Author Topic: Disc mounting in dosbox  (Read 1980 times)
Offline geggi1Topic starter
« on: March 04, 2023, 09:32:30 am »
Hi all!
I'm looking at a way to use dosbox to run some DOS radio programming software.
To keep it flexible I'm using a portable image on a tumb drive.
The problem is when changing PC there will be issues because the drive can change letter.
Is there a way to mount the drive with a command similar to using %windir% when referring to the location where windows in installed?
[autoexec]
# Lines in this section will be run at startup.
ECHO
Set Serial port to COM1 in device manager.
ECHO OFF
mount C: D:\C
C:
cd icom
ex1726.exe /EXPERT
Offline golden_labels
Re: Disc mounting in dosbox
« Reply #1 on: March 04, 2023, 01:46:54 pm »
I assume(1) the operating system is Windows. Please specify that kind of information, while asking questions.
Windows does not offer a way to use predictable volume or file system paths in a manner, that “just works” with any program. Therefore I believe the general answer is: no. However, a few guesses you may try:
If DosBox supports this path style, you may try identifying the file system using \\?\Volume{id} — where id stands for file system’s UUID.
Otherwise: in volume options there is a feature, which allows you to assign a particular letter to a given volume. I have no idea, if that works for removable media. But, if it does, you can set the same letter your thumb drive on all computers.
The third option is bruteforcing all 23 options(2) and checking, if some required file is present.
IIRC, batch scripts started from Explorer are executed with the working directory set to where the script is located. If that is true, you can write a script to start DosBox and use relative paths in it.
(1) Based on the mention of “drive letters” and “%windir%”.
(2) “A:”, “B:” and “C:” are excluded, so checking only covers “D:” to “Z:”.
« Last Edit: March 04, 2023, 01:56:04 pm by golden_labels »
Why 📎 | We live in times when half of people have IQ below 100.
« Reply #2 on: March 04, 2023, 05:39:44 pm »
I'm running windows 7 but this should not matter because the bat file is running inside the config settings on the Dosbox.
I would assume that this will only run native dos comands.
Here is the whole config code.
With the mapping commands at the end.
# This is the configurationfile for DOSBox 0.73.
# Lines starting with a # are commentlines.
# They are used to (briefly) document the effect of each option.
[sdl]
#       fullscreen: Start dosbox directly in fullscreen.
#       fulldouble: Use double buffering in fullscreen.
#   fullresolution: What resolution to use for fullscreen: original or fixed size (e.g. 1024x768).
# windowresolution: Scale the window to this size IF the output device supports hardware scaling.
#           output: What video system to use for output.
#                   Possible values: surface, overlay, opengl, openglnb, ddraw.
#         autolock: Mouse will automatically lock, if you click on the screen.
#      sensitivity: Mouse sensitivity.
#      waitonerror: Wait before closing the console if dosbox has an error.
#         priority: Priority levels for dosbox. Second entry behind the comma is for when dosbox is not focused/minimized. (pause is only valid for the second entry)
#                   Possible values: lowest, lower, normal, higher, highest, pause.
#       mapperfile: File used to load/save the key/event mappings from.
#     usescancodes: Avoid usage of symkeys, might not work on all operating systems.
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=true
[dosbox]
# language: Select another language file.
#  machine: The type of machine tries to emulate.
#           Possible values: hercules, cga, tandy, pcjr, ega, vgaonly, svga_s3, svga_et3000, svga_et4000, svga_paradise, vesa_nolfb, vesa_oldvbe.
# captures: Directory where things like wave, midi, screenshot get captured.
#  memsize: Amount of memory DOSBox has in megabytes.
#             This value is best left at its default to avoid problems with some games,
#             though few games might require a higher value.
#             There is generally no speed advantage when raising this value.
language=
machine=svga_s3
captures=capture
memsize=16
[render]
# frameskip: How many frames DOSBox skips before drawing one.
#    aspect: Do aspect correction, if your output method doesn't support scaling this can slow things down!.
#    scaler: Scaler used to enlarge/enhance low resolution modes. If 'forced' is appended,the scaler will be used even if the result might not be desired.
