Author Topic: Familiar with programming, not prolific, any advice?  (Read 12632 times)
Online DiTBho
Re: Familiar with programming, not prolific, any advice?
« Reply #25 on: July 13, 2023, 05:19:40 pm »
the number of lines of code in the project reduces. (Explodes the brains of idiots that count LoC as a measure of productivity, though!)
too many lines is also a serious problem for ICEs and AI-assisted automatic testing as the time to analyze the number of linearly-independent paths through a module grows exponentialy with the number of module lines, that's why in my-C I imposed a finited number of arguments passed to a function and a finited number of lines themselves of the body of function.
my-c is the first C-like compiler that cares about expressing the confidence level in a module as 1/(number of linearly-indipendent paths), and since an application is composed of multiple modules, the total confidence level is the sum of the confidence level of each module, the lower the inverse of that final number is, the easier to understand and less risky to change the whole application is.
           { dev , test } = | L(App, confidence level) | < eps
Considering "software life cycle", it should it be great for both the development and testing squads as it reduces the number of iteractions (measured by "i0")
i0=0;
test_report = {}
is_ok=False
while(is_ok)
     dev (in_out: it, in: test_report); /* development team */
     test(in:     it, out:test_report); /* testing     team */
     nbugs=test_report.nbugs;
     is_ok=(nbugs <= eps);
     i0++;
     test_report.is_ok=is_ok;
but if you take developers of non-military stuff, worse still home automation developers, and put my-c in front of them (I have already tried this social experiment), they perceive it as a "hostile and too stupidly limiting language" (their words), and they think it is more hostile than a xenonomorph alien for nothing but "for some stupid reasons tied to some stipid abstract ideals", as if its architect were nothing but a fanatic.
That's the human-factor problem in computer science  :-//
p.s.
this is also an example of how a tool can help measure complexity and keep it under control.
edit:
is_ok=(nbugs isEqualTo 0);
« Last Edit: July 13, 2023, 05:52:02 pm by DiTBho »
Online tggzzz
« Reply #26 on: July 13, 2023, 08:14:19 pm »
... AI-assisted automatic testing ...
You are living in a state of sin. If you ask the AI whether it has supplied sufficient tests, it will "hallucinate" the answer "yes".
Analogous example: the prosecution lawyer which used AI to generate case references, only to have the defence point out that none of the cases actually existed....
In the declaration Mr. Schwartz filed this week, he described how he had posed questions to ChatGPT, and each time it seemed to help with genuine case citations. He attached a printout of his colloquy with the bot, which shows it tossing out words like “sure” and “certainly!”
After one response, ChatGPT said cheerily, “I hope that helps!”"
That's become a widely know cautionary tale :)
Those problems are best kept under control by having a design strategy based around the concepts of locality, cohesion and coupling. The language is of secondary importance.
Offline brucehoult
« Reply #27 on: July 13, 2023, 10:55:54 pm »
Your question made me think I might have a problem with decision making and committing to fixed specs.  Could be.  In hardware such problems are smaller, because the choices are limited by the available parts, and other limitations from the physical world, while in software the possibilities are endless.  In software it is always possible to want/add more, or to switch between a completely different programming ways.
In software, do the simplest thing that could possibly work. You can always change it later. Don't add generality "just in case" -- "You aren't gonna need it" (YAGNI)
Ever refactored something?
Usually that's where I lose control, so I need to re-arrange/redesign some parts.  I've read a refactoring means better structured code, while retaining the same functionality from before.  I usually end up with buggy code after a refactoring attempt, or with a broken project that doesn't work any more.
HUGE red flag.
Refactoring should be a simple mechanical code transformation. It is so mechanical that people make IDEs with the common refactorings built in: "rename variable/function", "move code out of loop", "convert global to function argument", "extract code block into a function", "inline function into its callers", and so on.
Test after every small refactoring. Commit each individual change to git so that you can always backtrack if you break something.
