Author Topic: VHDL: Comparing an integer and a std_logic_vector  (Read 17699 times)
Offline Pack34Topic starter
« on: September 16, 2015, 07:33:45 pm »
Here's my situation. I'm reading in values over I2C and trying to set some switches in a top level process to configure a device.
To do so, I'm reading in values over I2C and storing them in a std_logic_vector array. Then when I've read in the complete signal I throw a flag and trigger a process in my top_level file. This all seems to work, but when I attempt to compare this read-in value to some integer constants to then set my configuration I keep getting lots of errors, such as:
Type error near setting ; current type integer; expected type std_logic_vector
When looking up my issue on the internet, the functions TO_INTEGER(UNSIGNED( ... )) keeps popping up as a solution but it just won't pass the compiler. I get the following errors:
ERROR:HDLCompiler:432 - Line 982: Formal <arg> has no actual or default value.
ERROR:HDLCompiler:541 - Line 982: Type integer is not an array type and cannot be indexed.
ERROR:HDLCompiler:1690 - Line 982: This construct is only supported in VHDL 1076-2008
Does anyone know what I can do to solve this? I'm completely stumped.
Offline AndyC_772
Re: VHDL: Comparing an integer and a std_logic_vector
« Reply #1 on: September 16, 2015, 07:53:55 pm »
Have you tried:
IF vector = CONV_STD_LOGIC_VECTOR (constant_integer, width) THEN...
or
IF CONV_INTEGER (vector ) = constant_integer THEN
« Reply #2 on: September 16, 2015, 08:14:56 pm »
Neither compile for me.
I've resorted to writing my own function. But I'm getting syntax errors that seem to kick off on the first ":=" operator in the first IF statement.
function slv16_to_int ( slv16_in : std_logic_vector(15 downto 0) )
return integer is
variable Rolling_sum_s  :  integer;
begin
Rolling_sum_s := 0 ;
if slv16_in(0) := '1' then
Rolling_sum_s := Rolling_sum_s + 1 ;
end if;
if slv16_in(1) := '1' then
Rolling_sum_s := Rolling_sum_s + 2 ;
end if;
if slv16_in(2) := '1' then
Rolling_sum_s := Rolling_sum_s + 4 ;
end if;
if slv16_in(3) := '1' then
Rolling_sum_s := Rolling_sum_s + 8 ;
end if;
if slv16_in(4) := '1' then
Rolling_sum_s := Rolling_sum_s + 16 ;
end if;
if slv16_in(5) := '1' then
Rolling_sum_s := Rolling_sum_s + 32 ;
end if;
if slv16_in(6) := '1' then
Rolling_sum_s := Rolling_sum_s + 64 ;
end if;
if slv16_in(7) := '1' then
Rolling_sum_s := Rolling_sum_s + 128 ;
end if;
if slv16_in(8) := '1' then
Rolling_sum_s := Rolling_sum_s + 256 ;
end if;
if slv16_in(9) := '1' then
Rolling_sum_s := Rolling_sum_s + 512 ;
end if;
if slv16_in(10) := '1' then
Rolling_sum_s := Rolling_sum_s + 1024 ;
end if;
if slv16_in(11) := '1' then
Rolling_sum_s := Rolling_sum_s + 2048 ;
end if;
if slv16_in(12) := '1' then
Rolling_sum_s := Rolling_sum_s + 4096 ;
end if;
if slv16_in(13) := '1' then
Rolling_sum_s := Rolling_sum_s + 8192 ;
end if;
if slv16_in(14) := '1' then
Rolling_sum_s := Rolling_sum_s + 16384 ;
end if;
if slv16_in(15) := '1' then
Rolling_sum_s := Rolling_sum_s + 32768 ;
end if;
return Rolling_sum_s;
end function slv16_to_int;
« Reply #3 on: September 16, 2015, 08:35:08 pm »
I'm not sure why it didn't like the comparison opperator, but switching it to > '0' seemed to fix it.
Now that I've implemented the function, added it to my top level code I get the following error:
Checking the design properties and the CHDL Source Analysis Standard is set to VHDL-200X.... This is tarting to get frustrating...  |O
Offline AndyC_772
« Reply #4 on: September 16, 2015, 09:19:36 pm »
:= is the operator for variable assignment, it doesn't mean comparison. The comparison operator is just an = on its own.
Don't forget to include the standard libraries at the start of your code:
library IEEE;
USE IEEE.std_logic_1164.all;
USE IEEE.std_logic_unsigned.all;
USE IEEE.std_logic_arith.all;
Offline Bassman59
  • Yes, I do this for a living
« Reply #5 on: September 16, 2015, 11:24:36 pm »
library IEEE;
or, less obsoletely,
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
Offline nctnico
« Reply #6 on: September 17, 2015, 05:49:03 am »
I agree. I suggest using signed and unsigned types instead of std_logic_vector and casting later on. In my experience these cause less hassle with casting/conversion/mathematic operations.
« Reply #7 on: September 17, 2015, 01:30:03 pm »
Just to provide some clarity, the issue compiling seemed to be related to where I was using these functions and not the functions themselves.
The initial configuration that was changing was using with/select statements and it seems that the compiler just didn't like them with the function being called inside the with statement. I ended up moving everything to a couple if statements and the code seems to be running fine, just need to update a test bench to verify. The actual error thrown by the compiler was odd and was leading me to verify the version of VHDL I was using but restructuring my code fixed it.
With/Select
http://www.sigasi.com/content/signal-assignments-vhdl-withselect-whenelse-and-case
As for signed and unsigned instead of std_logic_vector, is there a downside to just switching everything over? And for bit arrays there's no issue? Are there specific circumstances that it would be desired to use std_logic_vector over std_logic_unsigned?
Offline Scrts
  • Country: lt
« Reply #8 on: September 17, 2015, 04:06:39 pm »
library IEEE;
No nO NOOOO! :scared:
Use numeric_std only!
Offline AndyC_772
« Reply #9 on: September 17, 2015, 05:06:24 pm »
Why?
Offline nctnico
« Reply #10 on: September 17, 2015, 08:22:58 pm »
With the libraries you mentioned you need to choose between having VHDL treat a std_logic_vector as signed or unsigned. Want to mix signed and unsigned? You are out of luck. Want to use a std_logic_vector signal as an array index? You need to cast it first. These problems largely go away with numeric_std.
Offline AndyC_772
« Reply #11 on: September 18, 2015, 07:38:04 am »
OK, I'll take a look and see if it's worth migrating. Thanks.
