Author Topic: C word  (Read 57150 times)
Offline SiliconWizard
Re: C word
« Reply #200 on: October 01, 2019, 07:11:21 pm »
You don't need to use that construct if you don't want to.
It was not written by me. That is the point. It was a mistake made by someone who edited the file making a mess without knowing it, and GCC silently accepted it.
Well, as I said, it's a perfectly valid C construct, so of course it'll accept it. It's only a mistake if the assignment is not what was intended (here to initialize both lvalues to 0). It's not a mistake per se.
Again, I agree it's a bit unfortunate, and I gave the potential pitfalls and the probable initial rationale to use it.
And if it's strictly against your rules to use this construct (which I would second), just add a check for that in your static analysis tools.
Offline legacy
Re: C word
« Reply #201 on: October 01, 2019, 07:17:57 pm »
I have no idea if it's correct or buggy but it's easy to say what it does :P
Yup. There are similar points in the kernel source and they are correct. But, in the specific case, it was "disabling" a kernel driver like if needed to be "skipped", which then actually made the probe to fail.
Why does it happen? What's wrong? it's a hardware failure? you have to investigate. And this opens doors to the slowest and most tedious ways of finding a bad git commit. You checkout some old commit, make sure the broken code isn't there, then check out a slightly older commit, check again, and repeat over and over until you find the flawed commit.
do
    branch_back();
    is_ok=does_it_work();
while (is_ok isEqualTo False);
Which, in the end, was a stupid mistake: a line of code deleted and appended with the following, which "looks" correct because the C grammar allows A = B = 0  :palm: :palm: :palm:
Offline Nominal Animal
Re: C word
« Reply #202 on: October 01, 2019, 07:18:28 pm »
Now maybe you're thinking of the abused way of using hungarian notation, and taking it too far, which I don't do. Some abusive users of it have actually gone way too far (I remember Microsoft was a heavy user of it, and went a bit too far with it), and coming up with prefixes for almost every possible type definition, even custom ones! This is not at all what I do. I keep it clean and simple, and this way maintenance is absolutely no issue. I'll prefix pointers with p. If a given identifier is not a pointer, it's not prefixed with p. End of story.
You hit the nail on the head.  Looking at the Wikipedia article, it's the Systems Hungarian I oppose, because I've seen issues with short/int/long and unsigned prefixes (and near/far pointers on code I haven't used but have looked at).
Apps Hungarian looks non-problematic to me.
Your variant, Silicon Hungarian, with just pointers marked for easier human parsing, has nothing objectionable to me.
Some other prefixes that might be useful would be n for counts, s for human-readable strings, and b for binary blobs.  The point is, these act like comments: they help humans parse the programmer intent.  One could claim that that's not the case with pointers, but because * and & are common in expressions, having an additional marker that a variable is a pointer, does help express programmer intent, and probably makes expressions easier to parse correctly for us humans.
Re: C word
« Reply #203 on: October 01, 2019, 07:23:01 pm »
That's an exact example about what I wrote earlier, about comments and trying to remember without looking up the order of parameters for memset(): even Linux kernel developers make mistakes like that surprisingly often.  Which just shows why expressing developer intent is so important for maintainability and bug-fixability.
(Which is kind of why I feel the same way about Obfuscated C contests as I do about freediving in sewers.)
Re: C word
« Reply #204 on: October 01, 2019, 07:23:55 pm »
Oh, now I get it why you said it was a "mistake". Didn't know it was an accident and not written on purpose...
Well, again, I think this construct should indeed be banned from C, and I guess the std committee has probably raised that many times and never resolved to ban it; that would probably break a lot of legacy code.
The simple rule to add would be that an assignment expression would have no definite type instead of being a rvalue of the type of its lvalue. It could for instance have the "void" type, so such constructs would all be incorrect C in any case.
The example you gave is not the only one, there's also the very famous: "if (a = b)". It's correct C. Was "if (a == b)" meant instead? Who knows... but it's correct C for the same reason: "a = b" is an rvalue! If "a = b" expression was of type void, neither "a = b = c" or "if (a = b)" would compile. End of the story. So here is my proposal for the next std version...
And that said, the "if (a = b)" was so ubiquitous and problem-ridden that most decent C compilers will now give you a warning for that. (Such as: "did you mean a == b ?"), but will give you no warning whatsoever for "a = b = c = ..."
