Author Topic: This is interesting...  (Read 4207 times)
Offline technixTopic starter
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« on: September 12, 2016, 03:16:05 pm »
I got an ATmega32 which have two sets of oscillator inputs, one set for the system clock and the other for a 32768Hz watch crystal when one of the onboard timers is operating in asynchronous mode. And I got an interesting measurement:
Ready.
tock: 998
tock: 1998
tock: 10998
tock: 11998
tock: 12999
tock: 13999
tock: 31999
tock: 32999
tock: 34000
tock: 35000
tock: 53000
tock: 54000
tock: 55001
tock: 56001
tock: 74001
tock: 75001
tock: 76002
tock: 77002
tock: 95002
tock: 96002
tock: 97003
tock: 98003
tock: 116003
tock: 117003
tock: 118004
tock: 119004
tock: 137004
tock: 138004
tock: 139005
tock: 140005
tock: 158005
tock: 159005
tock: 160006
tock: 161006
tock: 179006
tock: 180006
tock: 181007
tock: 182007
tock: 199007
tock: 200007
tock: 201008
tock: 202008
Those "tock" messages are outputed when Timer 2 overflows, which is once per second. The number is milliseconds since initialization of an Arduino-style timer based on Timer 0 which is running at system core clock speed.
What is causing those oscillators to drift apart like that, one millisecond every 20 seconds or so? I am using two crystals, one 2-pin 32768Hz watch crystal, and a 16MHz 4-pin crystal oscillator can.
« Last Edit: September 12, 2016, 03:18:19 pm by technix »
Offline PA0PBZ
Re: This is interesting...
« Reply #1 on: September 12, 2016, 03:29:09 pm »
What is causing those oscillators to drift apart like that..
Why do you think they would be synchronized?
The following users thanked this post: Kilrah
  • Country: cn
    • My Untitled Blog
« Reply #2 on: September 12, 2016, 03:33:50 pm »
I am not expecting synchronization, but I do want to know if this drift is significant.
Offline Kilrah
« Reply #3 on: September 12, 2016, 03:41:13 pm »
Seems within the tolerances of 2 randomly picked crystals working completely independently...
  • Country: cn
    • My Untitled Blog
« Reply #4 on: September 12, 2016, 03:45:23 pm »
If your timer's ISR takes too long to execute before it resets the timer, then your timer interval is effectively compare/period/clock+isr_time, and here the isr_time is your majority source of error.
For instance:
#pragma ISR timer0_vector
void t0isr()
    do_something();
    t0_reset();
takes longer time to reset the timer compared to:
void t0isr()
    t0_reset();
    do_something();
Even for the first case, ISR entrance delay also plays a role in drifting. To get around with it, set the timer to reset itself (continuous mode) and generate interrupts without user code's help.
I used timer overflow interrupts in Fast PWM mode (effectively simple timer mode with PWM instead of comparator output) so there is no timer resetting involved.
Offline Chris Mr
  • Where there's a will there's a way
« Reply #5 on: September 12, 2016, 04:17:01 pm »
Lemme see..
20 seconds and 0.001 seconds out, is like 20,000:1 or to put it another way, 50ppm ((1/20000) * 1,000,000).
Your two crystals might be +/- 100ppm (for example) so what you have noticed is entirely reasonable.
A better explanation would be that whilst you have worked out precisely what the times should be using the crystal frequencies, the +/-100ppm variability of the crystals means those calculations are not as the hardware actually is.  Crystals are temperature sensitive so you could heat one up and watch the discrepancy get either larger or smaller.
If you have a scope, even better is to output two square waves and watch them drift.  Say 512Hz so you get plenty of updates.
Offline tatus1969
  • Resistance is futile - We Are The Watt.
    • keenlab
« Reply #6 on: September 12, 2016, 04:21:09 pm »
those watch crystal can be very nasty and temperature dependent. Take a chance and put your finger on it, I bet that you can see it at your output.
We Are The Watt - Resistance Is Futile!
  • Country: cn
    • My Untitled Blog
« Reply #7 on: September 12, 2016, 04:25:51 pm »
So my general design policy of only using DS3231 TCXO for RTC is a good idea?
