Hello Dave , can you please ask Extech to send you this meter for review??
and if you will get it can you compare it with the Fluke and the Gossen Mertowatt.
spec:
*Full range multimeter functions with
0.02% basic DCV accuracy and up to 100kHz True RMS ACV bandwidth
50,000 count (500,000 for DCV and Hz) backlit LCD display with bargraph
*Special True RMS combination AC+DC function for measurements of rectified AC (non-symmetrical) voltage & current waveforms
*Filtered frequency function with adjustable trigger levels for variable speed motor drives and high voltage applications
*AC/DC current to 10A with
0.01µA resolution*4 to 20mA, displayed as 0-100% for process current measurements
*Capacitance, Frequency, Resistance, Continuity, Duty cycle and Diode tests with 100V input protection on all functions
Dual input Temperature function -58 to 1832°F (-50 to 1000°C ) with T1, T2 and T1-T2 display in °F or °C
*High resolution to 1µV, 0.0001Hz, 0.01Ohm, 0.01µA and 0.1°*Max/Min recording with autoranging, Auto Power off, Relative & Hold, Peak function captures transient pulses
*Optional Windows® compatible PC communication software and optically isolated cable
*Complete with test leads, Type K thermocouple probe, protective holster with stand and 9V battery
link to the product page
http://www.extech.com/instruments/product.asp?catid=48&prodid=284Thanks
Ido
