Author Topic: Error message "Your session timed out while posting."  (Read 7169 times)
Offline floobydustTopic starter
« on: June 14, 2023, 08:32:22 pm »
I can't reply to thread https://www.eevblog.com/forum/projects/digital-power-meter-mod-for-voltages-down-to-zero/
Keep getting error message: "The following error or errors occurred while posting this message: Your session timed out while posting. Please try to re-submit your message."
My reply has three URL's, and also deleting the text reference did not change anything. Server seems sluggish today.
"Also discussed over here:
[url=https://www.eevblog.com/forum/beginners/power-meter-for-variac]https://www.eevblog.com/forum/beginners/power-meter-for-variac[/url]
[url=https://www.eevblog.com/forum/projects/digital-mini-0-56-inch-ac-voltage-panel-replacement-meter-for-variac]https://www.eevblog.com/forum/projects/digital-mini-0-56-inch-ac-voltage-panel-replacement-meter-for-variac[/url]
[url=https://www.eevblog.com/forum/projects/using-a-fixed-range-ac-voltmeter-with-variable-input]https://www.eevblog.com/forum/projects/using-a-fixed-range-ac-voltmeter-with-variable-input[/url]
Second attempt:
[url]https://www.eevblog.com/forum/beginners/power-meter-for-variac[/url]
[url]https://www.eevblog.com/forum/projects/digital-mini-0-56-inch-ac-voltage-panel-replacement-meter-for-variac[/url]
[url]https://www.eevblog.com/forum/projects/using-a-fixed-range-ac-voltmeter-with-variable-input[/url]
Offline MMMarco
  • Hobbyist. ⚠️ Opinionated
Re: Error message "Your session timed out while posting."
« Reply #1 on: June 14, 2023, 09:37:53 pm »
Can confirm getting the same error message.
27 year old Software Engineer (mostly JavaScript) from Switzerland with a taste for low level stuff like electronics 😊
