Author Topic: STM32F0 Failed to read memory  (Read 3275 times)
Offline DubbieTopic starter
« on: January 23, 2018, 01:03:26 am »
I just assembled a board with a stm32F0 chip.
I am connecting to it with st-link utility and a st-linkV2 via SWD
It connects fine, but if I try to read past 0x8007FF0 I get an error:  Failed to read memory @08008000!
Trying to write a bin to it fails as well.
Does this mean the chip is damaged or is there something I am overlooking?
I tried erasing the memory, but that didn't make any difference.
Thanks,
R
Offline llkiwi2006
Re: STM32F0 Failed to read memory
« Reply #1 on: January 23, 2018, 01:56:10 am »
0x8000 is 32k of flash. What chip do you have? Are you sure it has more than 32k of flash?
« Reply #2 on: January 23, 2018, 02:17:22 am »
Argh! Of course you are right. It only has 32K.   :-[
Why does STLink Utility try to read past 32K if I try to save the memory?
[edit] I am stupid. I never noticed the size field before. If I put 0x8000 in there, it all works properly.
Thanks for the help.
« Last Edit: January 23, 2018, 02:21:43 am by Dubbie »
