I'm trying to use USART + RTS only + DMA(non circular, peripheral to memory, DMA1 Stram0) on STM32H755ZIT6's M4 processor. I and D caches are enabled on M7. My code is working on M7 but it does not works on M4.
// u8* dma_rx_buffer_ = (u8*)((u32)0x24000000);
// u8* dma_rx_buffer_ = (u8*)((u32)0x38000000);
u8* dma_rx_buffer_ = (u8*)((u32)0x30000000);
int main(void)
//SCB_InvalidateDCache_by_Addr((u32*)dma_rx_buffer_, 14);
error = HAL_UART_Receive_DMA(&usart2_dma_, dma_rx_buffer_, 14);
as you can see I'm setting RAM_D2's address to the dma_rx_buffer_, but I can't use SCB_InvalidateDCache_by_Addr on M4.
This is M7's Flash.ld
MEMORY {
RAM_D1 (xrw) : ORIGIN = 0x24000000, LENGTH = 512K
FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 1024K
DTCMRAM (xrw) : ORIGIN = 0x20000000, LENGTH = 128K
RAM_D2 (xrw) : ORIGIN = 0x30000000, LENGTH = 288K
RAM_D3 (xrw) : ORIGIN = 0x38000000, LENGTH = 64K
ITCMRAM (xrw) : ORIGIN = 0x00000000, LENGTH = 64K
this is M4's Flash.ld
MEMORY
FLASH (rx) : ORIGIN = 0x08100000, LENGTH = 1024K
RAM (xrw) : ORIGIN = 0x10000000, LENGTH = 288K
//RAM_D2 (xrw) : ORIGIN = 0x30000000, LENGTH = 288K
//RAM_D3 (xrw) : ORIGIN = 0x38000000, LENGTH = 64K
I also tried to add RAM_D1 and RAM_D2 inside M4's Flash.ld file and use it like this `attribute ((section(".RAM_D2"))) attribute ((aligned (32))) u8* dma_rx_buffer_;
but no result.
I also read DMA is not working on STM32H7 devices, but can't find solution.
P.S all configurations, including DMA are correct .
Also when I'm setting different addresses for dma_rx_buffer_ then I'm getting different data.
Do I need to add MPU region for CortexM4?
Update: Configured MPU region accrding DRAM addresses, but no result, with RAM_D1, RAM_D2 or RAM_D3.
/* Disable fault exceptions */
SCB->SHCSR &= ~SCB_SHCSR_MEMFAULTENA_Msk;
/* Disable the MPU and clear the control register*/
MPU->CTRL = 0;
MPU->CTRL = MPU_PRIVILEGED_DEFAULT | MPU_CTRL_ENABLE_Msk;
SCB->SHCSR |= SCB_SHCSR_MEMFAULTENA_Msk;
__DSB();
__ISB();
MPU->RNR = MPU_REGION_NUMBER8;
//MPU->RBAR = 0x24000000;
//MPU->RBAR = 0x38000000;
MPU->RBAR = 0x30000000;
MPU->RASR = ((uint32_t)MPU_INSTRUCTION_ACCESS_ENABLE << MPU_RASR_XN_Pos) |
((uint32_t)MPU_REGION_FULL_ACCESS << MPU_RASR_AP_Pos) |
((uint32_t)MPU_TEX_LEVEL0 << MPU_RASR_TEX_Pos) |
((uint32_t)MPU_ACCESS_SHAREABLE << MPU_RASR_S_Pos) |
((uint32_t)MPU_ACCESS_CACHEABLE << MPU_RASR_C_Pos) |
((uint32_t)MPU_ACCESS_BUFFERABLE << MPU_RASR_B_Pos) |
((uint32_t)0x00 << MPU_RASR_SRD_Pos) |
((uint32_t)MPU_REGION_SIZE_32B << MPU_RASR_SIZE_Pos) |
((uint32_t)MPU_REGION_ENABLE << MPU_RASR_ENABLE_Pos);
What else can I do?
