Author Topic: STM32H7 usb device detection refusal  (Read 7461 times)
Offline SilenosTopic starter
  • Fumbling in ignorance
« on: June 20, 2019, 09:45:29 pm »
Hello. I'm struggling with just starting enumeration of USB FS on the STM32H7 part. Several years ago I've done CDC On F4 part and it was already a major PITA. Now I need a specific composite device, so trying to port some old code. I didn't expect any less carnage, so here it comes:
the USB core refuses to acknowledge VBUS active level at plug-in event, so the device cannot signal Powered state to host by pulling data line. Basically, no core state/flag change at all when VBUS turns active; never get the a/b session valid.
This issue is only similar to this one, but his core raised SRQINT  flag, mine doesn't. Though I investigated SDIS "soft disconnect" bit and it seems it is past my issue.
Potential evaluated suspects:
- pins configuration: data lines are PP AF, VBUS is "digital" input - I think VBUS pin required configuration still isn't mentioned anywhere on docs... during plug-in event VBUS is detected by port; zero activity on data lines though.
- core instance number: the device has two physical ips, yet in docs and CMSIS they are using "OTG_HS..", "OTG_FS.." mnemonics, which are ambiguous, as both cores can run FS on internal PHY and they state somehere else that both ips are HS but one ip lacks ULPI... Point is it isn't clear which core uses which set of DP, DM, VBUS... pins. In the end I checked EVAL boards and assumed that pins on port A are tied to "OTG_FS.." (Cube output conforms too). Even did the same config on both ips, but they both behave the same.
- clock: PLL3 Q output required. HSI48 also evaluated, no difference. Although cannot route PLL3-Q onto the MCO, but I have mirrored the pll config to another pll which could be put on mco pin, and have measured required 48 MHz. But when I put different than 48 MHz bogus freq onto the usb core, it still behaves the same way. Only when I don't route any clock, the system crashes on GRSTCTL CSRST bit. At least some other response.
- Cube generated example - I followed configuration sequence, with no avail. Still couldn't manage to run complete generated example on Keil, I never got it.
- AHB frequency - seems 200 MHz (docs require at least 30 MHz).
My issues during intialization; I have no idea if this is valid behaviour:
- GUSBCFG PHYSEL bit behaves like write-only bit, dunno if it ever apply; can't read it either. Is this bit supposed to persist after setting? In docs it is marked "rw"...
- "setting" PHYSEL causes to core to switch to HOST mode (GINTSTS CMOD bit turns 1).
Code:
#define USB2_OTG_FS_DEVICE ((USB_OTG_DeviceTypeDef *) 0x40080800)
/*48 mhz na PLL Q, assumed 8 mhz input*/
RCC->PLLCFGR &= ~RCC_PLLCFGR_PLL3FRACEN; /*integer pll*/
RCC->PLLCFGR |= RCC_PLLCFGR_PLL3VCOSEL;   /*narrow range vco output:150-400mhz*/
RCC->PLLCFGR |= RCC_PLLCFGR_PLL3RGE_2;   /*range ck in: 4-8Mhz (8Mhz input) */
RCC->PLLCKSELR |= RCC_PLLCKSELR_DIVM3_0; /*input prescaler = 1*/
RCC->PLL3DIVR = ((0x00000003)<<16)|(0x00000017); /*0x17 = 23; 8*(23+1) = 192 Mhz; Q divider: 3+1; output: 192/divider =48mhz*/
RCC->PLLCFGR |= RCC_PLLCFGR_DIVQ3EN;
RCC->CR |= RCC_CR_PLL3ON;
while(!(RCC->CR & RCC_CR_PLL3RDY));
RCC->D2CCIP2R |= RCC_D2CCIP2R_USBSEL_1; /*clock source selection - PLL3-Q*/
RCC->AHB1ENR |= RCC_AHB1ENR_USB2OTGHSEN;  /*peripheral enable*/
RCC->AHB4ENR |= RCC_AHB4ENR_GPIOAEN;
__DSB();
/*PA11-DM, PA12-DP*/
GPIOA->MODER |= GPIO_MODER_MODER11_1 | GPIO_MODER_MODER12_1; /*AF PP*/
GPIOA->MODER &= ~(GPIO_MODER_MODER11_0 | GPIO_MODER_MODER12_0);
GPIOA->OSPEEDR |= GPIO_OSPEEDER_OSPEEDR11 | GPIO_OSPEEDER_OSPEEDR12;  /*SPEED max*/
GPIOA->AFR[1] |= (0x0000000A<<12)|(0x0000000A<<16); /*AF10 (0x0A) - USB DM DP datasheet p82*/
GPIOA->PUPDR &= ~(GPIO_PUPDR_PUPDR11 | GPIO_PUPDR_PUPDR12); /*no pull ups*/
/*PA9 - VBUS*/
GPIOA->MODER &= ~GPIO_MODER_MODER9; /*input*/
GPIOA->PUPDR &= ~GPIO_PUPDR_PUPDR9; /*no pull ups*/
USB2_OTG_FS->GUSBCFG |= USB_OTG_GUSBCFG_PHYSEL;          /*USB 1.1 full-speed serial transceiver*/
delayMs(100);
USB2_OTG_FS->GUSBCFG |= USB_OTG_GUSBCFG_FDMOD;          /*force device mode*/
delayMs(100);
USB2_OTG_FS->GRSTCTL |= USB_OTG_GRSTCTL_CSRST;                              /*Core Soft Reset*/
while((USB2_OTG_FS->GRSTCTL & USB_OTG_GRSTCTL_CSRST) == USB_OTG_GRSTCTL_CSRST);
delayMs(100);
USB2_OTG_FS_DEVICE->DCFG |= USB_OTG_DCFG_DSPD;           /*Full speed using internal FS PHY*/
USB2_OTG_FS_DEVICE->DCTL &= ~USB_OTG_DCTL_SDIS;         /*soft disconnect release*/
USB2_OTG_FS->GCCFG |= USB_OTG_GCCFG_VBDEN;                  /*VBUS detection enable*/
USB2_OTG_FS->GCCFG |= USB_OTG_GCCFG_PWRDWN;             /*USB FS transceiver enabled*/
At this moment core should response at plug in with pulling up data line.
