Author Topic: Compile time C++ constructors?  (Read 3273 times)
Offline westfwTopic starter
« on: March 04, 2022, 11:09:41 pm »
Can I coerce C++ construction of objects to happen at compile time, even for relatively complex objects?
In particular, suppose I want to build a linked list of keywords:
keyword *listhead = NULL;
keyword _if(listhead, "if", process_if);keyword _else(listhead, "else", process_else);keyword _while(listhead, "while", process_while);
And I have constructor/object code that looks somewhat like:
class keyword {
public:
  const char *text;
  void (*func)(char *);
  keyword *next;
  keyword(keyword *&head, const char *t, void(*f)(char *)) {
    text = t;
    func = f;
    next = head;
    head = this;  // add to beginning of linked list
In theory, that could all happen at compile time, leaving me with a linked list that could theoretically be "const" and stuck in ROM instead of precious RAM.
Is there a way to make this happen?
Online magic
Re: Compile time C++ constructors?
« Reply #1 on: March 05, 2022, 08:25:54 am »
I suppose constexpr constructors may work, but not if the constructor writes to a global variable.
You would need to provide a new constructor which takes the next pointer to embed in the given list element explicitly, start constructing your objects from the tail and finally initialize listhead with the last object constructed.
Same thing could be achieved with manually initialized ordinary structs or, if there is no need to add elements dynamically, just make it an array instead of a list.
« Last Edit: March 05, 2022, 08:30:06 am by magic »
Offline retiredfeline
« Reply #2 on: March 05, 2022, 10:35:35 am »
Write a script to generate an array of structs/classes and their initializers.
Offline TheCalligrapher
« Reply #3 on: March 05, 2022, 05:46:26 pm »
Easily achievable in C with its compound literals. C++ is trickier.
Online SiliconWizard
« Reply #4 on: March 05, 2022, 06:07:12 pm »
That would be the most reasonable approach.
Or, even if you need a dynamic list, but initialized with some items, just implement a constructor for the list object that takes an array as a parameter to initialize values.
I have a hard time seeing the benefit of going through hoops here, but hey, what do I know.
« Reply #5 on: March 05, 2022, 07:03:03 pm »
Well, you can declare an array and still interlink the elements in order to make it conform to list interface
Using the current class declaration
class keyword {
public:
  const char *text;
  keyword *next;
    text = t;
    func = f;
    next = head;
keyword *listhead = nullptr;
keyword keywords[] = { { listhead, "if", process_if }, { listhead, "else", process_else }, { listhead, "while", process_while } };
Sequencing rules guarantee that array elements are constructed left-to-right.
Or you can use a POD-class instead and do this
class keyword {
public:
  const char *text;
  keyword *next;
keyword keywords[] = { { "if", process_if, nullptr }, { "else", process_else, &keywords[0] }, { "while", process_while, &keywords[1] } };
keyword *listhead = &keywords[2];
This feels even more "compile-timeish" although in reality both variants are virtually the same.
« Last Edit: March 05, 2022, 07:04:44 pm by TheCalligrapher »
« Reply #6 on: March 05, 2022, 10:35:33 pm »
What was clear from my original message (especially after the forum software mangled my newlines) was that I want to AVOID having a single declaration of a big keyword table.  I want to intersperse the keyword definitions with the code that implements each keyword like:
void process_if() {
  // code to process if
keyword _else(listhead, "else", process_else);void process_else() {
  // code to process else
This makes it easy to add keywords, or leave them out vs conditional compilation, and would make for a cleaner-looking source code (although harder to look at and see which commands are implemented.)
C++ run-time constructors would do this just fine, and they build a data structure that is essentially complete and static that COULD have been built at compile-time.
I could settle for that, if there is a way to initialize individual elements of an array at different points of the source code...
(I'm pretty sure I could also do this with inline assembly, since assembly macros tend to be much more powerful than C macros.  But... eww.)
Offline DiTBho
« Reply #7 on: March 05, 2022, 10:49:47 pm »
what are you trying to achieve? An interpreter?  :o
« Reply #8 on: March 07, 2022, 08:42:07 am »
A memory-efficient CLI parser, actually.
Something where if you want to add a new command (keyword), it is relatively easy at the source level, rather than requiring careful editing of complex data structures, tables, and/or case statements.
« Reply #9 on: March 07, 2022, 09:23:48 am »
Write a script to scan the file containing the bodies of your functions to generate an array of structs/classes and their initializers to another file. Use a distinctive macro for the function header to make it easy for your script.
