Hello,
Yesterday I had an idea, about connecting microcontrollers together with USB. Now, the OTG standard allows it to be host or slave. Cheap micros like the STM32F401 or PIC32s have OTG, and the CDC could make them work as it is a serial port. There is code for the host and the slave operation for the same micro, but this should work between different families and the host could be easily replaced with a PC or a RPi or similar SBC.
Now, the next step would be to use USB hubs to connect more than two microcontrollers together.
This opens endless possibilities. Basically boards could be chained, or connected together with just a standard USB HUB.
Backplanes could be implemented by using these protocol, where only two pins and standard libraries could take care about the entire communication, hot swapping it, timing it, arbitration and so on.
Hardware wise it is cheaper than using any serial communication protocol because a hub chip is cheaper than the next best thing, a 485 transceiver.
So my question is: Did anyone ever did this? Is this firmware-feasible? I don't see too much issues with the hardware side, but what is your opinion?
I see a lot of potential in this architecture.
I know that tablets and other consumer products use USB internally to connect stuff, I'm wondering if this can be adopted to the industrial/instrument environments.
