Author Topic: algorithm to quickly find a pattern in a block  (Read 5720 times)
Offline DiTBhoTopic starter
« on: February 14, 2025, 11:10:16 am »
Need to find an pattern, array of uint8_t, so it's "hex searching", in a large block.
Looking for the fastest method
Ummm, tempted to reuse what GNU/hexedit does, but first, let's look around ...
Online tggzzz
Re: algorithm to quickly find a pattern in a block
« Reply #1 on: February 14, 2025, 12:06:43 pm »
Simple linear search of contiguous data, or regular expression pattern matching?
Bit/byte/word/etc alignment?
One way or another you will end up with a FSM, whether or not you realise it. Merely by thinking that way will suggest solutions.
« Last Edit: February 14, 2025, 12:08:32 pm by tggzzz »
Offline artag
« Reply #2 on: February 14, 2025, 12:51:48 pm »
Are you looking for a specific pattern in terms of a sequence of bytes, or trying to find something unknown but repetitive such as a musical note in a digitised audio sample ?
The first might be a simple search but the second would have attributes of scaling in both amplitude and time and would probably be based on an autocorrelation.
« Reply #3 on: February 14, 2025, 12:59:20 pm »
sequence of bytes
Online SiliconWizard
« Reply #4 on: February 14, 2025, 01:10:12 pm »
If you don't care for performance, use a naive linear search.
But since your said "quickly", I recommend using what's been used for searching text for a few decades: the Knuth-Morris-Pratt algorithm.
https://en.wikipedia.org/wiki/Knuth%E2%80%93Morris%E2%80%93Pratt_algorithm
The following users thanked this post: Smokey, cfbsoftware, DiTBho
Online tggzzz
« Reply #5 on: February 14, 2025, 01:21:01 pm »
sequence of bytes
ABCDE or A?CDE or A*E ?
The following users thanked this post: newbrain, DiTBho
« Reply #6 on: February 14, 2025, 01:51:44 pm »
good question, I need both  :o
it can be implemented with two different algorithms, in two different modules.
It will be part of a firmware I am writing, kind of debugging feature of a "monitor"
It needs to search things into buffer of ram and device buffer.
the bad thing is that they are not always strings
and that often, as you just pointed out, there can be small variations (*)
ABCDE -> A*CDE
(*) means whatever, 1 byte of freedom, covering 0x00 ... 0xff
« Reply #7 on: February 14, 2025, 01:57:22 pm »
KMP can be used on any series of integer values.
Adding wildcards though will require some changes.
« Reply #8 on: February 14, 2025, 01:59:54 pm »
The Knuth-Morris-Pratt algorithm
uhm, I implemented the KMP-algo in my myC text editor myED.
I can reuse some of its code for the monitor/mips(1),
but this time it's not "substring search" but "hex search".
Even worse, with 1 byte of freedom.
(1) guess what for? for the damn rb532a router
hacking and reverse engineering is the only way ...
Online tggzzz
« Reply #9 on: February 14, 2025, 02:44:06 pm »
ABCDE -> A*CDE
In many regexp libraries "?"=one, "*"=0 to many. The difference matters, hence the differences between grep, egrep and fgrep utilities.
Offline spostma
« Reply #10 on: February 14, 2025, 08:59:42 pm »
the Boyer-Moore serach algorithm could be useful for you:
https://www.geeksforgeeks.org/boyer-moore-algorithm-for-pattern-searching/
The following users thanked this post: cfbsoftware, DiTBho
Offline Analog Kid
« Reply #11 on: February 14, 2025, 09:53:07 pm »
This is similar to a parsing problem.
My go-to method for parsing is to implement a state machine (technically a finite-state automaton or FSA). Easily coded: you have a loop that fetches the next character from the stream, then a jump table that dispatches to code stubs depending on the character seen (which can either be a single character or a class of characters, like numeric digits).
I use assembly language, but this can be done in any language, like C: it's driven by the jump table which has one row for each state, and columns corresponding to the character (or class of character) just seen.
« Reply #12 on: February 14, 2025, 10:30:17 pm »
going to implement it, thanks!
Offline benseno
  • Country: tr
« Reply #13 on: February 14, 2025, 11:49:38 pm »
May be, comparing the sum (add here any operation with lowest cost resulting in quasi unique result) of character values within sliding window substring (whose length is equal ot the length of patter) to the sum of characters in the pattern. Fast shifting of sliding window can be done by subtracting the oldest element and adding a newest one.
Above can be applied to the strict patter check.
Utilizing platform dependent asm instructions can also help. And another approach is to use multiple cores for paralleling the task.
You can also check glogg - huge file viewer. It can efficiently search gigabytes big texts.
« Reply #14 on: February 15, 2025, 12:52:03 am »
It's just a sequence of integers. What exactly do you see as a difference? You may of course have to change the data types but the algorithm is the same.
Yes, as I mentioned, it's *the* difference: adding wildcards. But from what I get, your wildcards are restricted to 1 character only, so that should make it easier.
