Author Topic: Which DMA microcontroller engines you like the most?  (Read 13864 times)
Offline benSTmaxTopic starter
« on: January 12, 2017, 03:59:31 pm »
These days most of the popular 32-bits MCUs have an ARM core with maybe one exception which is Microchip (using MIPS cores in their PIC32s).
In such a situation the differentiation comes from the peripheral themselves.
The DMA engine within a micro can help a developer differentiate between a few products from different vendors.
Throughout the years I have used parts from TI, ST, former-Freescale/NXP (and soon Qualcomm), Microchip, Cypress, former-Atmel (now Microchip).
Till recently, my preferred DMA engine was the one used in the TI's Tiva TM4C12x series.
Then came the one used in Freescale's Kinetis K6x series.
Inspired by mikeselectricstuff's projects using PIC32 here and here (A big Thank You for the materials on this topic posted on his Youtube channel), I started exploring the DMA engine in the PIC32MX250 series from Microchip and I totally love it.
Right now, my personal ranking would be:
  • Microchip's PIC32MX250 DMA engine - My current favorite. Though a simple engine, it is incredibly powerful and versatile due to the clever DMA trigger selection. You can do amazing things with it due to the large number and flexibility (in choice) of DMA triggers. For me, this DMA engine required the smallest learning curve
  • TI Tiva TM4C12x DMA engine - This was my personal favorite till PIC32. The scatter-gather capabilities are amazing and for me it required a medium learning curve
  • Freescale's Kinetis K6x DMA engine - I have used this engine in a few projects and it has a lot of possibilities. However this isn't a simple engine and you have quite a few registers to program
« Last Edit: January 12, 2017, 04:02:06 pm by benSTmax »
Offline mark03
Re: Which DMA microcontroller engines you like the most?
« Reply #1 on: January 12, 2017, 05:02:09 pm »
IMO, a proper DMA engine should support circular buffers in such a way that you can pause an in-progress DMA, add some data to the circular queue, and then restart the DMA, without a lot of hassle.  The one Kinetis part I used (I think it was a KL26?) was wonderful.  All of the STM32 parts fail on this metric, unfortunately.  Their "circular" mode should be called auto-repeat instead; once you stop a DMA you cannot pick up where you left off.  Too bad we can't mix and match our favorite peripherals from different vendors!
Offline Howardlong
« Reply #2 on: January 12, 2017, 05:27:31 pm »
The DMA in PIC32s allows circular buffers (it's called auto enable) and includes several buffer interrupts including at full and at half full so implementing continuous ping pong buffers in a single DMA channel  is simple, or as simple as it can be with DMA. You can also do it with DMA channel chaining, but that's expensive in terms of burning up DMA channels.
Getting stuff like cache coherency working is an irritation you can do without, as is Microchip's continual desire to rip up peripheral libraries and start again every three or four years, so I program the registers directly rather than pay the tax of having to learn another API.
The only other processor I've done DMA on recently is the NXP LPC4370, which was OK but had limitations on maximum buffer size which was 4095 bytes IIRC. The PIC32 has no buffer size restriction, you can DMA the entire physical address space in one transaction if you want to.
Offline hans
« Reply #3 on: January 12, 2017, 08:43:23 pm »
I only used the SMT32F407 and PIC32MX795 DMA's so far.
I think it's quite possibly one of the worst/frustrating and one of the best/elegant implementations right beside each other, in huge favour of the PIC32.
The PIC32 is simple to understand & program, yet it functions very well. The shadow IRQ system is excellent, as it allows any channel to be used with any IRQ trigger for any DMA transfer.
STM32 on the other hand probably has more options than the PIC32, but due to their channel selection it means you have to check triggers for particular channels during hardware design phase. More problems arise when e.g. you have a complex DMA use case and have collisions in this table. Also the extra delays between DMA1 and DMA2 for APB1/2 are noticeable at high frequencies.
