I have a question in my mind which I am trying to understand practically, ESP32 is a device that has inbuilt MCU and Wifi chip
If I am going to make 10,000 devices and sell them to the public but don't want to use ESP because it's too costly. I want to make my own board that has an inbuilt MCU and Wifi chip, Is it possible?
Theoretically, I know the Wifi chip can be connected to a microcontroller. Can the new device be made at a cost less than ESP?
Special Note - Question asked only to clear doubt it has nothing to do with real-world project
At 10k units I think you will struggle to beat ESP32 prices unless you find a similar MCU with all the toys you need at a cheaper price. If you need to combine multiple components to make it happen, I think you will waste any potential gains in development.
I don't really get it.
ESP32 SoCs are CHEAP. How are you going to find cheaper? Please give us hints!
Or are you maybe talking about ESP32-based BOARDS instead of just the chip? ESP32 can be bought as a chip and you can absolutely make your own board with it.
THe ESP32-S2 is about $1. Call me when you can find a solution, be it in a single SoC or as two chips, as cheap as that.
Check
LCSCIf you want to avoid the external parts for the esp32, you can get esp32 modules for as little as $2 at 1K quantities:
Differences between 10 and 1K are not huge, so you can make a smaller order for testing purposes.
ESP32-C3-MINI-1-N4$1.94
ESP32-S32Mb$2.28
ESP32-S2-WROOM-I-4M$2.36
ESP32-SL$2.44
ESP is already quite cheap.
Do you really need Wifi, or do you need any wireless connection between boards?
20 years ago Infrared (IRDA) was a popular and cheap communication option.
fchk
Yeah. As I said, I suspect the OP is talking either about ESP32-based dev boards, or at least ESP32-based modules (like the WROOM ones) - which are between $2 and $3. Still very cheap, but since the OP was considering directly using ICs (as I got it?), then they could as well make their own board with an ESP32 SoC (you can find them as low as $1 or so), but then they'd have to properly route it, then use a shield and take all measures to ensure it has any chance of passing conformance tests... yeah. But if they are ready and skilled to do that, why not.
There may be reasons not to use the ESP32 line for this, but cost is certainly not one.
Is there any software for the ESP32 other than
https://github.com/espressif/esp-at? That is basically a bunch of binaries with a little open source stuff to collect them into the ESP-AT firmware. I looked at modifying it to use the SPI interface instead of a serial port, and found this wasn't really feasible as the behavior is really nailed down in the .a binaries.
Also, the technical reference manual (
http://espressif.com/sites/default/files/documentation/esp32_technical_reference_manual_en.pdf) doesn't document the radio. But it's a very competent little SoC otherwise, and I like the idea of the PID controller for interrupts and context switch assist in an SMP setup. (Although I'd just assign one core to interrupts and real-time stuff, the application core can do everything else.)
The ULP coproc is a very cool idea.
The peripherals look very easy to use.
But the lack of more comprehensive documentation and example code in source form means I'd be a little hesitant to get too vested in it.
ESP8266, 94ยขBut supposedly the ESP8266 is even more quirky than the ESP32. If that eats into development time it may not be worth the cost saving at 10,000 units.
Espressif Is directly supported by the Chinese communist party. They are subsidized to to be cheap and successful. You are not going to beat them at 10k units. Not in any sort of apples to apples.
There are reasons to avoid ESP, but upfront cost is definitely not one of them.
Would love to hear any reasons not to use ESP (maybe PM me).
You probably know most of them already. Off the top of my head:
- Energy consumption!
- Poor performance for the speed/power
- Limited GPIOs
- Barely functional ADC
- Quirky peripherals
- No EEPROM
- Binary blobs for things that have no excuse to use them, e.g. DHCP
- Binaries can easily grow to > 1 MiB
But we still use them because of their features, ease of development, and low cost.
Well, only if battery-powered. Otherwise, it's the least of your worries.
Anyone tried SPI interface for ESP-AT? Problems?
https://docs.espressif.com/projects/esp-at/en/latest/Compile_and_Develop/How_to_implement_SPI_AT.html
I looked at it, but I wanted a protocol a bit simpler and more efficient. Like for example, hand it a complete set of configuration as a binary structure, in a single command, rather than dally around with a bazillion AT commands that effectively require sprintf or other text conversion. Not only that, but require a lot of painful parsing to process the responses. I'm willing to take apart their implementation and rewrite what's needed, but too much of it is proprietary closed source.
AT commands are (were?) a popular "protocol" for controlling communication devices, and, while it makes it easy to test things interactively (for instance in a terminal), it's a royal and inefficient pain to use it .
