Author Topic: Automatic 10-ports SCART switch review  (Read 1146 times)
Online VEGETATopic starter
  • Country: jo
  • I am the cult of personality
    • Thundertronics
« on: August 13, 2022, 09:38:20 pm »
Hello
there is the review:
https://youtu.be/3oDhDZKFzc0
I hope people benefit from this as I did, I really recommend this one as shown in the technical review.
get it here: https://www.aliexpress.com/item/1005004300273099.html -> it is available from other sources as well.
please share the video to everyone... we need more testers of new retro gaming devices which are affordable.
Offline madires
  • A qualified hobbyist ;)
Re: Automatic 10-ports SCART switch review
« Reply #1 on: August 24, 2022, 01:46:20 pm »
Over here we're glad that SCART is mostly gone. No more trouble with fiddly SCART plugs and their flimsy contacts. They could be better if the design would incorporate a retaining clip or screws like D-Sub.
Offline david77
« Reply #2 on: August 24, 2022, 02:28:01 pm »
SCART...good riddance. The crappiest consumer plug design ever. The US got it right: Just use RCA plugs  :-+
  • Country: jo
    • Thundertronics
« Reply #3 on: August 25, 2022, 08:21:49 am »
The retro gaming community agrees with you in terms of hating SCART connector for being bulky and so on. However, it is kinda necessity now since all retro gaming community use it for a long time and generally for RGB based system it is the only option.
VGA requires H and V separate syncs while SCART allows Csync, composite sync, or sync on luma on its pin 20 which is what most people and their equipment use.
yes you can use a DSub connector but the equipment won't be compatible and the whole retro gaming infrastructure won't as well, so scart is the way to go.
using a scart switch like this one reliefs you from keep plugging and unplugging your cables. you can set them up once and will be ok. I showed in the video that this switch is reliable and has automatic switching where I just power on my console and it gets to the screen. I paired it with other stuff like RGB to component converter and so on.
As for RCA, they are reliable and also BNC but for rgb you would need 4 RCA cables at least: R G B and Csync, plus 2 for audio would result in 6! no system at all use this standard for RGB.. well PVMs use a similar setup via BNC but these are not as wide spread as normal CRTs and even modern TVs.
for me, I prefer something like a DIN connector. it is really small and reliable with enough connectors for everything.
you can't satisfy all people... that we can agree on.
even digital video such as HDMI connector people hate it and prefer DisplayPort for having locking pins...