I've read once some book that was in fashion, about TDD (Test Driven Design).  Write a test for every line seems nonsense to me.  Who's testing the test, then?
That's very simple.
You write the test for a feature (or bug) before you implement the feature (or fix the bug).
Check that the test fails.
Implement  the feature or fix the bug.
Check that the test now passes.
It's not a test for every line of code. It's tests for every feature.
I recall even from one of the working places where a software team tried TDD.  Very often the tests were failing because of bugs in the tests, and after struggling with the TDD paradigm for a couple of weeks, they ended up being less religious about TDD, and they only kept a few test that were making sense.  It was a huge software project, and those guys were top programmers at a multinational, not amateurs.
I've worked in multinationals. They always have a lot of very ... "mid" ... programmers and only a few stars to keep an eye on the rest. And they obviously were not familiar with TDD, so probably over- or under-applied it, didn't get the idea, etc.
I'm confused what should I test, and how.  Many of my projs have some hardware, so I guess it will take considerable effort to mock the hardware signals.
Sure, but that's better than abandoned projects.
And it's not THAT much effort. Hardware is just some combination of combinatorial logic and some state machine, right?
Online tggzzz
« Reply #28 on: July 13, 2023, 11:50:01 pm »
That's the dogma, and there is value in it - but it should be applied judiciously and with good taste. The latter is often missing, and the dogma is used to excuse and even to justify it.
My attitude is to identify where enhancements might reasonably be expected to occur, and to ensure that component[1] boundaries are in place. The first functionality that should be plugged into the boundaries is the absolute minimum sufficient to show that all the components are connected. The next should be the minimum necessary in a minmally useful product.
[1] "component" can be anything relevant, e.g. an algorithm in a procedural/functional/OO language, or a "software IC" in a larger bean-type ecosystem, an external computer in a distributed system, or a meter/siggen/scope/etc in an ATE system.
HUGE red flag.
That is easy and very successful with strongly typed languages, but far more difficult and less successful with dynamically typed or untyped languages. Think Java/C# for the former, Lisp/C/C++ for the latter.
That's very simple.
That's OK so far as it goes, but isn't sufficient.
Try writing a test to
  • verify ACID properties
  • show that the system operates with asynchronous inputs which occur at an undefined time
  • show that the system doesn't exhibit livelock or deadlock
... and when you've achieved that, don't forget to write up your proof for publication in, say, the ACM. Then sit back and bask in the adulation you will receive :)
The fundamental point is missed by newbies: test can only show the presence of a fault - tests can never show the absence of a fault. Experienced engineers live by the old motto "you can't inspect (by doing a test) quality into a product: it has to be designed in".
Online dietert1
  • Country: br
    • CADT Homepage
« Reply #29 on: July 14, 2023, 05:25:23 am »
Software systems are based on assumptions. One can include health tests into an application to verify basic assumptions, like the famous memory test, checksum test, stack/heap space, clock source, presence of peripherals etc. The application can watch other invariants. This is standard practice when it comes to a certain complexity.
In this realm there is a difference between hardware and software. With hardware one can "see" whether there is a short, a burned fuse or a connector got unplugged. Nowadays many devices have a LED to indicate the powered state. Something like that.
Regards, Dieter
Offline thermistor-guy
« Reply #30 on: July 14, 2023, 06:45:43 am »
...My guess is I might have to unlearn the procedural programming style and move to OOP.  Or maybe I'm really bad at programming.  I don't know what I'm doing wrong, but I know my projects are eventually abandoned because the software part became overwhelming.
What to do to become more productive in writing code (for small/hobby projects)?  Some programming exercises/books/classes to follow?  Something else to learn?  :-//
Most of the hobby projects require to write some MCU firmware, usually in C, and sometimes a PC interface, usually in Python.  Any directions of how to write that faster is welcome.
What are you like at writing functional specifications, and defining h/w and s/w interfaces for your design? Can you write a clear spec., or define an interface, and then design to it?
