With due respect, prime calculation is not a very representative real world example.
It correlates well with other things. The exact task is not important, what is important is to have a similar mix of calculation, loads and stores, control logic. The main reason to use primes calculation is to give small code that a compiler is not going to be able to optimise away.
Plus, the zpugcc does not optimize very well, apart from some linker relaxation that is occuring later.
Then that is a black mark against ZPU as no one is going to program any significant application in assembly language.
I looked at the code size in a ready to run executable, so any linker relaxation had already been done.
But even then, it turns out compact enough, see attached image for a typical remote control application. MSP430 wins the race, obviously
It does, but I don't see why it's "obviously". MSP430 has a number of features that make its code density worse than it could be in a more complex ISA, including all branch offsets and all offsets from pointers and all constants for 16 bit arithmetic (except -1, 0, 1, 2, 4,
are a full 16 bits in the code. Many competing ISAs include 5, 8, or 12 bit constants and offsets.
Also I notice the Thumb listing in the table is ARMv5, which is quite limited compared to ARMv7 or RISC-V, especially in only being able to conveniently work with 8 registers.
I would think Thumb2 and RISC-V would both be smaller than ZPU on this "netpp" code.
this is also due to better compiler optimization. GCC just can't handle stack machines well
As an ISA designer and compiler engineer I can't see any reason why this would be true. GCC does just fine with the register-poor i386 where many functions have most of their variables on the stack.
ZPU's STORESP_n and LOADSP_n provide quick and easy access to the top 32 stack elements and ADDSP_n is also very convenient to add any of the top 16 elements in the stack to TOS.
32 local variables -- essentially virtual registers -- is really quite generous.
ZPUs code size suffers from being a STACK MACHINE with byte-oriented instructions because something like
x += n needs
IM_n; ADDSP_x; STORESP_x if x is one of the top 16 variables, or
LOADSP_x;IM_n;ADD;STORESP_x for variables 16..31, which are 3 and 4 bytes respectively while Thumb and RISC-V and M68000 can all add or subtract a small constant with a 2 byte instruction -- and 8086 can INC/DEC with a single byte.
There are numerous other examples. Stack machines gain over register machines only in the case of complex arithmetic expressions, and the fact is that most statements in most programs are very simple.
This is not a question of a compiler not being clever enough to optimise stack code. A human can't do any better.
In this example, the binary has crappy entropy due to many 32 bit immediate loads which consume 5 bytes on this architecture.
32 bit immediate loads use 6 bytes in Thumb (PC-relative load from a constant pool) and 8 bytes in RISC-V (
LUI;ADDI). So that's not it.