Haven't tried Tm4C12x, but scatter/gather sounds like an excellent feature considering most large memory MCU's have broken up memory maps.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #4 on: January 13, 2017, 06:08:09 pm »
I don't have any DMA experience ouside PIC32 but I like it's orthogonality, in that any IRQ can trigger a DMA from any address to any address, which came in handy recently when I used the DMA-complete int to load a constant into a timer-control register to stop an external clock precisely.
I'm sure you could do some really crazy stuff by DMAing things between hardware registers. I wonder what happens if you DMA stuff into DMA registers...  :scared:
Day Job: Mostly LEDs
Offline retrolefty
« Reply #5 on: January 13, 2017, 08:49:45 pm »
 It creates a Black Hole and we all perish.
The following users thanked this post: jnz
« Reply #6 on: January 13, 2017, 10:37:17 pm »
BTW here's another one  on using DMA to get image data from a camera into a PIC32
Offline hans
« Reply #7 on: January 13, 2017, 11:23:12 pm »
Use DMA to transfer data between hardware/RAM, and then use a second channel to swap the RAM source or destination start pointers from the first DMA channel automatically via the DMA complete IRQ.
Then if  the DMA the complete ISR occurs from channel 2, all buffers are sent.
If you need to send arbitrary size buffers, use a 3rd DMA channel to control the second in which the 2nd writes the source and size registers of 1st in bursts, and the 3rd resets the 2nd DMA channel destination address for the next burst.
Hmm, now I wonder if that could really work... not sure how much the DMA controller likes it's pointers to be touched when it's active  :box:
I'm sure it will kill an electron somewhere in the chip by doing that though. :-/O
« Last Edit: January 13, 2017, 11:29:23 pm by hans »
« Reply #8 on: January 13, 2017, 11:37:47 pm »
You could do some seriously crazy code obfuscation .. throw in CRC and abort on pattern-match for good measure.
Offline timb
    • timb.us
« Reply #9 on: January 14, 2017, 06:20:39 am »
I particularly like the DMA of the PSoC 5LP. They even make it easy to setup with a DMA wizard. Another neat thing is the DMA component has status pins, which makes it possible for the programmable logic to trigger DMA reads and writes completely outside of the software. (This allows you to do cool stuff like, say, move data from an I2C sensor to SPI flash when the sensor pulls an IRQ line, all with basically no CPU intervention.)
« Last Edit: January 14, 2017, 09:22:13 pm by timb »
The following users thanked this post: Carl47D, newbrain
Offline Karel
« Reply #10 on: January 14, 2017, 08:46:06 am »
Microchip PIC32.
Honestly, it was the first one where I used DMA and it was so easy to implement just by reading the datasheet and
the PIC32 family manuals, that I never felt the need to try something else.
So, I can't compare with other brands (have done some stuff wit AVR in the past, no DMA though), but I'm quiet
satisfied with PIC32's, also because they are easy to setup. Apart from the Harmony framework which I detest.
Offtopic: Once, when I was visiting the company that does our series production, I asked them which MCU's are used most
on the boards they produce for their clients. I expected it to be ARM but they said Microchip is used most.
Their clients do automotive, aerospace and industrial.
« Last Edit: January 14, 2017, 08:52:51 am by Karel »
Offline Howardlong
« Reply #11 on: January 14, 2017, 03:38:16 pm »
I've given up with Harmony for anything other than USB and Ethernet. Everything else is hand rolled bare metal SFR access, including PIC32MZ.
Offline Howardlong
« Reply #12 on: January 15, 2017, 06:30:39 pm »
One feature I'd like with PIC32 DMA that's missing is a padding feature allowing you to interleave data without resorting to manipulation after the fact.
« Reply #13 on: January 15, 2017, 07:27:37 pm »
Something else that would be handy is the ability to configure a pin to output a pulse whenever a transfer occurs - debugging DMA can be a bit of a PITA as it;s hard to know when transfers occur.
Offline Howardlong
« Reply #14 on: January 15, 2017, 11:12:07 pm »
Indeed. I had a bug only two days ago on an MZ where after hundreds of thousands of transfers one or two of six DMA channels would stop issuing interrupts.
