Author Topic: [solved] stm32f103 : Unexpected pause in code execution every 1ms  (Read 2226 times)
Offline JaunedeauTopic starter
  I have a bluepill with an stm32f103. The documentation says it is predictible, but it still has a prefetch queue to avoid waitstates, so I wanted to experiment with this. I just want to play with counting cycles*. But the code stops executing for 600-1000ns every (apparently exactly) 1ms.
  I run the following code :
  asm("asm:");
  asm(" mov r1, #0x00000001");
  asm(" ldr r2, =0x40010800");
  asm(".align 4");
  asm("loop:");
  asm("  str r1, [r2, #20]");
  asm("  str r1, [r2, #16]");
  asm("  b loop");
    That should just toggle a pin on and off four time, then loop.
      Here is what I see on the oscilloscope :
  The pause seems to be of repetable length, but it's about half long if I compile in release instead of debug.
  I have not made reproductible tests yet, but it seem to appear at random place in my loop (you see on the picture that after the long pause, I don't always have the same number of 0 or 1). Anyway it constantly repeat 1ms before the trigerring one.
  Also depending on what I write before the loop, it seems stall during either a 1 or a 0 on the output pin. I can flash several times with the same firmware and it will apparently always be the same, but if I change the code before the loop it might change (even though I aligned the code before)
  I have a very basic CubeMX new project, with :
  • PA0 to PA7 and PC13 set to output
  • RCC_MCO on on PA8 (clock output)
  • SWDIO and SWDCLOCK on PA13 and 14
  • 8MHz crystal with X9 multiplier to reach nominal 78MHz
  All I can see activated in CubeMX is :
  • Serial Wire debug
  • High Speed Clock (HSE) set to Crystal/Ceramic oscillator
[li]NVIC only has [/li][/list]
enabled
    on things I can't disable[/li]
think I let everything else disabled (no watchdog timer).
I use a cheap STLinkV2 clone for programming.
Source code attached.
Any idea what is happening ?
Thank you,
J.
* : Just for fun, don't judge me. I can count cycles on 6502 where you often need it, I just wanted to experiment with next difficulty level.
« Last Edit: May 13, 2023, 09:43:07 am by Jaunedeau »
Offline jnk0le
Re: stm32f103 : Unexpected pause in code execution every 1ms
« Reply #1 on: May 13, 2023, 08:11:58 am »
Most likely, it's a systick interrupt.
Offline AndyC_772
« Reply #2 on: May 13, 2023, 08:16:05 am »
SysTick interrupt, probably. Can you turn that off and see what happens?
https://www.st.com/resource/en/programming_manual/pm0056-stm32f10xxx20xxx21xxxl1xxxx-cortexm3-programming-manual-stmicroelectronics.pdf
Page 151 - make sure TICKINT = 0
« Reply #3 on: May 13, 2023, 08:44:50 am »
Yes, that was my probleme, thanks !
  asm(" CPSID if"); sovled my problem :)
« Last Edit: May 13, 2023, 09:44:12 am by Jaunedeau »
Offline DavidAlfa
Re: [solved] stm32f103 : Unexpected pause in code execution every 1ms
« Reply #4 on: May 13, 2023, 10:26:59 am »
Don't disable systick when using HAL, lots of functions rely on it for timeout management.
You'll get the code stuck in lots of places.
Offline Doctorandus_P
« Reply #5 on: May 19, 2023, 05:17:44 pm »
Indeed, temporarily disabling the systick timer is a nice diagnostics tool, but you should not do it lightly.
See it as part of the learning curve, and learn to write your programs in a robust way, so they can tolerate timing variations caused by ISR's.
