Author Topic: Variable Clock Divider  (Read 1269 times)
Offline Sparky49Topic starter
« on: March 20, 2019, 12:05:37 am »
I'm in the process of designing a project with a Cyclone IVE. Part of this requires creating an adjustable clock to put out. I've so far settled on using the ALTPLL from the Altera IP Catalog to achieve this ( in reconfigurable mode). However, I still need to calculate the values for M, N and C in the PLL for a given frequency, where
Fout = (Fin * M)/(N*C)
Fin = input freq
Fout = output freq
M = counter (multiplier) part of clk feedback
N = counter (divider) part of clk feedback
C = post-scale counter (divider)
But I am at a loss as to how I could calculate these three values. I also have a nios ii processor running on this device, so an implementation could easily be done in C rather than a HDL. How could I arrive at these three values to give an accurate, given Fout when I have a fixed Fin?
Many thanks in advance.
Offline hamster_nz
Re: Variable Clock Divider
« Reply #1 on: March 20, 2019, 03:50:30 am »
  f_in = ????  << Your input frequency
  f_Vco_max = ???  << From the datasheet, for your FPGA's speed grade
  f_Vco_min = ??? << From the datasheet, for your FPGA's speed grade
  for all possible m values
     f_Vco = Fin * m
     if f_Vco >= f_Vco_min and f_Vco <= f_Vco_max then
       for all possible n values
          f_out = f_Vco / n
          if f_out = F_desired then
             write "Values are " m " and " n
          end
       loop
     end
  loop
If you intend to use the post-scaler, you will need a third loop to try different 'C' values.
Edit: Having a quick look at the data sheets, the PLL internal VCO operating range is 600 — 1300 MHz, but don't  trust me on that one.
« Last Edit: March 20, 2019, 04:19:54 am by hamster_nz »
The following users thanked this post: Sparky49
