Author Topic: Ultimate J-Link programming adaptor  (Read 4586 times)
Offline liteyearTopic starter
« on: January 18, 2024, 12:57:15 pm »
What would your ultimate programming adaptor look like?
1984543-0
1984549-1
I'm looking to design one and release it to the community to solve a common industry frustration. So far I have:
  • Not cost $60+ for a bare bones connector board!
  • Support at least a few common programming cables, so you need less adaptors.
  • Right-angle IDC plug to plug straight into J-Link.
  • 20-pin, 10-pin and 6-pin 0.1" IDC socket headers
  • All configuration via 0.1" jumpers, instead of solder bridges
  • Jumper to configure Target supply voltage: none, 5V, 3.3V
  • Test points for everything
  • Documentation rich silkscreen
  • Additional header to connect a USB to serial adaptor, with jumpers to bridge it to some NC pins?
Maybe some nice to haves:
  • LEDs for power and comms?
  • Prototyping area for custom expansion?
  • 0.05" header?
  • Push button for reset?
  • Jumpers to define own pin mapping?
  • On board FDTI?
Thoughts?
Offline tellurium
  • Country: ua
Re: Ultimate J-Link programming adaptor
« Reply #1 on: January 18, 2024, 01:42:00 pm »
I own these from Ali:
https://www.aliexpress.com/item/1005001992920613.html
https://www.aliexpress.com/item/1005002058682164.html
Almost never used the 1st one, but often the 2nd one.
What I often needed is a serial converter, so your idea about the on board FDTI would make it quite attractive.
Mongoose - a full-stack embedded network library for STM32, NXP and other - https://mongoose.ws
TCP/IP stack + drivers + TLS1.3 + HTTP/WebSocket/MQTT + OTA in a single file
Offline dobsonr741
« Reply #2 on: January 18, 2024, 02:21:03 pm »
Target supply voltage: better to sense target voltage with LVC2T45 than configure and dry by mistake. Target could be powered off, so sensing protects your target.
The following users thanked this post: liteyear, BadeBhaiya
Offline darkspr1te
  • Country: zm
« Reply #3 on: January 18, 2024, 03:28:05 pm »
A lot of the features you mention are provided by the Dangerous prototypes bus blaster , except "standard cable pins" side but it had reconfigurable pins via change to cpld, dual UART , voltage (none,3.3v,5v, user provided down to 1.2v) and it could emulate other jtag adapters  and swd as well. it's party trick is to be able to emulate two j-links , handy when you trying to fix a asus router with two jtag ports.
A real trick would to be a combo of the Bus pirate , that is emulate any 5<  wire protocol sans level converters (eg rs-232/485/CAN Bus/KKline) and provide hardware jtag , with upgradable front end we can also emulate a few flash/prom programmers (hardware required for 12v stuff can be community design)
I recently worked on a device where i had JTAG for two cpu's via the busblaster +bus pirate (needed 1.8v and BB second port does only 3.3v) and two uarts (used stm32 with zenier droppers) and 1 spi eeprom chip (used stm32 with flashrom code) , this was too many devices on my desk and a issue was bound to occur and the project failed, had this been one device i dont think i would have had the issue. But yeah, i had a cable come loose while checking things and it hit 5v into a 1.8v system and job over.
darkspr1te
Offline ejeffrey
« Reply #4 on: January 18, 2024, 05:49:40 pm »
I've been using the jlink plus (not pro) for some years now, primarily with the nxp nee freescale kinetis MCUs and I have to say it's expensive but it works well. Flashing, debug, and I particularly like the segger RTT as a debug console instead of using a uart.   It's been good enough (and I've already got the device).
Offline ajb
« Reply #5 on: January 18, 2024, 11:43:07 pm »
I designed the simple purple PCB below ages ago (as evidenced by the dust and crud it's a accumulated  :-[ ). 99.9% of the time I just want a 10 pin SWD header in 50mil or 100mil pitch, so that's what it's got, plus a target power LED and a reset switch. I think I shared the design on osh park, along with similar ones I designed for the Atmel ICE and stlinkv2.
I did make a more complex adapter that includes a 3v3 regulator, and some dip switches to enable power to the target at 5V or 3v3, plus switches to route the J-Link UART rx/tx to pins 7 and 8 of the 10 pin headers, along with a 100mil header in the standard FTDI pin out. The idea was to have one adapter and one cable to the target for SWD and debug UART, but then I found out that the J-Link is limited to fairly low baud rates. I typically run debug UART as fast as I can, usually 250k, 1M, or 3M (which is the max for the FT232 et al -- though some of those parts go up to 10M). Plus I don't think I've ever actually used a J-Link to provide that power. So I gave up on that version and have been sticking with the simpler one plus a separate FT232 cable.
1985056-0
1985062-1
EDIT: Found the OSH Park project links:
JLink adapter: https://oshpark.com/shared_projects/oIF2gllI
ST-Linkv2 adapter: https://oshpark.com/shared_projects/765ksHTd
Atmel-ICE adapter: https://oshpark.com/shared_projects/JjUfnP7a
An integrated FTDI chip or something like that brings the problem of an additional USB connection. Maybe a vertical USB connector on the back of the PCB, so that the cable lays along the side of the Jlink could make that work?  I kinda like that, actually.
« Last Edit: January 19, 2024, 12:37:56 am by ajb »
« Reply #6 on: January 20, 2024, 03:14:47 am »
Oh that first one's nice, particularly with the cable kit. It strikes me though that I've never needed most of those pinouts, but have often needed 6-way IDC, which it is missing! I guess we all have our own version of "universal".
Nice form factor! Reminds me of the Joulescope front-panel concept. Though I wonder if it compromises available real estate too much.
Oh good one! I'll look into it, but I would have thought the programmer would already do this? To be clear, I'm only considering an adaptor that plugs into an existing programmer.
My killer feature is actually the physical sockets, and the active features are more a "may as well", so this is coming at it from the other direction which is interesting. Looking it up led me to this relevant attempt at adding a universal adaptor the BP!
Thanks everyone for the great ideas. I think it's becoming clear that scope creep is a core challenge! There's so many potential use cases, but throwing the net too wide will quickly compromise that key quality of "handiness".
« Last Edit: January 20, 2024, 03:18:26 am by liteyear »
