Author Topic: usb blaster works once only, needs a reinstall every time!  (Read 3493 times)
Offline diyaudioTopic starter
« on: February 07, 2016, 04:42:00 pm »
I got my usb blaster and Altera CycloneII EP2C5T144 FPGA Mini Development Board, had some time today to set it up...
problem. After following the install procedure for windows 8 (disabling driver signature check)  it works with Quartus II 10.1sp1 Web Edition (it detects the device),however when I unplug the device or accidentally unplug it , it doesn't work! I have to reinstall the the driver every-time, a restart doesn't even fix the problem.
This is the driver error I get.
Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory. (Code 38)
The driver could not be loaded because a previous version of the driver is still in memory.
Its the infamous usb blaster.
http://www.ebay.com/itm/altera-Mini-Usb-Blaster-Cable-For-CPLD-FPGA-NIOS-JTAG-Altera-Programmer-GM-/262136733505?hash=item3d08911f41:g:4W0AAOSwIwhWS~ah
Offline alsetalokin4017
Re: usb blaster works once only, needs a reinstall every time!
« Reply #1 on: February 07, 2016, 06:44:21 pm »
Windows is the problem and Linux is the answer.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #2 on: February 07, 2016, 06:52:11 pm »
:palm:
« Reply #3 on: February 07, 2016, 07:23:59 pm »
bloody hell thank you for that fantastic answer, now can you actually provide a solution.
Offline Jope
  • Country: my
« Reply #5 on: February 07, 2016, 07:33:41 pm »
i suspect your driver is not compatible with Windows 8. the answer is probably Windows XP or Windows 10 :palm: try go to device manager, disable and re-enable the driver. or get the latest driver...
« Reply #6 on: February 07, 2016, 07:56:23 pm »
I tried this. nothing same problem
http://altera-guide.blogspot.co.za/