The less you write down, the more you have to store in your head, and that quickly gets overwhelming.
I remember one of my past team leaders saying, "If it's easy to do, it gets done." His corollary was, when faced with something difficult, find ways to make it easier.
When writing embedded code, I used to write comment sections stating what the code has to do, and briefly why. The I'd write code to do exactly that.
I'd use this as a go/no-go test - if I couldn't write that comment section, it meant I didn't really know what I was trying to do. So I'd stop, generate supplementary
design documentation that nailed down that particular aspect, then go again. That supplementary document might be something small - a decision table, a timing
diagram, a pinout, a sketch of data flows. But it was something I couldn't keeo in my head, and needed to see in front of me, while I wrote the code for it.
Online tggzzz
« Reply #31 on: July 14, 2023, 07:31:11 am »
That's a useful technique for all software, and hardware for that matter.
Online DiTBho
« Reply #32 on: July 14, 2023, 08:47:50 am »
my-c is simply a "meter" to "measure" (well, to "estimate") the complexity, used in design strategy based around the concepts of locality (per function, per module), cohesion and coupling (useful during system integration, again to "measure" the final complexity).
Online DiTBho
« Reply #33 on: July 14, 2023, 08:57:44 am »
AI means a lot of things. AI-assisted means we use statistically based predictive algorithms to create test vectors, things that usually humans(1) would not think of doing, things that potentially could not be tested.
(1) note that in the military sector it is absolutely forbidden for the development team to talk to the testing team, so even that they don't even have to greet each other, that they are sitting in two different openspaces, that they go to two different toilet rooms and different canteens (same physical canteen room, but different timetables), and the only allowed form of communication is the test_report, as I indicated in the loop above.
Why'? because if you make the testers talk to the developers, you will pollute the test vectors, since the testers will be influenced by what the developers say, and vice versa.
Humans have bias problem.
« Last Edit: July 14, 2023, 09:17:02 am by DiTBho »
Offline brucehoult
« Reply #34 on: July 14, 2023, 09:23:13 am »
(1) note that in the military sector it is absolutely forbidden for the development team to talk to the testing team, so even that they don't even have to greet each other, that they are sitting in two different openspaces, that they go to two different bathrooms and different canteens (same physical canteen room, but different timetables), and the only allowed form of communication is the test_report, as I indicated in the loop above.
Ha!
There have been a couple of jobs at medium-large companies where I have ended up dating the QA person responsible for torturing my code!
Online DiTBho
« Reply #35 on: July 14, 2023, 09:38:55 am »
in the most extreme case, they even relocate to two different buildings in two different geographical areas, several thousand kilometers away, and forbidding to hire human with personal relations (husband, wife, boyfriend, girlfriend) between those in the development area , and who is in the testing area.
as corollary, this seriously means you cannot test your own software with the same efficiency (in finding bugs) that you can have if other people test it and report to you.
So, for my personal projects I adopt these contromeasures:
  • I further raise the threshold of the measure of complexity that my-c is willing to accept when it compiles a function(1)
  • I further raise the threshold of the measure of complexity that my-c is willing to accept when it compiles a module (sum of the complexity of the functions that compose it)(1)
  • I take a week off between when I develop and when I test-report, and in that week I don't touch the project, I let myself go, I do something else "to offload all my bias on my personal stuff". I call the pause "context switch"
(1) in practice it means having functions with fewer lines of code to test, and much fewer test vectors if(...){}else{}: that's how complexity is measured by my-c, it has a precise algorithm to measure the number of linearly independent paths, but but to make it immediately understandable, we can simplify and say that it more or less means this.
Commercial Software like Cantata have similar "meters", but they are very expensive.
Of course, that it will then be a system integration verfication. You have functions that individually work well, you put them together ... and you have to see how they behave, but since you have a lower total complexity, it is very likely that you also have fewer flaws.
my-c, when integrated into Geany or Nedit, can be queried live, and you can ask to measure the complexity of the function, or of the module, you're currently working on, then you can iteratively try to reduce it.
