Author Topic: STM32G474RE HAL_COMP_TriggerCallback broken  (Read 2174 times)
Offline HaedenTopic starter
« on: April 07, 2024, 01:29:38 am »
I am trying to use a comparator on my STM32G474RE nucleo board and the external output gives the expected output when measured with an oscilloscope, but using the HAL_COMP_TriggerCallback function is just constantly called for no discernible reason, even if nothing is happening at the external COMP output.
I genuinely have no idea why HAL_COMP_TriggerCallback just gets repeatedly called at about 370kHz for no reason. This happens no matter what is going on at the COMP inputs. If I let the MCU sit and run for about 20 minutes, it stops being called randomly, but still does not get called when it should.
main.c and comp.c shown below:
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * Copyright (c) 2024 STMicroelectronics.
  * All rights reserved.
  * This software is licensed under terms that can be found in the LICENSE file
  * in the root directory of this software component.
  * If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "comp.h"
#include "usart.h"
#include "tim.h"
#include "gpio.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin) {
if (GPIO_Pin == B1_Pin) {
//print("Test");
    TIM1->ARR = TIM1->ARR - 2;
    TIM1->CCR1 = TIM1->CCR1 - 1;
HAL_GPIO_TogglePin(GPIOA, LD2_Pin);
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_LPUART1_UART_Init();
  MX_TIM8_Init();
  MX_COMP4_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  HAL_COMP_Start(&hcomp4);
  // MIN FREQ: 150 kHz = ARR 1133
  // MAX FREQ: 400 kHz = ARR 425
  // START FREQ: 200 kHz = ARR 850
  TIM8->ARR = 680;
  TIM8->CCR1 = 680/2;
  HAL_TIM_PWM_Start(&htim8, TIM_CHANNEL_1);
  HAL_TIMEx_PWMN_Start(&htim8, TIM_CHANNEL_1);
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1_BOOST);
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV4;
  RCC_OscInitStruct.PLL.PLLN = 85;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
  RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
    Error_Handler();
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
  * @file    comp.c
  * @brief   This file provides code for the configuration
  *          of the COMP instances.
  * @attention
#include "comp.h"
COMP_HandleTypeDef hcomp4;
/* COMP4 init function */
void MX_COMP4_Init(void)
  /* USER CODE BEGIN COMP4_Init 0 */
  /* USER CODE END COMP4_Init 0 */
  /* USER CODE BEGIN COMP4_Init 1 */
  /* USER CODE END COMP4_Init 1 */
  hcomp4.Instance = COMP4;
  hcomp4.Init.InputPlus = COMP_INPUT_PLUS_IO1;
  hcomp4.Init.InputMinus = COMP_INPUT_MINUS_IO2;
  hcomp4.Init.OutputPol = COMP_OUTPUTPOL_NONINVERTED;
  hcomp4.Init.Hysteresis = COMP_HYSTERESIS_NONE;
  hcomp4.Init.BlankingSrce = COMP_BLANKINGSRC_NONE;
  hcomp4.Init.TriggerMode = COMP_TRIGGERMODE_IT_RISING_FALLING;
  if (HAL_COMP_Init(&hcomp4) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN COMP4_Init 2 */
  /* USER CODE END COMP4_Init 2 */
void HAL_COMP_MspInit(COMP_HandleTypeDef* compHandle)
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  if(compHandle->Instance==COMP4)
  /* USER CODE BEGIN COMP4_MspInit 0 */
  /* USER CODE END COMP4_MspInit 0 */
    __HAL_RCC_GPIOB_CLK_ENABLE();
    /**COMP4 GPIO Configuration
    PB0     ------> COMP4_INP
    PB1     ------> COMP4_OUT
    PB2     ------> COMP4_INM
    GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_2;
    GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = GPIO_PIN_1;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
    GPIO_InitStruct.Alternate = GPIO_AF8_COMP4;
    /* COMP4 interrupt Init */
    HAL_NVIC_SetPriority(COMP4_5_6_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(COMP4_5_6_IRQn);
  /* USER CODE BEGIN COMP4_MspInit 1 */
  /* USER CODE END COMP4_MspInit 1 */
void HAL_COMP_MspDeInit(COMP_HandleTypeDef* compHandle)
  /* USER CODE BEGIN COMP4_MspDeInit 0 */
  /* USER CODE END COMP4_MspDeInit 0 */
    HAL_GPIO_DeInit(GPIOB, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2);
    /* COMP4 interrupt Deinit */
    HAL_NVIC_DisableIRQ(COMP4_5_6_IRQn);
  /* USER CODE BEGIN COMP4_MspDeInit 1 */
  /* USER CODE END COMP4_MspDeInit 1 */
Offline DavidAlfa
Re: STM32G474RE HAL_COMP_TriggerCallback broken
« Reply #1 on: April 07, 2024, 04:12:20 am »
And where's HAL_COMP_TriggerCallback in that code?
Are you enabling any pull resistor to avoid noise?
Where are you resetting the flag?
You should add this to the callback function:
__HAL_COMP_COMP4_EXTI_CLEAR_FLAG();
But this seems already done by the IRQ code:
https://github.com/STMicroelectronics/stm32g4xx_hal_driver/blob/master/Src/stm32g4xx_hal_comp.c#L872-L924
« Last Edit: April 07, 2024, 04:53:36 am by DavidAlfa »
« Reply #2 on: April 07, 2024, 04:09:44 pm »
HAL_COMP_TriggerCallback is in main. I accidentally deleted it from the code block while I was deleting some commented out code.
void HAL_COMP_TriggerCallback(COMP_HandleTypeDef* hcomp) {
  if (hcomp->Instance == COMP4) {
    HAL_GPIO_TogglePin(COMP1_Callback_GPIO_Port, COMP1_Callback_Pin);
(Ignore the fact that some variables are named COMP1_xxx.)
I tried placing a pull-down resistor on COMP INP but HAL_COMP_TriggerCallback continues to be triggered.
The flag is reset in the auto generated (By STM32CubeMX) HAL_COMP_IRQHandler function, which then calls HAL_COMP_TriggerCallback.
__HAL_COMP_COMP4_EXTI_CLEAR_FLAG(); is unessecary as LL_EXTI_ClearFlag_0_31(exti_line); is called in HAL_COMP_IRQHandler.
I tried adding it anyway, but it does not solve the issue of HAL_COMP_TriggerCallback being randomly called.
