it by modifying the sources manually.
Is there a way to make changes using Cube on a project that was not created with Cube?
It surprises me, because I work with the NXP Kinetis MK66 and i.MX RT and always in any project you can use the config tools from MCUXpresso to configure anything. Things like setting the GPIOs, assigning interrupts to them, setting the clock, a serial port, everything can always be done in graphical mode without the need to manually create source code.
How is it that in the STM32 if you don't create a Cube project, nothing can be configured graphically? My question is if somehow I can reverse that situation, and make a project not created with Cube become a Cube project.
Regards