I was using IFSybits.DMAxIF=0 (non-atomic read-modify-write) in the ISR rather than IFSySET=DMAxIFBIT (atomic). As other DMA channels hit the same IFSy register, coincidentally they would interfere with the CPU accessing the same word, and the ISR would fail to fire once in a blue moon despite the DMAxIF and DMAxIE bits being set. That took a few hours to figure out.
« Reply #15 on: January 16, 2017, 12:08:42 am »
Yeah I've been bitten by that as well - after the first couple of incidents you start to recognise "once in a blue moon"  behaviour & realise it's a tiny "window of fail" somewhere.
Offline Howardlong
« Reply #16 on: January 16, 2017, 09:19:42 am »
Thing is, it works on PIC24 and PIC16 because unlike MIPS those cores have atomic bit set/reset.
Unfortunately, unlike the base registers themselves, the bit fields for the set/clear pseudo SFRs are not declared by the provided devices' header files, so either you declare them yourself or use the PLIB out of the dreaded Harmony, which then means your code has a dependency on Harmony working, and those declarations and functions not being deprecated or changed.
« Reply #17 on: January 16, 2017, 01:34:47 pm »
Are they hardcoded in the PLIB functions, or is the a header file you could steal from PLIB to do it yourself ?
I generally avoid using manufacturer-provided libraries  - a nasty I got caught by a while ago was that a very simple library call (IntDisableInterrupts on PIC24) which I assumed was implemented as a macro, as it should be a single instruction,  was actually implemented as a subroutine call.
Problem was I'd used in a bootloader, so you could only update firmware once :palm:
Offline Howardlong
« Reply #18 on: January 16, 2017, 04:05:32 pm »
These days I try to avoid peripheral libraries too.
My process for this has changed since using the PIC32MZ which pretty much demands Harmony if you want to use anything from the peripheral libraries such as chip setup.
For the basic projects, I don't use MHC or Harmony at all except for a few PLIB resources. Below is my typical boiler plate code for a new project.
o Set up as non-Harmony Project;
o Add "c:\microchip\harmony\v1_09\framework" to the project's include directories;
o Add "c:\microchip\harmony\v1_09\bin\framework\peripheral\PIC32MZnnnnEFxnnn_peripherals.a" as a Library/Object file to the project;
o Create a clean main.c file in the project, deleting all the machine generated shit;
o Add the following example code in main.c;
// DEVCFG0
#pragma config JTAGEN = OFF             // JTAG Enable (JTAG Disabled)
#pragma config ICESEL = ICS_PGx2        // ICE/ICD Comm Channel Select (Communicate on PGEC2/PGED2)
/*** DEVCFG1 ***/
#pragma config FNOSC =      0 //FRCDIV, note that setting this to 7 instead of 0 causes a clock failure, and COSC set to BFRC
#pragma config IESO =       OFF
#pragma config POSCMOD =    EC
#pragma config OSCIOFNC =   OFF
#pragma config FCKSM =      CSECME
#pragma config FWDTEN =     OFF
#pragma config FDMTEN =     OFF
#define PLIB_DISABLE_OPTIMIZATION_WARNING
#include "peripheral/peripheral.h"
#include <xc.h>
#include <sys/attribs.h> // Interrupt macros
#include <stdint.h>
#include <stdbool.h>
o Add the following functions and main() to main.c:
static void CPUInit(void)
    // Note that cache is already configured by startup code
    // C:\Program Files\Microchip\xc32\v1.42\pic32-libs\libpic32\stubs\pic32_init_cache.S
    // Set up wait states
    PLIB_PCACHE_WaitStateSet(PCACHE_ID_0, 2); // Adjust as appropriate for memory and clock
    // Set up prefetch
    if (PLIB_PCACHE_ExistsPrefetchEnable(PCACHE_ID_0))
