Author Topic: Getting a lot of "502 Bad Gateway" errors  (Read 11303 times)
Offline Analog KidTopic starter
« on: September 09, 2026, 11:26:52 pm »
Title says it all. This has been happening the last 2 days.
Yesterday I couldn't access the site for a couple hours.
Is this on your end or my end?
Offline Stray Electron
Re: Getting a lot of "502 Bad Gateway" errors
« Reply #1 on: September 09, 2026, 11:35:08 pm »
  I've been getting them today and it wouldn't post a reply that I made a few hours ago.
Offline HwAoRrDk
« Reply #2 on: September 09, 2026, 11:36:15 pm »
Same. I assume the servers are getting blasted by AI bot scrapers or something like that. :(
Offline themadhippy
« Reply #3 on: September 09, 2026, 11:38:06 pm »
similar here, not had any prolonged outage,but almost every other page gives a 502 bad gateway
Offline tautech
« Reply #4 on: September 09, 2026, 11:39:12 pm »
+ 1
EEVblog has been painfully slow for a few weeks and I suspect starting when Dave changed the forum ads.  :-//
But there's also another story:
331297 Guests, 112 Users
Near record guests #'s.......Bots ?
Is it time for gnif to be let loose to tidy things up some ?
Avid Rabid Hobbyist
Online Fraser
« Reply #5 on: September 09, 2026, 11:44:29 pm »
I have had the same issue for a couple of days.
I looked at the forum guest stats tonight and it said today was the highest number seen on this forum. It is almost like a DoS attack, overloading the servers. If it is AI scrapers, the situation can only get worse unless Dave knows how to block them.
Fraser
« Last Edit: September 10, 2026, 12:49:55 am by Fraser »
Offline CatalinaWOW
« Reply #6 on: September 09, 2026, 11:49:19 pm »
This did not start for me until today, but now well over half the times I click on anything on the site I get a bad gateway error.  Including two tries at posting this message.  Maybe the timing and my location will provide some clues for someone.
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #7 on: September 10, 2026, 12:37:17 am »
Same thing for me for a couple of days now ...  :palm:
« Reply #8 on: September 10, 2026, 12:57:58 am »
Now it's literally every other click on this site gives me that error.
The following users thanked this post: JustSquareEnough
Offline thm_w
  • Non-expert
« Reply #9 on: September 10, 2026, 01:13:09 am »
Dropping now: " 218236 Guests, 66 Users "
I'm impressed that the server can handle that many views. We used to be able to see what thread they were looking at but no more.
Offline PCB.Wiz
« Reply #10 on: September 10, 2026, 01:17:27 am »
Yup, seems a bit variable.
Sometimes a refresh will spin-a-while then work, other times an instant 502 reappears.
Offline EEVblog
« Reply #11 on: September 10, 2026, 01:19:41 am »
331k guest requests will do it alright. Nothing to do with the ads.
Offline EEVblog
« Reply #12 on: September 10, 2026, 01:23:05 am »
Getting hammered!
« Reply #13 on: September 10, 2026, 01:28:30 am »
Please pardon my ignorance of how that Intertube stuff works, but what's the relationship between all those "guests" (=bots?) and the 502 errors?
Offline EEVblog
« Reply #14 on: September 10, 2026, 01:33:41 am »
Baidu bots
« Reply #15 on: September 10, 2026, 01:38:53 am »
Can they be blocked?
If so, what would the consequences of that be?
Offline thm_w
  • Non-expert
« Reply #16 on: September 10, 2026, 01:58:55 am »
At a certain point you block IP ranges of legitimate users and they can't use the forum:
https://www.eevblog.com/forum/chat/baidu-is-trawling-the-eevblog-forum/msg6316476/#msg6316476
Offline EEVblog
« Reply #17 on: September 10, 2026, 03:18:53 am »
Update: the culprit is Shanghai263 again, and our anti-bot service was attacked and crashed. The infrastructure has a fail-safe configuration so that if this occurs it doesn't block the entire site.
Looks to be back up now.
The following users thanked this post: thm_w, SiliconWizard
Offline EEVblog
« Reply #18 on: September 10, 2026, 03:20:02 am »
Correct, we have extensive block lists and have unfortunately accidently blocked legit users before.
Offline fourfathom
« Reply #19 on: September 10, 2026, 05:44:20 am »
Still getting regular 502 errors, so I guess it's not solved yet.
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
Offline iMo
  • Country: li
« Reply #20 on: September 10, 2026, 06:55:53 am »
..mee too..
Offline chilternview
« Reply #21 on: September 10, 2026, 07:06:36 am »
Still getting the 502 errors, and the forum is very slow.
If it ain't broke, don't fix it!
Offline gnif
  • Views and opinions are my own
« Reply #22 on: September 10, 2026, 07:47:55 am »
Still working on it, getting close now.
We do not block IPs at all, we used to. Now we force bad IPs/subnets through a captcha validation, otherwise we end up blocking VPN users completely.
The following users thanked this post: EEVblog, thm_w, Kean, tooki
Offline CatalinaWOW
« Reply #23 on: September 10, 2026, 07:13:51 pm »
Any idea on how you got on someone's shit list?
« Reply #24 on: September 10, 2026, 08:38:45 pm »
Question:
Would it help to require all users to solve a CloudFlare captcha (like the simplest "click on the box" one) before first logging on or accessing the site?
I wouldn't mind having to do this at all if it helped reduce the bot attacks.