? probably means "any value" (but there must be exactly one in that place)
* usually means zero or more values (in your case, it would seem you only want 1 value of "freedom", so does that mean that the * is none, or any value?
Offline Tation
  • Country: pt
« Reply #15 on: February 15, 2025, 08:01:27 am »
https://www.google.fr/url?sa=t&source=web&rct=j&opi=89978449&url=https://igm.univ-mlv.fr/~lecroq/articles/cl2008.pdf&ved=2ahUKEwjpn5PZlsWLAxWITqQEHXWzDAMQFnoECCEQAQ&usg=AOvVaw3UPBGG_I-mK6Th2mO18Z3y
It seems that, from Boyer-Moore up, the "best" algorithm depends on exactly what kind of search is needed (size of alphabet, size of pattern...). The paper does not include the Knuth-Morris-Pratt, though.
In any case I wonder if there's much to gain implementing any of these against using any available search()/find() function in some common library.
« Reply #16 on: February 15, 2025, 12:00:52 pm »
strings are managed by xx_string_compare(), which considers the special char '\0' has end of string.
hex-arrays should use xx_mem_compare(), which considers a pair of uint8 within a window
Offline Traceless
« Reply #17 on: February 15, 2025, 12:06:13 pm »
Let me save you some time there just use std::search.
« Reply #18 on: February 15, 2025, 12:23:57 pm »
eh, there are some constraints I didn't mention.
I'm not using a standard C compiler, but rather myC, myown C-like compiler.
This excludes C++ and existing standard-C libraries, unless they are "adapted".
« Reply #19 on: February 15, 2025, 12:26:22 pm »
This algo needs to do search from 32kbyte (hw buffer) up to 4Mbyte (rom0)
While the size of searching key is always less than 512byte.
Edit:
The CPU is a single core MIPS32 at 400Mhz, with 8Kbyte of D/I cache.
« Last Edit: February 15, 2025, 12:35:17 pm by DiTBho »
Offline Tation
  • Country: pt
« Reply #20 on: February 15, 2025, 03:39:51 pm »
512 byte patterns are "long" patterns. In this case Backward Oracle Matching (BOM) algorithms and derivatives are thought to be the most efficient.
But I do not think that the benefit over Boyer-Moore (maybe around 50 % in selected cases, definitely not orders of magnitude) worths the effort.
Offline radiolistener
  • Country: Earth
« Reply #21 on: February 15, 2025, 09:51:22 pm »
Here is AI ChatGPT-4-turbo version (a little bit modified and fixed for better readability) :)
#include <stdio.h>
#include <stdint.h>
int indexOf(uint8_t *buffer, size_t bufferSize, uint8_t *pattern, size_t patternSize) {
    if (patternSize == 0 || bufferSize < patternSize) {
        return -1;
    size_t badChar[256];
    for (size_t i = 0; i < 256; i++) {
        badChar[i] = patternSize;
    for (size_t i = 0; i < patternSize - 1; i++) {
        badChar[pattern[i]] = patternSize - 1 - i;
    size_t i = 0;
    while (i <= bufferSize - patternSize) {
        size_t j = patternSize - 1;
        while (j < patternSize && buffer[i + j] == pattern[j]) {
            if (j == 0) {
                return i; // Pattern found
            j--;
        i += badChar[buffer[i + patternSize - 1]]; // Shift using bad character rule
    return -1; // Pattern not found
int main() {
    uint8_t buffer[] = {0x01, 0x02, 0x03, 0x04, 0x05, 0x00, 0x07, 0x08, 0x04, 0x05, 0x06, 0x07, 0x08};
    uint8_t pattern[] = {0x04, 0x05, 0x06};
    int result = indexOf(buffer, sizeof(buffer), pattern, sizeof(pattern));
    if (result < 0) {
        printf("Pattern not found\n");
    } else {
        printf("Pattern found at index: %d\n", result);
    return 0;
« Last Edit: February 17, 2025, 07:57:02 am by radiolistener »
  • Country: Earth
« Reply #22 on: February 17, 2025, 07:55:05 am »
Here is AI Grok2 version, with no fixes:
    if (bufferSize < patternSize) {
        return -1; // Pattern cannot fit in buffer
    for (size_t i = 0; i <= bufferSize - patternSize; ++i) {
        if (memcmp(&buffer[i], pattern, patternSize) == 0) {
            return (int)i; // Match found, return index
The same AI Grok2 with asking to not use memcmp:
        size_t j;
        for (j = 0; j < patternSize; ++j) {
            if (buffer[i + j] != pattern[j]) {
                break; // No match, continue searching
        if (j == patternSize) {
Online tggzzz
« Reply #23 on: February 17, 2025, 10:58:21 am »
Anybody who thinks feels posting LLM responses to technical questions is useful should read these two summaries of the competence of LLMs.
https://www.science.org/content/blog-post/evaluation-deep-research-performance
https://www.bbc.com/news/articles/c0m17d8827ko
« Reply #24 on: February 17, 2025, 11:15:00 am »
Not interested in answers from chatGPT&C.
Don't post, please
The following users thanked this post: tggzzz
