Author Topic: Started By column should be left-justified  (Read 8548 times)
Offline MikeKTopic starter
« on: July 08, 2023, 04:07:36 pm »
In forum post listings, most of the columns are left-justified...which makes them easily readable.  But the Started By column is center-justified, which makes it difficult to read.  Center-justified things are often a poor choice, because the eye has to keep jumping around to find the start of the item in the next row instead of just moving down the page.  This applies to the Replies/Views column, too...I think that should be left-justified.
Offline thm_w
  • Non-expert
Re: Started By column should be left-justified
« Reply #1 on: July 11, 2023, 09:11:14 pm »
Disagree
« Reply #2 on: July 12, 2023, 01:04:06 am »
Left-justified is easier to read.  A book that had a jagged left edge would be a nightmare to read.
Havard agrees:
https://accessibility.huit.harvard.edu/design-readability
Use left-aligned text. A consistent left margin makes reading easier.
Offline Nusa
« Reply #3 on: July 12, 2023, 05:23:19 am »
I think you're talking about the SMF forum software rather than stuff Dave has control over. You're likely in the wrong place entirely if you want someone relevant to hear your opinion.
The following users thanked this post: james_s
Offline IanB
« Reply #4 on: July 12, 2023, 05:42:33 am »
Except that you justify text when laying out paragraphs. You align entries in table columns.
I find the center alignment of the entries in the columns is aesthetically pleasing, and I have no problem reading them that way.
So add for me a second vote of disagreement. I think the SMF software has it fine the way it is.
Offline james_s
« Reply #5 on: July 12, 2023, 06:05:22 am »
I think center justified works just fine for this particular application, and I really don't think it would make any difference on ease of reading, it's just a person's handle anyway.  Is this even something any of the admins could control if they wanted to? I would assume it's just the way the forum software works.
Offline thm_w
  • Non-expert
« Reply #6 on: July 12, 2023, 09:27:07 pm »
If its really an issue for you, you can figure out how to tweak it for yourself, eg: https://stackoverflow.com/questions/9168697/how-can-i-change-text-align-with-greasemonkey