I love this! It helps a lot! Refactoring is a pleasure this way  :D
Offline Nominal Animal
« Reply #36 on: July 14, 2023, 09:39:31 am »
I've read once some book that was in fashion, about TDD (Test Driven Design).  Write a test for every line seems nonsense to me.  Who's testing the test, then?  I recall even from one of the working places where a software team tried TDD.  Very often the tests were failing because of bugs in the tests, and after struggling with the TDD paradigm for a couple of weeks, they ended up being less religious about TDD, and they only kept a few test that were making sense.  It was a huge software project, and those guys were top programmers at a multinational, not amateurs.
I'm a pragmatist.  I use tests to find out.  Mad scientist with his experiments, perhaps.
For example, in another thread, I'm discussing with Sparkydog about how to control one or two 12V 4-pin PWM fans at constant RPM using minimal circuitry.  As typical fans age, the PWM duty does not stay constant wrt. airflow/RPM, so using a small MCU to give a startup pulse and then control the fan RPM via its tachometer output (two pulses per rotation), with a FAN-FAULT signal to the rest of the board in case one or both stall, makes a lot of sense.
Let's say I decide to write such a firmware for some 8-bit AVR, perhaps ATtiny85.  (I do that sort of stuff for free, only asking them to pass the help forwards.)
How do I go about it?
The circuitry needed is simple, and I've already simulated it.  I only need two cheap N-channel MOSFETs (NX138AKR is my favourite, assuming hand-soldered board) and a couple of resistors, and a bypass capacitor for the microcontroller.  An MCU with a timer peripheral with two output channels (most AVRs!) is needed, so that the 25kHz PWM output is handled by the peripheral.
The "trick" is how the tachometer inputs are handled.  The pulse interval varies between say 0.1s (100ms, 300 RPM) and 0.01s (10ms, 3000 RPM).  Not only are the two fans completely unrelated, but you want to find out if either one or both are stalled, i.e. pulse interval exceeds the maximum limit.
We can do this using input edge interrupts, or using an innermost busy loop counting loop iterations as "ticks".  If we use an innermost busy loop, each tachometer measurement can take up to 0.3s (because we need to detect a pair of pulse edges from each fan).  That is more than sufficient for the PWM update rate, as the fan blades have significant inertia, and the response to PWM changes isn't instantaneous anyway.
I would start by testing the two method of two-fan tachometer reading: the interrupt method, and the counting loop iterations method.
Both have their upsides and their downsides.  Also recall that to get say 8-bit precision at the 25 kHz PWM, we need the PWM timer base to be at least 6.4 MHz; or say 4 MHz, for duty cycle control between 48 (30%) and 159 (100%-1).  Thus, the AVR MCU clock will have to be 4 MHz or higher in any case.
(The simulations I've already done to find out the electrical requirements and suitable components could be counted as the first "testing" I did.)
As the controller wants to provide an initial start pulse to get the fan moving, I must then consider how the overarching logic of controlling the target tachometer reading, towards which the fan PWM will be adjusted.  In this case, it is straightforward: it is done after each tachometer sampling, as an outer main loop, iterating at least once every 0.3 seconds, but possibly as often as once every 0.01 seconds.  So, this outer loop does need some kind of way to reliably measure time intervals under half a second, so it can tell when PWM adjusting needs to be done or not.  It does not need to be precise, however, so even knowing the inner loop iteration count or similar will suffice; also so would an 8-bit one-second timer (with 4ms resolution), as long as it is under the outer main loop control and not related to PWM.
Next, I would separately implement the PWM control, and test that.  Note that some AVRs have only one 16-bit timer/counter (with two PWM outputs at different duty cycles but the same frequency), and no cycle counter, so Arduino-style millis() or micros() functionality requires a separate timer/counter, or interaction with the PWM clock.  I would rather avoid having an interrupt fire 25000 times a second on a small AVR, though.
