Author Topic: display change  (Read 2212 times)
Offline m3vuvTopic starter
display change
« on: December 28, 2020, 08:49:49 am »
Hi all,i have a project using a lcd display,heres the code://-----------------------------------------------------Youtube Channel Sasiskas------------------------------------------------------------------------
//-----------------------------------------------------Battery Capacity tester and more V1.1-----------------------------------------------------------
#include <SPI.h>
#include <stdlib.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
unsigned long previousMillis = 0;
unsigned long millisPassed = 0;
unsigned long BatFull = 0;
float BatVoltQuiescent = 0;                                             // The battery voltage when there is no load on the battery
float Capacity = 0.0;                                                   // The calculated capacity of the battery, measured wile discharging
float mA=0;
float SetI = 0;                                                         // The setpoint for the discharging current. Remember you can adjust the discharging current using the 500K trimpot.
float ChargeI = 0;
float CurTP4056 = 0;
float ResTP4056 = 0;
float ratioRI = 0;
float BatLevel = 0;                                                     // The percentage of battery charge/level
float BatVoltCorrected = 0;                                             // The voltage of the battery, measured based on the arduino internal reference
float A2VoltCorrected = 0;
float VoltTP4056Pin2  = 0;
float Rprog = 0;
float BatRes = 0;                                                       // The internal battery resistance
const float RES = 1;                                                    // Value of your resistor. Suggested Value is 1 Ohm. Change it, if you use a different resistor value
#define clk 2
#define dt 3
#define sw 4
#define MOSFET_Discharge 9                                              // It is an N-MOSFET, so HIGH is ON and LOW is OFF
#define MOSFET_Charge 8                                                 // It is a P-MOSFET, so HIGH is OFF and LOW is ON
char screen = 0;
char arrowpos = 0;
char charging = 0;
char discharging = 0;
char storage = 0;
char storagecharge = 0;
char storagedischarge = 0;
char BatVoltQuiescentValue = 0;                                          // Whether there is a value for "the battery voltage with no load" (BatVoltQuiescent) or not. 1 for yes and 0 for no.
//char nointermediate = 0;
const unsigned char PS_128 = (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0);
volatile boolean TurnDetected = false;
volatile boolean up = false;
volatile boolean button = false;
byte OhmChar[8] = {
  B00000,
  B01110,
  B10001,
  B10001,
  B10001,
  B01010,
  B11011,
  B00000
byte customChar1[8] = {
  0b10000,
  0b11000,
  0b11100,
  0b11110,
  0b11110,
  0b11100,
  0b11000,
  0b10000
ISR(PCINT2_vect) {
  if (digitalRead(sw) == LOW) {
    button = true;
void isr0 ()  {
  TurnDetected = true;
  up = (digitalRead(clk) == digitalRead(dt));
void setup() {
  lcd.begin();
  lcd.setCursor(0, 0);
  pinMode(MOSFET_Discharge, OUTPUT);
  pinMode(MOSFET_Charge, OUTPUT);
  digitalWrite(MOSFET_Discharge, LOW);
  digitalWrite(MOSFET_Charge, HIGH);
  pinMode(sw, INPUT_PULLUP);
  pinMode(clk, INPUT);
  pinMode(dt, INPUT);
  PCICR |= 0b00000100;
  PCMSK2 |= 0b00010000;   // turn o PCINT20(D4)
  attachInterrupt(0, isr0, RISING);
  lcd.createChar(0, customChar1);
  lcd.createChar(1, OhmChar);
  lcd.clear();
  screen0();
  lcd.write((uint8_t)0);
void loop() {
  int in0 = analogRead(A0);                                           //read the A0 pin value
  int sensorValue1 = analogRead(A1);                                  //read the A1 pin value
  float val0 = in0 * 5.0 / 1024.0;
  float supply = readVcc() / 1000.0;
  SetI = sensorValue1 * (5.00 / 1024.00) / RES * 1000;                // Calculate the discharge rate of the battery
  if (SetI <= 1200){
    SetI = SetI;
  else{
    SetI = 1200;
  BatVoltCorrected = supply / 5 * val0 * 4.35;                         //In case you use different voltage dividers, you need to change the number 4.3 accordingly.