        PLIB_PCACHE_PrefetchEnableSet(PCACHE_ID_0, PLIB_PCACHE_PREFETCH_ENABLE_ALL);
    // Set up interrupt controller
    PLIB_INT_MultiVectorSelect(INT_ID_0);
    PLIB_INT_Enable(INT_ID_0);
static void OSCInit(void)
    // Switch to 200MHz PLL sourced from 24MHz EC POSC
    PLIB_DEVCON_SystemUnlock ( DEVCON_ID_0 );
    PLIB_OSC_SysPLLInputDivisorSet(OSC_ID_0, OSC_SYSPLL_IN_DIV_3); // Generate 8MHz from 24MHz POSC
    PLIB_OSC_SysPLLFrequencyRangeSet(OSC_ID_0, OSC_SYSPLL_FREQ_RANGE_5M_TO_10M);
    PLIB_OSC_SysPLLInputClockSourceSet(OSC_ID_0, OSC_SYSPLL_IN_CLK_SOURCE_PRIMARY);
    PLIB_OSC_SysPLLMultiplierSelect(OSC_ID_0, 50);
    PLIB_OSC_SysPLLOutputDivisorSet(OSC_ID_0, OSC_SYSPLL_OUT_DIV_2);
    PLIB_OSC_SysClockSelect(OSC_ID_0, OSC_PRIMARY_WITH_PLL);
    while (!PLIB_OSC_ClockSwitchingIsComplete(OSC_ID_0))
        Nop();
    PLIB_DEVCON_SystemLock ( DEVCON_ID_0 );
void main(void)
    CPUInit();
    OSCInit();
//  Your code goes here
Setting up the CPU and oscillator is almost all I use the PLIBs for, I use bare metal SFR access for almost everything else. It's my intention to move to bare SFR access to set the oscillator in future, but this is a hangover from the time I did actually try to use PLIB but have since decided it's not worth the effort.
If I could be sure the PLIBs were:
(a) correct;
(b) fit for purpose;
(c) able to cover the complete set of peripheral use cases;
(d) not going to be deprecated any time soon;
(e) easy to use and learn;
then I'd be more likely to use them. As it is, within a year or two of release the peripheral library APIs no longer fit the peripherals of newer devices.
Offline Karel
« Reply #19 on: January 16, 2017, 04:53:32 pm »
I still prefer the PIC32MX series and I use the following boilerplate code:
#include <xc.h>
// #define CPU_HZ 30000000
// #define CPU_HZ 38000000
#define CPU_HZ 96000000
#if CPU_HZ <= 40000000
  CHECON = 0;  /* disable data caching, disable predictive prefetch, zero wait states */
  BMXCONCLR = 1 << 6;  /* data RAM accesses from CPU have zero wait states for address setup */
#else
//  CHECON = 0x00000312;  /* enable data caching with a size of 4 lines */
                        /* enable predictive prefetch for cacheable regions only */
                        /* two waitstates for PFM */
  CHECON = 0x00000332;  /* enable data caching with a size of 4 lines */
                        /* enable predictive prefetch for both cacheable and non-cacheable regions */
#endif
#pragma config FSRSSEL = PRIORITY_7      /* Shadow Register Set Priority Select */
#pragma config FPLLIDIV = DIV_2          /* System PLL input divider */
#if CPU_HZ == 30000000
#pragma config FPLLMUL = MUL_15          /* System PLL multiplier */
#pragma config FPLLODIV = DIV_2          /* System PLL Output Clock Divider */
#pragma config FPBDIV = DIV_1            /* Peripheral Clock Divisor */
#endif
#if CPU_HZ == 38000000
#pragma config FPLLMUL = MUL_19          /* System PLL multiplier */
#endif
#if CPU_HZ == 96000000
#pragma config FPLLMUL = MUL_24          /* System PLL multiplier */
#pragma config FPLLODIV = DIV_1          /* System PLL Output Clock Divider */
#pragma config FPBDIV = DIV_2            /* Peripheral Clock Divisor */
#endif
#pragma config FNOSC = FRCPLL            /* Fast RC Osc with PLL */
#pragma config FSOSCEN = OFF             /* Disable secondary oscillator */
#pragma config IESO = OFF                /* Disable internal/external switch-over */
#pragma config POSCMOD = OFF             /* Primary oscillator disabled */
#pragma config OSCIOFNC = OFF            /* CLKO Output Signal Active on the OSCO Pin disabled */
