Hi All,
I have a new PCB I've put together with an STM32F030F4P6.
I've attached the Schematic drawing below for reference.
I've checked over the board extensively to confirm all is correct.
Normally, to program an STM32F030, like one of the blue pills, all I have to do is attach the 3v3, GND & SCLK / SIO pins.
For this board I've made, I have to also connect Reset pin, & attach BOOT0 to 3v3 to get a connection.
I suspect it's due to the config internally of the unit, however I have used STM32Cube to set up the ports as Debug Serial Wire, this hasn't made a difference.
How can I configure this to allow me to work easily to program the unit without having to mess around with bringing the BOOT pin high and low, (and preferably no Reset line needed)
Thanks!
