Author Topic: Getting a lot of "502 Bad Gateway" errors  (Read 9281 times)
endless∞, xrunner and 22 Guests are viewing this topic.
Offline gnif
  • Views and opinions are my own
Re: Getting a lot of "502 Bad Gateway" errors
« Reply #150 on: September 15, 2026, 07:14:38 am »
Yes, but we have technical reasons why we need to keep it this way. Lets discuss this via email.
This is a normal issue; you set up a bypass in CF.
The real server should be firewalled to accept only CF traffic, plus obviously any other stuff you need internally.
Yes it's a normal issue, and we have protections in place. This is not something we will discuss publicly as it pertains to server security
Edit: at this time using CF directly I would consider a "trial", the last time we used it, CF failed to identify a massive attack against our infrastructure and left us with no tools to filter it. This was a few years ago, here is hoping that the situation has improved.
Edit 2: This is something that smaller site operators seem to fail to consider... if CF doesn't filter it, how do you then filter an attack coming from "trusted" IPs? You now  have to filter it at the protocol/http layer, firewalls become useless. You're now needing to handle SSL sessions, and then inspect headers to get the originating IP and then make a decision. Your ingress HTTP servers have to work far harder to block known abusive IP ranges. Enabling "Under Attack Mode" is a last resort, and really is just a stopgap workaround, not a fix.
« Last Edit: September 15, 2026, 07:23:03 am by gnif »
The following users thanked this post: EEVblog, Kean
Offline peter-h
« Reply #151 on: September 15, 2026, 07:47:34 am »
CF is supposed to automatically block huge DDOS attacks (gigabit volume). That was the original reason for CF. But - as we found too - it does not block "small" attacks which are enough to trash your site (and ours). For those you have to use "proof of work" like Precursor or, if your server bw is enough, set up Anubis on the server.
Proof of work serving is low server load but very high client load, which is why it works.
I spent months blocking IP ranges and now have almost 1000 blocked, like e.g. all of Hetzner, Digital Ocean, etc. That is a good idea anyway (some will moan because they are on VPNs terminating on these farms). I also block Russia and China (which I know you don't want to). Historically we got a lot of attacks from some guys in Germany... hence the German server farms. But this last attack, a huge rented residential botnet, 50% US and 50% 3rd World, no chance of blocking that.
Offline gnif
« Reply #152 on: September 15, 2026, 07:55:45 am »
Yes, we have a solution for that already but it was not designed to work with CF. I can adjust it if we need to and put it back in place. Again though the specifics of the implementation are not going to be shared for operational security reasons.
Our block lists for DC owned subnets span hundreds of thousands of IPs, and are automatically generated based on external sources of information daily (Attached non-exhaustive sample). We do not block them, but rather force a proof of work.
« Last Edit: September 15, 2026, 08:01:05 am by gnif »
Offline peter-h
« Reply #153 on: September 15, 2026, 09:52:12 am »
What is "DC owned"?
It sounds like you may not need CF except
- it should still block *huge* DDOS attacks
- it gives you a free https certificate with reliable renewal
- it does cache probably 1/2 your data volume (but probably that is not an issue these days)
I fully understand not talking about some things. I don't either :)
If CF kick us off Precursor (sounds like we got in under the wire) then I will put Anubis on our server. A friend who knows it says it's easy.
IP range blocking is no more than icing on the cake. It blocks mostly individuals with a grudge (all forums get those). But it is probably good practice. OTOH I pissed off some people on our forum by accidentally blocking their IP. It does tend to block a lot of targeted attacks; a bigger issue for you since your code is open source.
Offline gnif
« Reply #154 on: September 15, 2026, 10:00:46 am »
DC = Data center. These are IP ranges that are in use by data centres, cloud providers, etc. Ie, Digital Ocean, OVH, Hertzner, HostPapa, to name a few.
Our ISP already blocks huge DDOS style attacks, we don't need CF for this.
Cert renewal is not an issue, we already have a robust free solution.
Caching doesn't much help us as the pages SMF serve are generally non-cachable (it's from a pre-caching era, dynamic content on every page load)
We had successfully filtered everything we needed to until a few weeks ago when these proxy attacks started. The traffic comes from people that have installed free games/apps on their phones or browser extensions that allow their PC to become part of a proxy bot net. The bots then proxy it via their device, a single request every few days, but there are enough installations out there that it causes a flood of incoming requests that can't be identified from real users. It's not a per-ip flood, there is no pattern to search for, and the requests are coming from regular user's networks (DSL/Cellular, etc).
« Last Edit: September 15, 2026, 10:04:15 am by gnif »
Offline EEVblog
« Reply #155 on: September 15, 2026, 12:50:38 pm »
I'm curious to know why Cloudflare fixed it in this case?
Was it a case of "we scared them away for now" with the Under Attack mode and forcing the authentication?
Offline EEVblog
« Reply #156 on: September 15, 2026, 01:00:01 pm »
This option sounds like fun  >:D
Offline gnif
« Reply #157 on: September 15, 2026, 01:00:27 pm »
under attack never scared them away, it likely just caused them to move onto different servers in their target list until they noticed we were available again.
What I think has confused matters here is your view of the guest count, because this was turned on before I was ready for it, the servers (including SMF) saw all traffic originating from the CloudFlare proxy IPs, not the actual end user's IP, causing the guests online count to be very low as it logs per IP.
The following users thanked this post: PA0PBZ, Kean, CatalinaWOW
Offline EEVblog
« Reply #158 on: September 15, 2026, 01:06:06 pm »
That's what I figured.
All I know is that the site went from not working at all to instantly working once I switched cloudflare online, even before I switched Under Attack mode on. I'm not really concerned about the SMF Guest count provided that it doesn't impact the performance significantly or bring down the site like it just did, it's just a curiosity really.
