Author Topic: Extended Hamming Code  (Read 1904 times)
Offline hamster_nzTopic starter
« on: September 09, 2020, 09:27:21 pm »
If you aren't familiar with Hamming Codes (a simple Error Correction Code, maybe the simplest?) you could do far worse thing wiht 40 minutes than watch this:
Even if you are familiar it has a few interesting different perspectives on what is going on.
