Author Topic: Don't Stay Under Trees During Thunderstorms  (Read 1600 times)
Offline hesam.moshiriTopic starter
    • MyVanitar
The following users thanked this post: james_s
Offline james_s
Re: Don't Stay Under Trees During Thunderstorms
« Reply #1 on: August 11, 2022, 10:12:25 pm »
This is common advice, I remember being told when I was a little kid if a thunderstorm rolls in to get away from any trees or other tall objects and get indoors if possible. Quite an impressive picture.
Offline jpanhalt
« Reply #2 on: August 11, 2022, 11:16:03 pm »
Lightning is amazing and unpredictable for what it does.  A few weeks ago, lightning apparently hit a medium size tree (10" trunk) about 50 ft from my home.  It destroyed the wall wart supply to my router and only the part of the router that allowed connection to the modem.  I am on fiber optic, but my underground mains supply was nearby.   My PC would connect to the router just fine.  That was a perplexing problem.  A few days later, I saw some long splinters of wood in the yard.  I didn't immediately associate the two events, but figured the tree was simply dead from some other reason.  After cutting it down, the top 15 to 20 feet were normal.  From there on down, the bark was separated from the rest of the trunk.  It just peeled off like the shell of a hard-boiled egg.
My home is in a small clearing in the middle of a forest. It was just that tree's bad luck. (And my good luck.)  Some people survive lightning strikes, many don't.  I don't mess with lightning if I can possibly avoid it.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: August 11, 2022, 11:40:39 pm »
Apparently another risk is that the sap can explode, sending bark shrapnel flying.
Day Job: Mostly LEDs
Offline james_s
« Reply #4 on: August 11, 2022, 11:57:50 pm »
I thought it was mostly the water in the tree that would flash vaporize and cause the tree to explode. I suppose sap is mostly water.
Offline jpanhalt
« Reply #5 on: August 12, 2022, 12:16:08 am »
That's what I assumed loosened the bark.  Some of the splinters from higher up were 15' long. There are lots of trees here.  This one caught my attention as it was so close to the house -- right off my front porch.  It also leaned toward the house, so felling it was a bit tricky.  Fortunately, it went right where I wanted it to go.