Next, I would combine the above, and check the interactions.  At every stage, I make sure there are no bugs (so no "I'll fix that later"!), and no compiler warnings.  This minimizes the regions where bugs may lurk at, and makes it easier and faster to handle the interactions.
Along the way, as I "test" things, I record my assumptions and findings as documentation.  This means that when I get to this point, I should only need to collect the documentation, write some glue text (introduction, licensing, etc.), and the project is done.
I'd probably also create a variant of the firmware that instead of the FAN-FAULT signal, uses a potentiometer to control the fan RPMs (with each fan having their minimum and maximum RPMs hardcoded in the firmware).  That would be useful for others, too, which is a large part of why I'm considering writing the above code.
I have absolutely zero idea how long doing the above should take.  I know I should know, as I definitely have the experience, but I just do not: it is one of my very significant faults.  At least I'm now old enough to report my progress correctly (and only because I learned to write out my plan like this above, and describe how much of each stage has been completed, and what unexpected stuff I discovered); I used to fail a lot at that, too.
While this may or may not help, the above is what I meant by "testing".  It is as much exploration, as it is verification; and I use it not just to test the code, but my own understanding of the problem and the behaviour and limitations of the solution model I'm proposing.
Online DiTBho
« Reply #37 on: July 14, 2023, 09:42:20 am »
the theory, the practice ... the problem is that in the QA department there was a beautiful Swedish girl with green eyes and long legs ... how can you not invite her to lunch? maybe outside the base so as not to point out that you have the yellow card (from the development department) and she has the red one (from the QA department), and therefore you shouldn't even say hello to her?
We are human after all...   :-//
Offline brucehoult
« Reply #38 on: July 14, 2023, 09:54:46 am »
Well, yes. The one in Redmond in 1998 was blonde. And intelligent. First date, she took a taxi from work to the Bellevue TGIFs (her suggestion), I drove there. Drove her home on the completely opposite side of Redmond, after parking up beside a lake for an hour or two.  Better not to start the rumour mill in any company prematurely, or at all.
Funny story: in Moscow I *twice* was in some random metro wagon late at night or in the weekend when my (married w/ children) department head entered the same wagon together with a programmer from another department [1]. When my stop came I casually said "Hi Sveta, Sergey" as I went out the door.
[1] the woman who starts off nearest to me in this
Online SiliconWizard
« Reply #39 on: July 14, 2023, 09:19:41 pm »
Yes, well probably more than just useful.
Generally speaking, what it comes down to is, if you don't know what you are doing while engineering something, things are not going to end well.
Online dietert1
  • Country: br
    • CADT Homepage
« Reply #40 on: July 14, 2023, 09:50:32 pm »
Also another example for redundancy: Describing the same thing first in natural language, then in a programming language. The 400 lines in one day i mentioned above are possible only after having a problem absolutely clear. Just coding and debugging.
Regards, Dieter
« Last Edit: July 15, 2023, 03:37:10 pm by dietert1 »
Offline RoGeorgeTopic starter
« Reply #41 on: July 15, 2023, 10:12:24 am »
After the first 4 chapters (Concepts) from the book I've found couple of days ago, https://zjnu2017.github.io/OOAD/reading/Object.Oriented.Analysis.and.Design.with.Applications.3rd.Edition.by.Booch.pdf turns out I don't know all the basic mechanisms already available in OOP languages.
For example, at page 144 of 717, one of the bullet points reads
The three kinds of relationships include association, inheritance, and aggregation.
I knew only about inheritance, not about the other two.  ;D
Will try again, this time starting from square one:
Any book recommendation to learn the basics about objects, please?
Would prefer a book where the teaching style is from bottom to top, to start from some examples and counter-examples, then to deduce the abstractions, so to see how the ideas came into existence, then some exercises.  I don't like the style where some generic/abstract idea is stated first (apparently pulled out of thin air), then justified later by telling how to apply it to whatever situation the abstraction was meant for in the first place.