  millisPassed = millis() - previousMillis;
  previousMillis = millis();
  //------------------------------------------------------------------- calculates the charging current ------------------------------------------------------------------------
  int in2 = analogRead(A2);                                                      //read the A2 pin value
  int in3 = analogRead(A3);                                                      //read the A3 pin value
  float val2 = in2 * 5.0 / 1024.0;
  float val3 = in3 * 5.0 / 1024.0;
  A2VoltCorrected = supply / 5 * val2;                                           //calculates reading of pin A2 based on internal voltage reference
  VoltTP4056Pin2 = supply / 5 * val3;                                            //calculates reading of pin A3 based on internal voltage reference
  Rprog = 1220 + (A2VoltCorrected * 1220 / (VoltTP4056Pin2 - A2VoltCorrected));  //calculates the Rprog of TP4056 module
        //calculates the Charging current based on numbers from TP4056 datasheet
  if (Rprog >= 10000) {
   CurTP4056 =130 ;
   ResTP4056 =10000 ;
   ratioRI = 0.107 ;
  else if (Rprog < 10000 && Rprog >= 5000){
    CurTP4056 = 250 ;
   ResTP4056 = 5000 ;
   ratioRI = 0.024 ;
   else if (Rprog < 5000 && Rprog >= 4000){
    CurTP4056 = 300 ;
   ResTP4056 = 4000 ;
   ratioRI = 0.050 ;
   else if (Rprog < 40000 && Rprog >= 3000){
    CurTP4056 = 400 ;
   ResTP4056 = 3000 ;
   ratioRI = 0.100 ;
   else if (Rprog < 30000 && Rprog >= 2000){
    CurTP4056 = 580 ;
   ResTP4056 = 2000 ;
   ratioRI = 0.180 ;
   else if (Rprog < 20000 && Rprog >= 1660){
    CurTP4056 = 690 ;
   ResTP4056 = 1660 ;
   ratioRI = 0.324 ;
   else if (Rprog < 10000 && Rprog >= 1500){
    CurTP4056 = 780 ;
   ResTP4056 = 1500 ;
   ratioRI = 0.563 ;
   else if (Rprog < 10000 && Rprog >= 1330){
    CurTP4056 = 900 ;
    ResTP4056 = 1330 ;
    ratioRI = 0.706 ;
    else if (Rprog >= 1220){
    CurTP4056 = 995 ;
    ResTP4056 = 1220 ;
    ratioRI = 0.864 ;
   if (Rprog < 1220){
    ChargeI = 1000 ;
  else {
  ChargeI = (CurTP4056 - ((Rprog - ResTP4056) * ratioRI));
  if (ChargeI > 0){
  ChargeI = ChargeI;
  else{
  ChargeI = 0;
  //------------------------------------------------------------------- battery percentage - linear calculation based on voltage (linear does NOT represent the REAL percentage)
  if (BatVoltCorrected < 2.5) {
  BatLevel = 0;
  else if (BatVoltCorrected > 4.2)
  {BatLevel = 100;
  else {BatLevel = (BatVoltCorrected - 2.5 ) / 1.7 * 100 ;
  if (BatVoltCorrected <= 3.70 && BatVoltCorrected >= 3.65){          // For 3400mAh batteries storage voltage is 3.6-3.7V, for batteries below 2600mAh it should be higher.
  storagecharge = 0;
  if (BatVoltCorrected <= 3.75 && BatVoltCorrected > 3.7){            // Set these numbers +0.5V of your batteries storage voltage
  storagedischarge = 1;
  storage = 2;
  storagecharge = 0;
  if (BatVoltCorrected >= 3.6 && BatVoltCorrected < 3.65){            // Set these numbers -0.5V of your batteries storage voltage
  storagecharge = 1;
  storage = 2;
  if (BatVoltCorrected > 3.75 || BatVoltCorrected < 3.6){             // Set these numbers +0.5V and -0.5V of your batteries storage voltage
  storage = 0;
  storagecharge = 0;
  if (BatVoltCorrected <= 3.75 && BatVoltCorrected >= 3.6){           // Set these numbers +0.5V and -0.5V of your batteries storage voltage
  storage = 1;
  if (screen == 0) {
  //delay(500);
  BatVoltQuiescent = BatVoltCorrected;
  BatVoltQuiescentValue = 1;
  BatFull = 0;
//----------------------------------------------------------------------------------------Capacity test mode-------------------------------------------------------
  if (screen == 1) {
      if (BatVoltCorrected <= 2.3){
        Capacity = Capacity;
//      buz();
        lcd.setCursor(0,0);
        lcd.print("V:");
