Author Topic: STM32 TFT LCD library  (Read 18373 times)
Offline DavidAlfa
Re: STM32 TFT LCD library
« Reply #25 on: March 15, 2021, 04:10:36 pm »
how to see disassembly in CubeIDE?
GPIOB->ODR = ( d ) ; GPIOA->BSRR = (0x00000002)  ;GPIOA->BSRR = (0x00020000 ) ;little faster
Windows...show view..disassembly.
You need debug build.
 I don't understand your code...
Put data in GPIOB.
Set GPIOA1
Reset GPIOA1
The full GPIOB is not available in the blue pill board.
Also you can't just put the value into ODR, since that way you overwrite the whole port, 16-bit wide. You need a mask.
Unless you don't care about the rest of the pins.
« Last Edit: March 15, 2021, 04:18:08 pm by DavidAlfa »
Offline strawberryTopic starter
  • Country: lv
« Reply #26 on: March 15, 2021, 04:54:05 pm »
16bit wide data to 16bit GPIOB0..15, GPIOA1 to toggle data clock
Nucleo64
Offline DavidAlfa
« Reply #27 on: March 15, 2021, 05:55:17 pm »
Oh, nice in that case. Should be much, much faster.
Ensure the clock pulse is long enough.
 I was doing it for the 103 blue pill :-+
