Author Topic: Upgrading the ESP8266 to 4MB  (Read 3098 times)
Offline ChumanistaTopic starter
« on: August 05, 2016, 05:37:57 pm »
Hello again.
I made another video, this time on upgrading the ESP to the biggest flash chip it can support.
It is really simple, but I hope it'll help someone.
As always: if a moderator tells me to stop posting my videos I will.
Offline FlyingHacker
  • You're Doing it Wrong
Re: Upgrading the ESP8266 to 4MB
« Reply #1 on: August 05, 2016, 05:53:13 pm »
Pretty slick! Easy to upgrade if you need more space.
Thanks.
--73
Offline Kilrah
« Reply #2 on: August 05, 2016, 06:21:18 pm »
Watching you try solder this poor thing is something to make you cringe though  :scared:
« Reply #3 on: August 05, 2016, 06:27:50 pm »
No doubt, but it does demonstrate that anyone can solder these, even if it takes extra cleanup work, etc.
You gotta start somewhere.
--73
The following users thanked this post: Kilrah
« Reply #4 on: August 05, 2016, 06:31:36 pm »
The problems were caused by the camera nearly touching the board to get the shot and having to work around it. It would be much faster and cleaner if I didn't have to record.
« Last Edit: August 05, 2016, 06:42:01 pm by Chumanista »
Offline thm_w
  • Non-expert
« Reply #5 on: August 05, 2016, 09:07:19 pm »
thanks for that video,
For the soldering I would recommend not adding solder on pads after you've wicked them. The part will be raised and pads are uneven height, making it more difficult to solder. You can put some flux if you like though.
Offline b_force
    • One World Concepts
« Reply #6 on: August 07, 2016, 11:17:30 am »
Agree, I normally put some solder on just one pad.
Line up the IC, fix it with that one pad. Solder the opposite pad and than finish the rest.
