From the STM document: RM0008 Rev 20 page 1085/1134
MCU device ID code
The STM32F10xxx MCUs integrate an MCU ID code. This ID identifies the ST MCU part-
number and the die revision. It is part of the DBG_MCU component and is mapped on the
external PPB bus (see Section 31.16). This code is accessible using the JTAG debug port
(four to five pins) or the SW debug port (two pins) or by the user software. It is even
accessible while the MCU is under system reset.
I note the above doc says "or by the user software" do they mean code executed within the Flash of the MCU itself or only externally via SWD or JTAG ?
Comments appreciated from those with
first hand experience with the STM32F1xx DBG_IDCODE register
This is what I get when trying to read the DBG registers. I also read no data from peripherals which are not enabled, but the DBG peripheral doesn't seem to have a clock enable.
DBG.
DBG_IDCODE $00000000
3|3|2|2|2|2|2|2|2|2|2|2|1|1|1|1|1|1|1|1|1|1|
1|0|9|8|7|6|5|4|3|2|1|0|9|8|7|6|5|4|3|2|1|0|9|8|7|6|5|4|3|2|1|0
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
DBG_CR $00000000