Preferred language for exercises would be Python.  Ideally would be a book with only the OOP basics, and language agnostic, if such a language agnostic OO book exists (doubting about existence because I've read some languages have more OO features than others, so I guess the OO basics might be different between different languages).
« Last Edit: July 15, 2023, 10:24:57 am by RoGeorge »
Offline brucehoult
« Reply #42 on: July 15, 2023, 10:23:36 am »
Note that OOD is not the same thing as OOP.
Not to mention that, yes, there are many interpretations of OOP.
- inheritance or prototypes?
- multiple-inheritance, or single-inheritance plus interfaces/mixins/traits?
- inheritance of implementation or only inheritance of interface?
- internal methods or external?
- selection of virtual function based on the dynamic type of only the first argument (and maybe static types of the others), or based on the dynamic types of all arguments?
- mutable state in objects, or immutable? YES! You can do OOP perfectly well in pure functional languages, returning a new object rather than modifying the original one.
« Reply #43 on: July 15, 2023, 11:04:11 am »
I've noticed in those 4 chapter I've just read that, indeed, apparently generic words I might have used interchangeably, might in fact have a very specialized meaning in programming.
At this moment, to me inheritance means a child class will have (by default) the same attributes and methodes as the parent class has.  As for the rest of the questions, I can only assume what they are about, but I don't know the exact meaning.
Just to be sure I'm not accidentally misusing dedicated terms, asking in plain English:
- would like to write programs based on objects, as apposed to programs based on procedures/functions only.
- what book to start with?
Assume zero knowledge about programming with objects.  I only program occasionally, for my hobby projects, procedural programming style + common sense, just as a singer that sings by the ear and never went to a proper school to learn how to read the musical notes (by profession, electronist specialized in hardware/digital electronics, not software).
The final goal is to write with ease, and faster, the software part for my hobby projects.
« Last Edit: July 15, 2023, 11:11:09 am by RoGeorge »
« Reply #44 on: July 15, 2023, 02:23:24 pm »
Searched all morning browsing books that teach programing with objects.  Browsed 5-10 top titles that come up from a Google search.  Very disappointed.  Talking about the form, can't judge the content myself.
Most authors can't write concise sentences.  "Basically", "obvious", "actually", "clearly" and alike emphasizing or opinionated words, comics rather than diagrams, long idioms instead of a single word, etc.
George Carlin - Flying [Live from NYC '92]
Eventually, the only decent book I could find was "The C++ Programming Language Fourth Edition" of Bjarne Stroustrup.  http://chenweixiang.github.io/docs/The_C++_Programming_Language_4th_Edition_Bjarne_Stroustrup.pdf
It has 1300+ pages, which is a bummer, but at least it's first hand info coming from the C++ author.
Never learned C++ before, because when I first encountered C++ I didn't like the "::" operator.  It was a childish reason, I know.  I'll commit to this book for now, better late than never.
Though, before proceeding, I want to ask if it would be OK to learn from this 4th edition, or from the 1st edition (which I assume might be shorter and easier)?
« Last Edit: July 15, 2023, 02:49:30 pm by RoGeorge »
The following users thanked this post: nctnico
« Reply #45 on: July 15, 2023, 04:10:12 pm »
You have no idea how difficult it is to be precise, concise, and easily understood at the same time.  :'(
If you like Python 3, then extending and combining existing Qt UI widgets is one sure way to explore many OO concepts in practice.
The signal and slot mechanism should probably be understood first, though; it can throw people off.  It is Qt's way of implementing inter-object communication, or abstracting events and event handlers, so that the connections between the two can be controlled at run time.
Each object has a set of signals it can emit, for example clicked or textChanged.  Each signal (from a specific object) can be connect()ed to one or more slots; each slot being just a Python callable (method, function, etc.).  When the object emits (due to user interaction; or your code emit()s) a signal, the Qt runtime (verifies and) remembers the parameters.  Later on, when that code completes, and execution is returned back to Qt runtime, it causes each of the connected slots/callables to be called in turn, passing the information from one Qt object to another.
