I use this:
https://ftdichip.com/products/ttl-232r-5v-we/
Being a genuine FTDI product is is not the cheapest option but it works perfectly.
Please define "works perfectly". Quite a long time ago the FTDI chips were quite popular, and the Chinese started making clones of them. FTDI reacted by bricking devices which used the cloned chips by deleting USB descriptors in those chips, and after that got too much backlash, they reversed that, but started implementing various other anti features such as injecting ascii characters in the data stream. For more info, search for "FTDIgate". I was not affected by this, as I am using Linux, and don't use the FTDI drivers at all, but none the less, I still avoid using IC's from that company. CP210x and CH340 all work fine on my linux box.
I can't really blame FTDI for wanting to do something against other companies using their driver software, but lots of consumers do not have any influence on what IC's are inside the gadget they buy, and they are duped by this behavior none the less.
USB to RS485 is not really suitable RS485 uses differential signalling over two wires, and it also combines the Rx and Tx wires onto the same differential pair. You can use RS485, but then you also have to use an RS485 driver on the 8051 side, and this also needs a pin to change the direction of the RS485 driver. RS485 is pretty cool, you should look into it some day, but not just yet.
USB to RS232 drivers are a bit "old fashioned". RS232 was invented some 50 -odd years ago and uses pretty high signal voltages. Officially something like +7 to 12V and -7 to -12V. but over time these high voltages have been sort of scrapped from the standard, and (probably non "officially" compliant) versions use something close to 0V and 5V. What is important is that RS232 inverts the signals, So for the RS232 chips, you also have to invert the signals again before they go into your 8051.
CP2102 (or CH340) should work, and so would the FTDI chips. The versions with "TTL" outputs are not inverted, and as a result you also do not have to invert the signals between these adapters and your 8051. When you go from a 3V3 IC to a 5V IC with CMOS inputs, then the input signals are a bit borderline, but usually it works, but it's not a very robust solution. It's also far from ideal to roue microcontroller pins directly to a connector. You can do this on your bench (in your lab), but uC pins are quite fragile, and with connectors (and long wires) you introduce ESD events and other electrical disturbances onto your PCB, and for a reliable solution there should be extra protection and filtering on all signals (and power lines) that enter or leave your PCB.
