sigh.
the full optmizing xc32 is free, you just have to compile it. (its gcc. you know that gcc is free... right?).
XC32 is for PIC32, though, and I can't think of one single, solitary reason to ever consider using PIC32 over an ARM based device. Happy to take suggestions.
I do the entire PIC range as well as ARM, mostly Cortex M4(F) but some M0 and M3 from NXP and TI. You may think it's trivial, but being able to prototype something in ten minutes in DIP is a key reason for me to continue to use PIC extensively. The other reason, perhaps more telling, is that I've been using PICs, and their predecessors, since the late 70s. Like it or not I have an awful lot of boilerplate code and experience for PICs sitting there ready to go, but not as much as with NXP or TI ARM.
The single biggest failure of Microchip has been their awful silicon and development framework since 2013 targeted at the the high end PIC32MZ, although this has improved of late significantly with their floating point PIC32MZ. I guess they were desperate to get something out of the door silicon-wise to compete with M4, but it was a car crash. The framework which you pretty much have to use on the latest PIC32MZs was and still is complete overkill. It was revealed recently it was written by some Linux kernel folks. It shows, it's hugely over abstracted and the newer PIC32MZ chips, with double the processor speed of the PIC32MX, run applications written for the MX without the framework significantly slower.
I am not sure why this needs to be a PIC vs ARM in the same way you could have the same argument about TI ARM vs NXP ARM, to me although there are similarities in the cores, that's generally a minor consideration for most of the time: beyond that they're very different from the peripherals to the vendor libraries to the free IDEs, I could go on, but knowing one ARM Cortex chip from one manufacturer doesn't mean you automatically know all the others, far from it in fact.
Having said all that, I do think Microchip made a marketing blunder going for MIPS rather than ARM, because like it or not that is where everyone thinks they should be, for now at least.