        lcd.print(BatVoltCorrected);
        lcd.print("V ");
        lcd.setCursor(8,0);
        lcd.print("I:");
        lcd.print(SetI,0);
        lcd.print("mA  ");
        lcd.setCursor(0,1);
        lcd.print("C:");
        lcd.print(Capacity,0);
        lcd.print("mAh   ");
        lcd.setCursor(10,1);
        lcd.print("R:");
        lcd.print(BatRes,0);
        lcd.print("m");
        lcd.print(char(1));
        delay(100);
      if (BatVoltCorrected > 2.3 && BatVoltQuiescentValue == 0 ) {
        BatRes = (BatVoltQuiescent - BatVoltCorrected) / (BatVoltCorrected / SetI);  //Calculates the internal battery resistance in mOhms
        Capacity = Capacity + (SetI * (millisPassed / 3600000.0));
        digitalWrite(MOSFET_Discharge, HIGH);
        lcd.setCursor(0,0);
        lcd.print("V:");
        lcd.print("V ");
        lcd.setCursor(8,0);
        lcd.print("I:");
        lcd.print(SetI,0);
        lcd.print("mA  ");
        lcd.setCursor(0,1);
        lcd.print("C:");
        lcd.print("mAh   ");
        lcd.print("R:");
        lcd.print("m");
        lcd.print(char(1));
        delay(500);
        else if (BatVoltCorrected > 2.3 && BatVoltQuiescentValue == 1 ) {
        lcd.setCursor(0,0);
        lcd.print("V:");
        lcd.print("V ");
        lcd.setCursor(8,0);
        lcd.print("I:");
        lcd.print(SetI,0);
        lcd.print("mA  ");
        lcd.setCursor(0,1);
        lcd.print("C:");
        lcd.print("mAh   ");
        lcd.print("R:");
        lcd.print("m");
        lcd.print(char(1));
        delay(500);
  //----------------------------------------------------------------------------------------Charge mode-------------------------------------------------------
  else if (screen == 2) {
       if (BatVoltCorrected >= 4.15) {
           lcd.setCursor(0,0);
           lcd.print("Full Battery");
           lcd.setCursor(12,0);
           lcd.print("100%  ");
           lcd.setCursor(0,1);
           lcd.print("V:");
           lcd.print("V         ");
         lcd.setCursor(8,1);
           lcd.print("I:");
           lcd.print(ChargeI,0);
           lcd.print("mA         ");
           delay(500);
         BatFull = BatFull + 1;
       else if (BatVoltCorrected == 0 ){
          BatFull = 0;
         lcd.setCursor(0,0);
          lcd.print("No Battery   ");
          lcd.print(BatLevel,0);
          lcd.print("%   ");
          lcd.setCursor(0,1);
          lcd.print("V:");
          lcd.print("V         ");
        lcd.setCursor(9,1);
           lcd.print("I:");
           lcd.print("mA         ");
          //delay(9000);
          //digitalWrite(MOSFET_Charge, HIGH);
          delay(500);
     else if (BatVoltCorrected < 4.15 && BatFull < 10 && BatVoltCorrected > 0 )  {
         lcd.setCursor(0,0);
          lcd.print("Charging... ");
          lcd.print("% ");
          lcd.setCursor(0,1);
          lcd.print("V:");
          lcd.print("V         ");
        lcd.setCursor(8,1);
           lcd.print("I:");
           lcd.print("mA         ");
          digitalWrite(MOSFET_Charge, LOW);
          //delay(9000);
          delay(500);
      else if (BatVoltCorrected < 4.15 && BatFull >= 10) {
           lcd.setCursor(0,0);
           lcd.print("100%  ");
           lcd.setCursor(0,1);
           lcd.print("V:");
           lcd.print("V         ");
         lcd.setCursor(8,1);
           lcd.print("I:");
           lcd.print("mA         ");
           delay(500);
  //----------------------------------------------------------------------------------------Storage mode-----------------------------------------------------------------------------------------
  // You need to adjust your voltages according to your batteries, for 3400mAh batteries storage voltage (50% capacity) is 3.6-3.7V, for batteries below 2600mAh it should be higher.