I'm using STM32H743 from Nucleo board, 750 part is the final target, though the board isn't done yet.
Have you ever meet such behaviour, or have any other ideas?
Offline rounin
Re: STM32H7 usb device detection refusal
« Reply #1 on: June 25, 2019, 04:11:39 am »
I'm actually writing a USB stack initially for the H750 right now, and just started getting it working (it shows up under linux, and I can write to /dev/ttyACM0 and have data appear on the device side, but still a lot left). I'm not ready to post code, but might be within a month or so (possibly dual commercial / GPL license as part of the launch of my startup). I'm not using the internal phy or FS mode though (only testing HS PHY right now), and only have code for CDC class right now so not sure how much I can help you.
PHYSEL is working when set to 0 for me, for external ULPI PHY. As far as i know only the OTG_HS core is connected to the external phy. I think you set it to 1 for internal FS phy.
I'm not sure about the VBUS detection stuff though, I'm currently disabling vbus detection and hard setting the core to device mode (USB_OTG_GUSBCFG_FDMOD in GUSBCFG). You could try disabling the host/device detection and force it to be a device or host as needed to skip that step. After I do that, the PHY starts pulling up the data lines as soon as I bring the core out of soft reset (well, and other stuff like turning on the phy clocks etc).
« Last Edit: June 25, 2019, 04:15:07 am by rounin »
Offline ua1arn
  • Country: ru
« Reply #2 on: June 27, 2019, 11:13:09 pm »
Add to your Cube-generated project this line:
   PWR->CR3 |= PWR_CR3_USB33DEN;
Or use HAL function
HAL_PWREx_EnableUSBVoltageDetector
In some prototype boards Cube-generated projects works well because this operation already done by DFU loader of STM32H7 CPUs. This bit can not be reset without power cycle CPU.
« Last Edit: June 27, 2019, 11:21:23 pm by ua1arn »
The following users thanked this post: Silenos
« Reply #3 on: June 29, 2019, 12:27:48 pm »
Yes, I have also found PWR option on Wednesday, but didn't evaluate it until today. Thank you.
@rounin: thanks for a tip about forcing bsession valid. I've detected that Keil debuger doesn't show some bits in GOTGCTL register... yep, it happened I didn't registered all bits descriptions in RM in this exact, one of dozens, register and, of course, the relevant force bits are hidden by Keil. And these, with omitting VBDEN, seem to alternatively solve my issue (idle and disconnected device state results in continous core reset state), though didn't validate it fully as PWR solution has followed.
Don't push it with publishing your code, I cannot release mine and even I'll have the stack integrated with my custom os, so I expect null compatibility.
Btw, @rounin, have you encountered any hardware issues, or the phy "just works" with usb core - of course, with proper pcb ULPI routing and recommended phy layout etc?  I've considered HS but I could't manage to route ULPI from 100 pin package and keep the actually required pins for me. And it smells with minefield of nasty issues. Yet, still, it is tempting..
Offline rounin
« Reply #4 on: June 29, 2019, 07:19:19 pm »
Cool, glad it helped.
Surprisingly, the ULPI PHY did just work. We're not using many pins, so it was ok system-wise. I wouldn't necessarily call the routing "proper" either  :D, fortunately the board is rather small so it seems to be ok, inferring from the lack of corrupted packets. I'm hoping that doesn't bite us later, I don't have access to a nice enough scope to validate the layout / eye diagram stuff, I did finally get a USB2.0 protocol analyzer though.
Offline ua1arn
  • Country: ru
« Reply #5 on: June 30, 2019, 03:27:28 pm »
May USB stack lives here: https://github.com/ua1arn/hftrx/blob/master/usb/usbd.c - heavy modified STM's cube generated codes.