#            Possible values: none, normal2x, normal3x, advmame2x, advmame3x, advinterp2x, advinterp3x, hq2x, hq3x, 2xsai, super2xsai, supereagle, tv2x, tv3x, rgb2x, rgb3x, scan2x, scan3x.
frameskip=0
aspect=false
scaler=normal2x
[cpu]
#      core: CPU Core used in emulation. auto will switch to dynamic if available and appropriate.
#            Possible values: auto, dynamic, normal, simple.
#   cputype: CPU Type used in emulation. auto is the fastest choice.
#            Possible values: auto, 386, 386_slow, 486_slow, pentium_slow, 386_prefetch.
#    cycles: Amount of instructions DOSBox tries to emulate each millisecond. Setting this value too high results in sound dropouts and lags. Cycles can be set in 3 ways:
#              'auto'          tries to guess what a game needs.
#                              It usually works, but can fail for certain games.
#              'fixed #number' will set a fixed amount of cycles. This is what you usually need if 'auto' fails.
#                              (Example: fixed 4000)
#              'max'           will allocate as much cycles as your computer is able to handle
#            Possible values: auto, fixed, max.
#   cycleup: Amount of cycles to increase/decrease with keycombo.
# cycledown: Setting it lower than 100 will be a percentage.
core=auto
cputype=auto
cycles=auto
cycleup=500
cycledown=20
[mixer]
#   nosound: Enable silent mode, sound is still emulated though.
#      rate: Mixer sample rate, setting any device's rate higher than this will probably lower their sound quality.
#            Possible values: 22050, 44100, 48000, 32000, 16000, 11025, 8000, 49716.
# blocksize: Mixer block size, larger blocks might help sound stuttering but sound will also be more lagged.
#            Possible values: 2048, 4096, 8192, 1024, 512, 256.
# prebuffer: How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
#     mpu401: Type of MPU-401 to emulate.
#             Possible values: intelligent, uart, none.
# mididevice: Device that will receive the MIDI data from MPU-401.
#             Possible values: default, win32, alsa, oss, coreaudio, coremidi, none.
# midiconfig: Special configuration options for the device driver. This is usually the id of the device you want to use. See README for details.
mpu401=intelligent
mididevice=default
midiconfig=
[sblaster]
#  sbtype: Type of sblaster to emulate.
#          Possible values: sb1, sb2, sbpro1, sbpro2, sb16, none.
#  sbbase: The IO address of the soundblaster.
#          Possible values: 220, 240, 260, 280, 2a0, 2c0, 2e0, 300.
#     irq: The IRQ number of the soundblaster.
#          Possible values: 7, 5, 3, 9, 10, 11, 12.
#     dma: The DMA number of the soundblaster.
#          Possible values: 1, 5, 0, 3, 6, 7.
#    hdma: The High DMA number of the soundblaster.
# sbmixer: Allow the soundblaster mixer to modify the DOSBox mixer.
# oplmode: Type of OPL emulation. On 'auto' the mode is determined by sblaster type. All OPL modes are Adlib-compatible, except for 'cms'.
#          Possible values: auto, cms, opl2, dualopl2, opl3, none.
#  oplemu: Provider for the OPL emulation. compat or old might provide better quality (see oplrate as well).
#          Possible values: default, compat, fast, old.
# oplrate: Sample rate of OPL music emulation. Use 49716 for highest quality (set the mixer rate accordingly).
#          Possible values: 22050, 49716, 44100, 48000, 32000, 16000, 11025, 8000.
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=22050
[gus]
