I got this captcha a couple of times now, but not nearly as often as the combined captchas yesterday.
Don't get me wrong. I understand the neccessity and i don't really mind that single captcha.
But it *is* changed behaviour.
Yes, I am regularly seeing the CrowdSec captcha. Note that this is very much not the same as CrowdStrike!
I presume it is happening because with CloudFlare enabled the requests are reverse proxied, so the IP seen by the EEVblog servers is not the originating IP but one from CF.
As mentioned in another post, there are configuration settings that can be made to better handle this and restore the originating IP.
https://www.eevblog.com/forum/news/getting-a-lot-of-502-bad-gateway-errors/msg6357054/#msg6357054Edit: Yes, in fact I can see the IP logged against this post is not my companies public IP address, but one associated with CF.
