Author Topic: Which PIC?  (Read 3968 times)
Offline redekTopic starter
Which PIC?
« on: September 16, 2011, 06:49:52 am »
I'm going to start my first real electronics project, circuit design and programming.  I've assembled a few kits, but I want to make a nixie clock.  I have decided to get a Pickit 3, and have no idea which pic to use.  If someone could point out a chip that I can use for various projects for the next few years I would appreciate it.  I've hand soldered surface mounted microcontrollers in the past, so the package isn't a big issue.
Thanks,
Derek
« Last Edit: September 16, 2011, 06:52:43 am by redek »
Offline PeterG
Re: Which PIC?
« Reply #1 on: September 16, 2011, 09:13:35 am »
I would go with any one if the 18F PIC chips.
Regards
Testing one two three...
Offline ChrisKiwi
Re: Which PIC?
« Reply #2 on: September 16, 2011, 12:14:40 pm »
If your planning on coding in C then you might like to check out Shane Tolmie's site http://www.microchipc.com/ which has lots of examples of coding PIC's in C
Offline jakeypoo
Re: Which PIC?
« Reply #3 on: September 18, 2011, 04:43:09 am »
Offline bruce273
Re: Which PIC?
« Reply #4 on: September 28, 2011, 06:43:20 pm »
18f are certainly better but if you want something really simple theres also the 16f series
