Author Topic: video output processing (FPGA)  (Read 2051 times)
Offline bbsfooTopic starter
  • Country: hk
« on: August 26, 2016, 01:13:50 am »
One systems output 320x240 RGB signal, and displayed on the LCD(320x240). Now requires the output to 480x320 LCD, centered image, do not stretch.
how?
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
Re: video output processing (FPGA)
« Reply #1 on: August 26, 2016, 08:42:11 am »
Count...
 :popcorn:
Wrong code should not compile!
The following users thanked this post: Kilrah
Offline Scrts
  • Country: lt
« Reply #2 on: August 26, 2016, 02:57:52 pm »
Generate black video of 480x320 and overlay your original video on top. For Altera it's like 5 minutes job: Add color pattern generator, uniform background: RGB 0,0,0. Then add Alpha blending mixer, connect ch0 to the pattern generator and ch1 to your video. Alpha <= '1' on both. Done.
    • Marctronix Blog
« Reply #3 on: August 26, 2016, 03:08:04 pm »
Well, if it's real VGA (analog) you need some ADCs in there too, I think....
Also, you may need to resample to correct for timing differences in the video signals..?
