Author Topic: Using PC RAM with microcontrollers  (Read 7828 times)
Offline NiHaoMikeTopic starter
    • Facebook Page
« on: November 06, 2011, 07:51:00 pm »
Recently, I managed to get a bag of old RAM for free. It had a few 30 pin and 72 pin SIMMs, lots of SDRAM and DDR DIMMs, and even a few small DDR2 DIMMs. Since none of them are usable (or worth using) in a modern PC, is it possible to use them with high end microcontrollers like a PIC24/dsPIC or ARM M4?
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
Online mikeselectricstuff
    • Mike's Electric Stuff
Re: Using PC RAM with microcontrollers
« Reply #1 on: November 06, 2011, 09:23:04 pm »
Forget DDR2 or later as they tend to have PLL clocks that require a minimum clock rate.
Standard SDRAM (unbuffered) can be interfaced fairly easily, either using onboard memory controllers on some of the higher end ARMs etc., or (slowly) via I/O ports.
If you want good info on the protocols check the Micron website - their datasheets are very clear and comprehensive.
SDRAM is also very easy to interface to FPGAs.
Day Job: Mostly LEDs
Offline johnmx
  • Country: pt
« Reply #2 on: November 06, 2011, 09:26:26 pm »
DRAM memories need a special controller to continuously refresh the memory cells. My guess is that this type of memory is not good for microcontrollers. SRAM type doesn’t have this problem.
Best regards,
johnmx
« Reply #3 on: November 06, 2011, 10:34:04 pm »
If you can access the  RAM at reasonable speed, then refresh is a relatively easy task.
Offline Psi
« Reply #4 on: November 07, 2011, 03:41:25 am »
You won't be able to use external ram to extend the micros built in ram in order to have more variables etc.  unless external ram is a special feature of that micro.
But you can wire up the sram and write some code to read/write it yourself.
« Last Edit: November 07, 2011, 03:44:03 am by Psi »
« Reply #5 on: November 07, 2011, 10:12:56 am »
That's not necessarily true - some C compilers can support special variable types which are read and written via user-supplied routines, but can be accessed like normal variables.
For example the IAR AVR compiler supports an __eeprom type qualifier that allows eeprom data to be  used like any other variable.
Offline sub
« Reply #6 on: November 07, 2011, 11:10:07 am »
Even without magic compiler directives, if you're willing to use C++ you could probably accomplish the effect with operator overloading.