Offline gnif
« Reply #159 on: September 15, 2026, 01:38:02 pm »
The guest count can no longer bring the site down, I re-developed this the last time it did and implemented safeguards.
The following users thanked this post: EEVblog, 2N3055
Offline madires
  • A qualified hobbyist ;)
« Reply #160 on: September 15, 2026, 03:19:04 pm »
I've stumbled across a new problem. Since this morning I got "Database Error" when trying to access the forum. After a bit of testing I found out that it's related to the AAAA DNS records (IPv6) for www.eevblog.com. After forcing IPv4 by adding a local A record (IPv4) I'm able the access the forum again. If possible it would great if Dave or gnif could remove the AAAA records. My guess is that other users with IPv6 have the same issue.
The following users thanked this post: EEVblog, TUMEMBER
Offline KungFuJosh
  • TEAS is real.
« Reply #161 on: September 15, 2026, 03:21:12 pm »
Because we have changed to using CF entirely I have had to disable/remove the CrowdSec layer we had implemented, these to systems are not compatible.
Unfortunately the result is many bots that I was already properly filtering is now relying on CF to filter, as a result of which I'd expect to see numbers rise again.
According to CrowdSec, they can be used together. You do need to change how some things are done though. From a CrowdSec employee on reddit here: https://www.reddit.com/r/sysadmin/comments/1f33alo/protecting_webapp_using_cloudflare_or_crowdsec/
CrowdSec and Cloudflare can work together to provide you CDN level protection and Server level protection (one caveat here is if you want to block IP's then you cant use a firewall remediation as it will only see Cloudflare as the originating IP but you can use web server remediation)
That's okay anyway, since blocking IPs directly is mostly useless with bots.
Thanks,
Josh
Best Continuity Tester Ever
Offline gnif
« Reply #162 on: September 15, 2026, 09:28:05 pm »
Thanks,
Josh
Yes, they can be used together but as it stands right now with our current configuration they are not going to and requires additional work.
Regarding removal of AAAA records, this is not a viable solution, CloudFlare are proxying IPv6 traffic and when we pickup the IP it's clearly being mishandled by SMF. Prior we never saw these because the provider we use doesn't support IPv6. I am investigating a fix.
The following users thanked this post: EEVblog, madires, TUMEMBER, KungFuJosh
Offline gnif
« Reply #163 on: September 15, 2026, 11:03:04 pm »
IPv6 issue has been fixed.
The following users thanked this post: madires, TUMEMBER
Offline Monkeh
« Reply #164 on: September 15, 2026, 11:28:30 pm »
Not in any way attacking your choice of provider, but every time I see a line like that, I don't know if I should respond with :palm: or  |O. It's 2026!
Offline Zucca
  • EE meid in Itali
« Reply #165 on: September 16, 2026, 01:34:41 am »
The friction and sloppiness in the transition from ipv4 to ipv6 is hard to compare to anything else.
Maybe from querty to Dvorak keyboard?
Thanks GNIF for keeping the boat afloat, but you should not have such problem today. I agree with Monek.
Offline gnif
« Reply #166 on: September 16, 2026, 08:08:07 am »
It seems I was wrong our provider does now have IPv6 support, however now we are proxied via CF though it makes little sense to request it as it just broadens our attack surface.
Offline TUMEMBER
« Reply #167 on: September 16, 2026, 10:54:20 am »
True. Yesterday was a total nightmare. I did so much clicking—I even dug up the notebook where I’d physically written down my forum password—because that "missing from database" error message was really getting my blood boiling... to put it mildly, without resorting to the Latin word *curva*.
W życiu nie ma nic za darmo, są tylko różne formy płatności.
Wciąż płacimy okruchami własnego czasu.
Offline madires
« Reply #168 on: September 16, 2026, 11:48:25 am »
Thanks for fixing the IPv6 issue!
Would it? I'm running my servers dual-stack-ed for a long time and I see much less malicious traffic from IPv6 addresses than IPv4. And for targeted attacks it doesn't matter if they happen over v4 or v6. A nice side effect is that ACLs for IPv6 are shorter since you usually deal with short prefixes instead of a bunch of non-contiguous longer prefixes.
Offline factory
« Reply #169 on: September 16, 2026, 08:34:51 pm »
After two days with less than 1k users online, the count is now creeping back up, currently over 175k, mostly guests bots.
Offline Xena E
« Reply #170 on: September 16, 2026, 09:15:26 pm »
Yeah, and the bad gateway reports too:-
« Reply #171 on: September 16, 2026, 09:29:53 pm »
(Attachment Link)
Yeah I got that too yesterday but at that time gnif was busy tweaking things behind the scenes but 10 minutes later everything was back to normal.  :phew:
Avid Rabid Hobbyist
Offline EEVblog
« Reply #172 on: September 18, 2026, 12:36:18 pm »
Happened again tonight 8:30pm Sydney time. Confirmed many people on X, but not everyone. Now 10:30pm and I just disabled the Apple AI bot as it was by far the most traffic (1449 crawlers in 60min) and suddenly I could access the forum again.
« Last Edit: September 18, 2026, 12:45:52 pm by EEVblog »
The following users thanked this post: Stray Electron
Offline TUMEMBER
« Reply #173 on: September 18, 2026, 04:44:10 pm »
It happened again today; I don't know what time it was in Sydney.
Offline factory
« Reply #174 on: September 18, 2026, 04:52:01 pm »
Site is getting very slow to load again, had the bad gateway error this morning too, now nearly 6pm here and 240k guests bots, need to boot the AI scraper crap off the forum, they must have cost a lot for extra server capacity, with no funding from them, then the bastards charge to use their stolen data sets.
The following users thanked this post: TUMEMBER