  // For more info visit this:https://lygte-info.dk/info/BatteryChargePercent%20UK.html
  else if (screen == 3) {
    delay(100);
          if (BatVoltCorrected <= 1.5 ) {
          lcd.setCursor(0,0);
          lcd.print("No battery      ");
          lcd.setCursor(0,1);
          lcd.print("V:");
          lcd.print("V            ");
          charging = 0;
          discharging = 0;
          storage = 0;
          storagecharge = 0;
         else if (BatVoltCorrected > 3.75 && charging == 0) {                            // Checks if the "quiescent voltage" of the battery is above 3.7V  and Starts the discharge.
              lcd.setCursor(0,0);
              lcd.print("Discharging       ");
              lcd.setCursor(0,1);
                  lcd.setCursor(0,1);
                  lcd.print("V:");
                  lcd.print("V        ");
                  lcd.setCursor(9,1);
                  lcd.print("I:");
                  lcd.print(SetI,0);
                  lcd.print("mA    ");
                  delay(100);
              discharging = 1;
                  delay(9000);
      else if (storagedischarge == 1 && discharging == 1){                             // Intermediate step before stopping the discharge
              lcd.setCursor(0,0);
              lcd.print("RDY for storage");
              lcd.setCursor(0,1);
              lcd.print("V:");
              lcd.print("V                            ");
              discharging = 1;
              delay(100);
              delay(9000);
      else if (BatVoltCorrected >= 1.5 && BatVoltCorrected < 3.6) {                      // Checks if the "quiescent voltage" of the battery is between 1.5V and 3.6V
                 if (discharging == 1 && BatVoltCorrected < 3.0){                     // Stops discharging if the "discharge voltage" of the battery is below 3.0V
              lcd.setCursor(0,1);
              lcd.print("V:");
              lcd.print("V        ");
              lcd.setCursor(9,1);
              lcd.print("I:");
              lcd.print(SetI,0);
              lcd.print("mA    ");
                 if (discharging == 1 && BatVoltCorrected > 2){                        // Prevents from charging (continues discharging) even if the "quiescent voltage" is below 3.6V
              lcd.setCursor(0,1);
              lcd.print("V:");
              lcd.print("V        ");
              lcd.setCursor(9,1);
              lcd.print("I:");
              lcd.print(SetI,0);
              lcd.print("mA    ");
                else if (discharging == 0 && BatVoltCorrected < 3.6){                  // Starts to charge the battery
                  lcd.setCursor(0,0);
                  lcd.print("Charging       ");
                  lcd.setCursor(0,1);
                  lcd.print("V:");
                  lcd.print("V              ");
                  delay(100);
                 charging = 1;
              delay(1000);
              else {        // used for debugging
              lcd.setCursor(0,0);
              lcd.print("error?       ");
       else if (storagecharge == 1 && charging == 1){                                  // Intermediate step before stopping the charge. (not actually stopping the charge)
              lcd.setCursor(0,0);
              lcd.setCursor(0,1);
              lcd.print("V:");
              lcd.print("V                       ");
              charging = 1;
              //nointermediate = 1;
              delay(100);
              delay(1000);
       else if (charging == 1 && BatVoltCorrected > 3.65 ){                            // Stops charge . This step is used if the Intermediate stop of charge was used.
           lcd.setCursor(0,0);
             lcd.setCursor(0,1);
             lcd.print("V:");
             lcd.print("V           ");
             delay(1000);
        else if (storage == 1 && charging == 0){                                       // For 3400mAh batteries sorage voltage is 3.6-3.7V, for batteries below 2600mAh it should be higher.
          lcd.setCursor(0,0);                                                          // This step is used if the Intermediate stop of charge was NOT used. Or after intermadiate stop of discharge.