#      gus: Enable the Gravis Ultrasound emulation.
#  gusrate: Sample rate of Ultrasound emulation.
#  gusbase: The IO base address of the Gravis Ultrasound.
#           Possible values: 240, 220, 260, 280, 2a0, 2c0, 2e0, 300.
#   gusirq: The IRQ number of the Gravis Ultrasound.
#           Possible values: 5, 3, 7, 9, 10, 11, 12.
#   gusdma: The DMA channel of the Gravis Ultrasound.
#           Possible values: 3, 0, 1, 5, 6, 7.
# ultradir: Path to Ultrasound directory. In this directory
#           there should be a MIDI directory that contains
#           the patch files for GUS playback. Patch sets used
#           with Timidity should work fine.
gus=false
gusrate=22050
gusbase=240
gusirq=5
gusdma=3
ultradir=C:\ULTRASND
[speaker]
# pcspeaker: Enable PC-Speaker emulation.
#    pcrate: Sample rate of the PC-Speaker sound generation.
#     tandy: Enable Tandy Sound System emulation. For 'auto', emulation is present only if machine is set to 'tandy'.
#            Possible values: auto, on, off.
# tandyrate: Sample rate of the Tandy 3-Voice generation.
#    disney: Enable Disney Sound Source emulation. (Covox Voice Master and Speech Thing compatible).
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=true
[joystick]
# joysticktype: Type of joystick to emulate: auto (default), none,
#               2axis (supports two joysticks),
#               4axis (supports one joystick, first joystick used),
#               4axis_2 (supports one joystick, second joystick used),
#               fcs (Thrustmaster), ch (CH Flightstick).
#               none disables joystick emulation.
#               auto chooses emulation depending on real joystick(s).
#               Possible values: auto, 2axis, 4axis, 4axis_2, fcs, ch, none.
#        timed: enable timed intervals for axis. (false is old style behaviour).
#     autofire: continuously fires as long as you keep the button pressed.
#       swap34: swap the 3rd and the 4th axis. can be useful for certain joysticks.
#   buttonwrap: enable button wrapping at the number of emulated buttons.
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=true
[serial]
# serial1: set type of device connected to com port.
#          Can be disabled, dummy, modem, nullmodem, directserial.
#          Additional parameters must be in the same line in the form of
#          parameter:value. Parameter for all types is irq.
#          for directserial: realport (required), rxdelay (optional).
#                           (realport:COM1 realport:ttyS0).
#          for modem: listenport (optional).
#          for nullmodem: server, rxdelay, txdelay, telnet, usedtr,
#                         transparent, port, inhsocket (all optional).
#          Example: serial1=modem listenport:5000
#          Possible values: dummy, disabled, modem, nullmodem, directserial.
# serial2: see serial1
# serial3: see serial1
# serial4: see serial1
serial1=directserial realport:COM1
serial2=directserial realport:COM2
serial3=disabled
serial4=disabled
[dos]
#            xms: Enable XMS support.
#            ems: Enable EMS support.
#            umb: Enable UMB support.
# keyboardlayout: Language code of the keyboard layout (or none).
xms=true
ems=true
umb=true
keyboardlayout=auto
[ipx]
# ipx: Enable ipx over UDP/IP emulation.
ipx=false
[parallel]
parallel1=printer
[printer]
printoutput=printer
device="Microsoft Print to PDF"
[autoexec]
ECHO
ECHO OFF
mount C: D:\C
C:
cd icom
ex1726.exe /EXPERT
« Last Edit: March 04, 2023, 05:44:06 pm by geggi1 »
« Reply #3 on: March 04, 2023, 10:20:20 pm »
Commands, which interact with external world (like mount), are dependent on the operating system. It would be pretty useless, if I told you how to do that one some Linux distro, Android or MacOS.
« Reply #4 on: March 05, 2023, 09:52:16 am »
Solved it!
Did google a  bit and figured out a solution by using variables.  :)
Used the %CD% command to set a variable.
Than used the variable as the first part of the path for the drive to map.
New code.
[autoexec]
ECHO
ECHO OFF
SET/P dri=%CD%
mount C: %dri%\C
C:
cd icom
ex1726.exe /EXPERT
Old code.
[autoexec]
ECHO
ECHO OFF
mount C: D:\C
C:
cd icom
ex1726.exe /EXPERT
