Author Topic: Zynq 7000 reboot from SD card  (Read 2140 times)
Offline Jer0enTopic starter
« on: November 24, 2020, 11:01:20 am »
I have a Zynq 7000 processor running a bare metal application. It boots from QSPI flash. I'm looking for a way to reboot it from SD card under software control, irrespective of the values of the boot-mode pins. Is there a way to do that, for example by jumping directly into the the boot ROM code?
Thanks in advance
Offline RoadRunner
Re: Zynq 7000 reboot from SD card
« Reply #1 on: November 24, 2020, 02:25:31 pm »
If you looking to load kernel and dtb which is present on SD card then modifying Uboot Environment and pointing to load Kernel from SDCard will Solve the issue.
« Reply #2 on: November 25, 2020, 07:34:38 am »
I'm not entirely sure what you mean -- if you're saying that I can use an appriopriately configured UBoot to boot from SD card instead of from flash then that's not a solution. Initially booting from flash is a given, but there are circumstances under which I want to perform a reboot into the image on the SD card.