          lcd.setCursor(0,1);
          lcd.print("V:");
          lcd.print("V           ");
          delay(1000);
//-------------------------------------------------------------------------------- TURN -------------------------------------------------------------------------------------------------------
  if (TurnDetected) {
    delay(200);
    switch (screen) {
      case 0:
        switch (arrowpos) {
           case 0:
            if (!up) {
              screen0();
              lcd.setCursor(0, 1);
              arrowpos = 1;
            else {
              screen0();
              lcd.setCursor(8, 1);
              arrowpos = 2;
            break;
          case 1:
            if (up) {
              screen0();
              arrowpos = 0;
            else {
              screen0();
              arrowpos = 2;
            break;
           case 2:
            if (up) {
              screen0();
              arrowpos = 1;
            else {
              screen0();
              arrowpos = 0;
            break;
        break;
//-------------------------------------------------------------------------------------------- BUTTON PRESS --------------------------------------------------------------------------------------------
  if (button) {
    delay(200);
    switch (screen) {
      case 0:
        if (arrowpos == 0) {
          screen = 1;
          screen1();
        else if (arrowpos == 1){
          screen = 2;
          screen2();
        else {
            screen = 3;
          screen3();
        break;
      case 1:
            screen = 0;
            screen0();
        break;
      case 2:
            screen = 0;
            screen0();
        break;
        case 3:
            screen = 0;
            screen0();
        break;
    arrowpos = 0;
    button = false;
//-----------------------------------------------------------------------------------------------------SCREENS-------------------------------------------------------------------------------------
void screen0() {
  lcd.clear();
  lcd.setCursor(1, 0);
  lcd.print("Capacity test");
  lcd.setCursor(1, 1);
  lcd.print("Charge");
  lcd.setCursor(9, 1);
  lcd.print("Store");
  charging = 0;
  discharging = 0;
  storage = 0;
  storagecharge = 0;
void screen1() {
  lcd.clear();
void screen2() {
   lcd.clear();
void screen3() {
  lcd.clear();
//-------------------------------------------------------------------voltage based on internal reference-------------------------------------------------------------
long readVcc() {
  long result;
  // Read 1.1V reference against AVcc
  #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
  ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
  #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
  ADMUX = _BV(MUX5) | _BV(MUX0);
  #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
  ADMUX = _BV(MUX3) | _BV(MUX2);
  #else
  ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
  #endif
  delay(2);                                                // Wait for Vref to settle
  ADCSRA |= _BV(ADSC); // Convert
  while (bit_is_set(ADCSRA, ADSC));
  result = ADCL;
  result |= ADCH << 8;
  result = 1126400L / result;                              // Calculate Vcc (in mV); 1126400 = 1.1*1024*1000
  return result;
//void buz()
//  digitalWrite(9, HIGH);
//  delay(100);
//  digitalWrite(9, LOW);
//  delay(10);
i want to use a 1.3 inch oled using i2c interface,  sh1106,what do i need to  change in the code to do this?,i already have all the libraies etc,thanks in advance.
« Last Edit: December 28, 2020, 09:07:18 am by m3vuv »
Offline PlainName
Re: display change
« Reply #1 on: December 31, 2020, 11:28:22 am »
You need to change the LiquidCrystal_I2C library code, not this stuff. Take a look at LiquidCrystal_I2C.h for info. As to how hard it might be, I'm afraid someone else will have to answer that (or you could find out yourself) - I am not an Arduino IDE developer and nor am I familiar with your display chip.
Offline CJay
Re: display change
« Reply #2 on: December 31, 2020, 12:21:10 pm »
I suggest you go and read the datasheets for the HD44780 controller and the SH1106/SSD1306 controller, they're significantly different, it's not just a library change, you'd need to rewrite significant portions of the code.
Offline Ian.M
Re: display change
« Reply #3 on: December 31, 2020, 12:25:04 pm »
OLED displays are almost invariably dot addressable graphics displays.  The HD44780 compatible LCD displays the various variants of the LiquidCrystal library work with are NxM ASCII text displays where N is 1, 2, or 4 lines and M is typically 8 to 40 characters per line.  As Cjay points out, the hardware and programming interface is very different.
Your code uses the following LiquidCrystal methods:
lcd.begin()
lcd.clear()
lcd.createChar()
lcd.print()
lcd.setCursor()
lcd.write()
*IF* your OLED library has equivalent methods,you could go through the code replacing the LiquidCrystal ones with their OLED equivalents, maybe with some parameter tweaking, and rescaling the coordinates of lcd.setCursor().
Otherwise you'll need to write a LCD emulation 'shim' library that translates LiquidCrystal alike method calls to something the OLED library can handle.
P.S. *PLEASE* use code tags when posting sourcecode!
Offline ledtester
Re: display change
« Reply #4 on: December 31, 2020, 12:32:07 pm »
I just googled "SH1106 arduino" and it came back with this library:
https://github.com/durydevelop/arduino-lib-oled
It says it has these features:
* Supports all print() and write() calls as the internal Serial lib of Arduino core
* Supports also standard C/C++ printf() function
* Added printf(x,y,...) to print directly at x,y coordinate with one call
Should be relatively straightforward to translate the lcd.* calls to this library.
You should first spend some time familiarizing yourself with the library, e.g. running the examples, trying out your own code, etc. as well as learning the lcd library so you know what the project code is doing.
Better yet, for a large amount of code like this make it an attachment to your post.
« Last Edit: December 31, 2020, 12:34:58 pm by ledtester »
Re: display change
« Reply #5 on: December 31, 2020, 12:58:08 pm »
it can stay as is,was just a thought.73 m3vuv.
