Author Topic: Weird pointer issue  (Read 2767 times)
Offline IuriCTopic starter
  • Country: br
Weird pointer issue
« on: November 20, 2014, 04:39:31 pm »
I'm having a little weird issue in my code running on a ARM Cortex M0 (LPC1114), probably is just a ridiculous mistake bypassing my view. I'm using LPCXpresso IDE, coding in C.
Let me break it down for you guys:
I have one typedef struct in my code that defines my circular buffer nodes. Exactly the same below.
typedef struct {
uint8_t addr;
uint8_t offset;
uint8_t rw;
uint8_t size;
uint8_t status;
uint8_t data[8];
} EEPROM_MemoryPageNode;
My read function receives one pointer of that structure above as a parameter to retrieve data. Function declaration below.
uint8_t _EEPROM_readBytes(uint8_t address, uint8_t size, EEPROM_MemoryPageNode* mem);
Inside the function I catch the memory address of my last node in my circular buffer.
mem = (EEPROM_MemoryPageNode)&_pageNodes[_stopNode];
Here comes the issue. I call the function as below:
EEPROM_MemoryPageNode* mem;
_EEPROM_readBytes(0x00, 0x01, mem );
It compiles ok, but for some reason the variable "mem" doesn't catch the address of my node! I did some debugging and could not fix it.
As I said earlier, probably a small detail escaping through my hands. Any help is welcome.
Thank you.
« Last Edit: November 21, 2014, 06:34:37 pm by IuriC »
Offline DJohn
Re: Weird pointer issue
« Reply #1 on: November 20, 2014, 04:55:12 pm »
If you want it to change the mem variable in the caller, you need to pass in a pointer to that variable.  As it is, you're passing the value of mem, which is a pointer to EEPROM_MemoryPageNode.
You want
uint8_t _EEPROM_readBytes(..., EEPROM_MemoryPageNode** mem )
  *mem = whatever;
_EEPROM_readBytes( ..., &mem );
  • Country: br
« Reply #2 on: November 20, 2014, 05:41:11 pm »
Didn't work. First time I got this kind of issue with pointers, may be some limitation on compiler?
  • Country: br
« Reply #3 on: November 20, 2014, 06:07:08 pm »
oh man... found it! I was forgetting to allocate memory! I can't believe it  :palm: :palm: :palm:
Thank you DJohn.
