Author Topic: VHDL question (solved)  (Read 1753 times)
Offline DagoTopic starter
    • Electronics blog about whatever I happen to build!
« on: October 24, 2015, 04:21:29 pm »
I have an entity with a generic of type natural. Then I have a function which takes a natural number as an argument and returns a natural number. I then try to create a variable in the entity with such as "variable foo : unsigned(my_function(my_generic) downto 0);" and modelsim will complain "no feasible subprogram found" about the my_function call. I pretty much also tried different types for the generic and function return type/argument etc. but no dice. This function works fine when called with for example some_other_variable'length but not with the generic.
What is happening?
Edit: Gah solved, I had an enumerated type the same name and I didn't realize this due to case insensitiveness...
« Last Edit: October 24, 2015, 04:23:19 pm by Dago »
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
