Author Topic: What is Data flash memory not Flash memory, in Microcontroller?  (Read 1690 times)
Offline sangarTopic starter
  • Country: in
« on: December 13, 2018, 08:52:31 am »
Hello all,
I have just look at M487JIDAE nuvoton microcontroller which has Flash memory of 512KB and SRAM-160KB...Other than this, it has Data Flash memory which is configurable...Could anyone tell the purpose of Data Flash memory?
Thanks,
Muthu
Offline ataradov
    • Personal site
Re: What is Data flash memory not Flash memory, in Microcontroller?
« Reply #1 on: December 13, 2018, 09:17:01 am »
It is a section of the main flash array dedicated for storing data. It is writable even if the rest of the array is locked for writing.
Alex
  • Country: in
« Reply #2 on: December 13, 2018, 02:21:57 pm »
Hi Alex,
Thanks...So, Can I take it as EEPROM?...
Regards,
Muthu
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: December 13, 2018, 02:42:44 pm »
And probably has higher endurance
Day Job: Mostly LEDs
« Reply #4 on: December 13, 2018, 02:44:15 pm »
Hi Alex,
Regards,
Muthu
Yes, except it is probably only eraseable in large blocks - typically smaller than than program memory block size but if it's called flash and not eeprom it's unlikely to have single byte erase, so you need to do a read/erase/rewrite to update individual bytes
Offline legacy
« Reply #5 on: December 13, 2018, 02:50:40 pm »
Why FeRam is still so expensive? it would be nice to have it instead of Flash.
Offline David Hess
  • DavidH
« Reply #6 on: December 13, 2018, 02:57:17 pm »
It requires extra processing steps which are not native to a CMOS process.  Flash just requires floating gates.
Offline tszaboo
« Reply #7 on: December 13, 2018, 02:59:27 pm »
We really should have MRAM microcontrollers with unified memory space, replacing the 3-4 different memory types on these kind of projects. Because large MRAM can replace Flash, EEPROM, NVRAM and SRAM. Only if Everspin wouldn't concentrate on the wrong market.
Offline ataradov
    • Personal site
« Reply #8 on: December 13, 2018, 03:35:48 pm »
No, it it is quite literally logically reserved part of the main flash array. It is no different than main memory. The only thing that is different about it is logic that defines write permissions.
Alex
Offline ataradov
    • Personal site
« Reply #9 on: December 13, 2018, 03:37:47 pm »
It has 4K erase granularity. In order to make it really work as EEPROM, you would have to create some emulation layer.
Alex
  • Country: in
« Reply #10 on: December 13, 2018, 04:46:07 pm »
Thank you very much to make me understand this...
Thanks,
Muthu