Just never, ever use the Designer to generate Python code for your UI designs.  Instead, save your UIs as XML .ui files, and load them at runtime.
The generated Python UI code is horrible to maintain, whereas properly written .ui-loading code is nice.  Also, if you use a specific pattern for naming your slots (event handlers), it is trivial to auto-connect them to the .ui elements' signals.
Online tggzzz
« Reply #46 on: July 15, 2023, 08:40:27 pm »
Simple points about OOP which are often glossed over...
Inheritance: is-a relationship.
Composition: has-a relationship.
Inheritance is two things. Externally it is extending the interface that defines what a component can do; the subclass is more specialised than the superclass. Internally it is a code sharing mechanism.
Inheritance can be often overused at the application level; usually composition is preferable. Example: a Money class could be considered as a specialisation of a FloatingPoint class, but it is preferable that instances of Money are composed of a FloatingPoint object. That prevents you from even considering that you could take the square root of money:)
Having said that, inheritance is invaluable when your client says "that's great, but in addition I also need other things just like that but which also does X"
EDIT: understand the Liskov Substitution Principle. Absolutely key concept.
« Last Edit: July 16, 2023, 09:31:53 am by tggzzz »
Offline cfbsoftware
    • Astrobe: Oberon IDE for Cortex-M and FPGA Development
« Reply #47 on: July 15, 2023, 11:16:12 pm »
I recommend Object-Oriented Programming in Oberon-2 by Hanspeter Mössenböck, published by Springer-Verlag.
The goal of this book is to convey the fundamentals of OOP, namely classes, inheritance and dynamic binding. The emphasis is on the concepts rather than on the specifics of a particular programming language. In addition, readers should learn to determine for which problems OOP is most suitable, and which problems would be better solved with conventional means.
This book is out of print and is made available as PDF with the friendly permission of Springer‐Verlag:
https://ssw.jku.at/Research/Books/Oberon2.pdf
Chris Burrows
CFB Software
https://www.astrobe.com
Offline nctnico
« Reply #48 on: July 16, 2023, 12:41:10 am »
Did an inventory of my unfinished tinkering projects last weekend, and most are stalled without firmware/software.
The goal is to write fast enough and good enough code, so to get functional projects, not to become a programmer able to work in a team.  Environment is Linux and FOSS tools.
I've wrote small programs occasionally, starting decades ago.  Fortran was probably the first I read a book about in the high school, but didn't practice, later practiced some Basic on home computers, then at university we did some Turbo Pascal, then read K&R which later applied to programming microcontrollers, with some other languages and algorithm books/classes in between (i.e. the Knuth's 'Algorithms' books, about half of the 4-5 volumes).  Latest language I've dealt with is Python.  I know the basics of OOP, but not able to take advantage of it.  I'm stuck with the procedural writing style.  Never tried functional programming or other fancier stuff.
Use an MCU that supports Micropython and don't care about the costs especially if you want to get a project finished quickly. Spare time is valuable! I have been venturing into implementing the high level parts of MCU firmware using scripted languages like Lua and Micropython. I'm currently working on a project for a customer that uses Micropython to implement the logic. It is a whole lot less tedious compared to using C.
« Last Edit: July 16, 2023, 12:48:54 am by nctnico »
Online DiTBho
« Reply #49 on: July 16, 2023, 05:32:18 pm »
To be honest, I too find this attitude very annoying, and it bothers me that we are here to give free advice just as some people give free advice, and he doesn't even put "thanks" to posts because he wants "books" or "simple answers" written in precise, concise, and easily understood at the same time sentences and what else? also a piece of cake? of which, worse still, then he allows himself to read what is convenient for him, ignoring the same advice he is asking for, and, worse still, by labeling what he does not understand as "cult".
