I created a simple programme to view the registers in a PIC16F877A with each of the PORTB pins connected to a LED:
#define _XTAL_FREQ 12000000
#include <xc.h>
#pragma config FOSC = HS
#pragma config WDTE = ON
#pragma config PWRTE = OFF
#pragma config BOREN = ON
#pragma config LVP = OFF
#pragma config CPD = OFF
#pragma config WRT = OFF
#pragma config CP = OFF
int x = 1;
void main()
TRISB = 0;
x = x - 1;
PORTB = STATUS;
while(1) {}
I noted that bit4 (TO) was initially set then went low as the WDT came in, as expected. Then I noticed that bit2 (zero bit) was set. The relevant bits of STATUS register are:
bit 4 TO: Time-out bit
1 = After power-up, CLRWDT instruction or SLEEP instruction
0 = A WDT time-out occurred
bit 3 PD: Power-down bit
1 = After power-up or by the CLRWDT instruction
0 = By execution of the SLEEP instruction
bit 2 Z: Zero bit
1 = The result of an arithmetic or logic operation is zero
0 = The result of an arithmetic or logic operation is not zero
bit 1 DC: Digit carry/borrow bit
1 = A carry-out from the 4th low order bit of the result occurred
0 = No carry-out from the 4th low order bit of the result
bit 0 C: Carry/borrow bit
So, I added a simple line of arithmetic with x = 1 to begin and got the following, surprising (to me), results [Z, DC, C]:
x = x - 1 the answer is 0 but STATUS reg says [0, 0, 0]
x = x + 10 the answer is 11 but STATUS reg says [1, 0, 0]
x = x - 10 the answer is -9 but STATUS reg says [1, 1, 1]
Therefore, this is the exact opposite from what I would expect. If the arthimetic operation produces a zero then Z should be set!
Any help with where I went wrong this time please?
Cheers.
The status register bits are as described in the relevant datasheet after each machine code instruction.
There is no requirement for your C compiler to set the STATUS register to any particular state.
A C code instruction is a very different thing to a machine code instruction
EDIT: minor correction C to STATUS
Oh! Right, thank you very much.
You will need to look at the assembly listing of your program, that will show you the list of machine instructions each line of C has been translated to. Usually this is generated into a separate file in your project directory, and there may be a compiler option to enable/disable it.
As hexreader suggests, you will find there are usually several of these instructions per line of C code, and likely one or more of these instructions is modifying the status bits before you are able to output them.
You could possibly use inline assembly to overcome this.