#pragma config FCKSM = CSDCMD            /* Clock switch disabled, FSCM disabled */
#pragma config FWDTEN = OFF              /* Disable watchdog timer */
#pragma config JTAGEN = OFF              /* Switch off JTAG */
#pragma config ICESEL = ICS_PGx1         /* Use PGEC1/PGED1 for programming/debugging */
#pragma config PWP = OFF                 /* Program Flash Write Protect disabled */
#pragma config BWP = OFF                 /* Boot Flash Write Protect bit disabled */
#pragma config CP = ON                   /* Code Protect bit enabled */
// #pragma config DEBUG = OFF               /* Background Debugger disabled */
#pragma config DEBUG = 3
  INTEnableSystemMultiVectoredInt();  /* Enable multi vectored interrupts */
  INTEnableInterrupts();  /* Enable interrupts */
The last two functions to enable the interrupts I copied from the Microchip libs.
MZ is still too buggy, even the latest versions. For example, the uarts can't recover from a buffer overrun.
Offline Howardlong
« Reply #20 on: January 16, 2017, 07:57:45 pm »
There are two features on the MZ EF that make it tower over the MX, that of USB HS and the integrated multiple simultaneous sampling high speed ADCs.
I agree though that the errata rap sheet is something that Microchip should be ashamed of. Even findamentals like I2C and the crystal oscillator have significant shortcomings. The oscillator has been broken since the MZ EC, an even more woeful disaster, where they didn't acknowledge that its HS ADC was almost completely broken until about a year after it was released.
Offline hli
« Reply #21 on: January 16, 2017, 08:10:44 pm »
Second that. Being able to trigger DMA with any signal you can come in hardware (even being able to create new hardware signals in custom logic), and then getting a DMA transfer signal in hardware which you can use to do any other things in hardware is really powerful. And IMHO the API for it is easy to understand, and Cypress has some really good application notes. They even explain the tricky things (such as self-modifying DMA - having one of the DMA channels modifying another DMA channels registers is quite powerful, e.g. to be able to use multiple target buffers without any software intervention).
« Reply #22 on: January 16, 2017, 08:13:18 pm »
Do you happen to know if Microchip have a working solution for reading USB memory sticks at High Speed on the MZ ?
Offline Howardlong
« Reply #23 on: January 16, 2017, 08:29:39 pm »
No. Not sure if this helps, but to implement and take advantage of higher speeds as an HS device (rather than a host) I had to implement multiple simultaneous endpoints. I don't have any experience of running the USB peripheral as host.
Offline Howardlong
« Reply #24 on: January 16, 2017, 09:50:07 pm »
Update: I received a couple of PIC32MZ EF Curiosity boards last week, so I thought I'd try them out as a USB host for a thumb drive. I just ran a modified "PIC32MZ EF Curiosity USB MSD Host" (msd_basic) from here
My modified version is here.
The modification was to change it to write a 256MB file, by writing 4096 bytes 65536 times.
It managed this in 28 seconds, so 9.6MB/s, or 77Mb/s. So it's definitely HS, but not stunning.
The drive I used was a Sandisk Extreme USB 3.0 thumb drive which was specifically chosen for its high R/W speeds. For comparison, from a Windows box on USB 3.0, the same file writes in about 3 seconds. From a PC's USB 2.0 connection it's 10 seconds.
Update: I have another version of that project that reads the file. For some reason, it's slower, taking 46s to read the 256MB file, 5.8MB/s or 46Mbps.
« Last Edit: January 16, 2017, 10:15:19 pm by Howardlong »
