I can totally see how a compiled language can be tricky with interrupts, since interrupts (and the specific problem you mentioned) are often device specific. I imagine compilers screw that pooch, quite frequently.
Prove it. Seriously. You will find it to be extraordinarily difficult.
Oh, I agree on this. Even if my code works as expected, I know there are bugs in there, somewhere. I have maintained complex code for years. But in assembly, the problems you mention are just another potential source of bugs out of a million. And interrupts make many tasks so much simpler to code, the coding (and the debugging) is much easier by employing them. I am more confident in my code when I'm using the tools that make it way, way simpler, shorter, more efficient, and easier to follow.
FWIW, the datasheet (hopefully, not the errata!) should specify which instructions must not be interrupted, and you should temporarily disable interrupts where needed. Things like this would be the least of my worries when coding a project.
I think TerminalJack has an insightful observation:
My opinion regarding the use of interrupts is that you can/will make more complex use of them on less complex systems (=lower-end hardware.) The complexity will be easier to manage on a smaller system. You also won't likely have an RTOS to leverage.
Maybe the question is loaded, depending on the application/device/language.
On another note, I'm still having a real hard time understanding how a RTOS operates without timers. It seems to me that the device must be using timers in the background, perhaps just hidden from the user.
Yes, you can easily have as many counters as you want in the code loop, but calculating the total delay with the variety of the code branches would be ludicrous. The clock is most certainly incrementing counters and prescalers and storing and acting on that information very similar to the way timers are implented directly by the user in lower level devices.
