Author Topic: Noob: C port  (Read 3936 times)
Offline PerranOakTopic starter
Noob: C port
« on: October 01, 2019, 04:06:34 pm »
In my PIC C programming course I've come across a command that is not explained:
static bit button @ (unsigned) &PORTA*8+1;
What I think I know is:
the code is to assign the name "button" to RA1, static means that the value of "button" is to be retained between functions, unsigned means that the value of "button" has no mathematical sign and PORTA is port A(!)
I don't understand what these are doing:
bit, @, & (though I believe this is "logical .AND."), *8, 1 (I guess this refers to bit 1 of PORTA).
I'm not necessarily looking for descriptions (though all help is welcome) but where do I look to understand these things? I have Kernighan & Ritchie but this is not really a reference.
Cheers.
You can release yourself but the only way to go is down!
RJD
Offline ledtester
Re: Noob: C port
« Reply #1 on: October 01, 2019, 04:39:28 pm »
The @-sign is a compiler extension which allows you to specify the address of a global variable:
https://stackoverflow.com/questions/15955856/sign-in-c-variable-declaration
In this case it looks like a bit-variable is being defined at a specific bit-address - hence the PORTA*8+1 expression.
Offline sokoloff
Re: Noob: C port
« Reply #2 on: October 01, 2019, 04:45:38 pm »
& is "address of"
(&& is "logical AND")
Read that as roughly:
Take the address of PORTA (&PORTA), multiply by 8 (*8), add 1 (+1) to get to the bit you want.
« Last Edit: October 01, 2019, 04:51:30 pm by sokoloff »
Offline SiliconWizard
Re: Noob: C port
« Reply #3 on: October 01, 2019, 06:06:58 pm »
Additionally, '&' has two forms, unary and binary. Reminds me of another thread...
Re: Noob: C port
« Reply #4 on: October 03, 2019, 01:08:57 pm »
Cheers all.
So, why is it "*8"? Does each bit have an address?  :-//
RJD
Offline ledtester
Re: Noob: C port
« Reply #5 on: October 03, 2019, 01:40:57 pm »
Yes - it's a bit address not a byte address. The first byte (byte address 0) contains bit addresses 0 through 7, the second byte contains bit addresses 8 through 15, etc.
Re: Noob: C port
« Reply #6 on: October 03, 2019, 01:54:05 pm »
Oh no! Another thing!
Thank you.
RJD
Offline Ian.M
Re: Noob: C port
« Reply #7 on: October 03, 2019, 02:08:15 pm »
Its hard to be specific when you are discussing non-standard extensions to a C compiler and the O.P. hasn't specified *which* compiler!  However that looks like HiTech PIC C or older XC8 syntax, so I'm going to assume that's whats being used.  If you are using something else, ignore this and post the actual compiler make and version you are using.
No, a HiTech PIC C or XC8 variable of bit type does *NOT* have an address in the C sense of address - you cant make a pointer to a bit or have an array of them.  However the compiler needs some way of locating which bit in which byte to use when defining them at an absolute address so when applied to a bit, the @ addressing attribute takes a parameter of 8 times the byte address + the bit number within the byte.  Its only usable for @ - *NOTHING* else uses bit 'addresses' and they must always evaluate to a compile-time constant expression.
N.B. the bit type is very non-portable.  The modern way of declaring that input bit under later HiTech C versions or XC8 would be:
#define BUTTON PORTAbits.RA1which relies on you having #included the compiler's standard headers. BUTTON is in caps because that's the convention for a name that's a #defined alias.  You'd need to make all other instances of it the same case.  If you need single bit flag variables, you'd do best to pack them as bitfields in a struct.
XC8 CCI syntax has depreciated bit and @, and that's the default (for C99 compatibility) from XC8 2.0 onwards.  You can however enable backwards compatibility, and still use it.
« Last Edit: October 03, 2019, 02:13:16 pm by Ian.M »
Re: Noob: C port
« Reply #8 on: October 03, 2019, 02:39:04 pm »
Cheers for that.
You were right, it is XC8 and the version used by my course manual is v1.35 though I have a later version.
Is "bit" a variable type like "int" and "long"? You don't see it in those lists.
PS
I still don't get why it's "*8".
« Last Edit: October 03, 2019, 02:45:55 pm by PerranOak »
RJD
Online Siwastaja
Re: Noob: C port
« Reply #9 on: October 03, 2019, 03:23:39 pm »
No, and not even close.
You need to understand that you are not writing C, but a C-like custom language. It's more than extensions or attributes; it has fundamental differences in basics.
You need to refer to the documentation of the language.
Re: Noob: C port
« Reply #10 on: October 03, 2019, 03:47:58 pm »
Exactly.
Offline ledtester
Re: Noob: C port
« Reply #11 on: October 03, 2019, 04:23:02 pm »
It's a single bit - i.e. either a 0 or 1.
It's intended to be used like this:
static bit LCD_RS @ ((unsigned)&PORTB*8+1); // RB1 -> LCD_RS
LCD_RS =1;  // Set RB1 to 1
The compiler will generate code to set the RB1 bit to 1 (without affecting any of the other bits in the RB register.)
However, it is not standard C and there are alternatives which are compatible with the C standard:
https://www.microchip.com/forums/m1088415.aspx
Have a look at the data memory map of the PIC16F684:
847564-0
Each file address contains a byte. The file address of PORTA is 0x05, so the 0-th bit of PORTA is the 5*8+0 = 40-th bit of the data file. The 1st bit of PORTA is the 41-st bit of the file, etc.
To find the bit-offset you have to multiply the byte-address by 8 and add which bit you want to address.
The following users thanked this post: PerranOak
Re: Noob: C port
« Reply #12 on: October 04, 2019, 09:53:33 am »
Thank you ledtester that is very clear. So the effect of "bit" is to treat the memory addresses not as bytes but as bits.
So, if the address you want is 5 bytes in, then (with 8-bits per byte) it's 5*8=40 bits in. Got it!
Of course, my problem is that (since I'm at the beginning) I don't know what is standard C and what is uC specific.
Siwastaja: the "documentation of the language"; where would I find this? I have C books but these are no good since, as you pointed out, this is not C and I've looked in the XC8 manual but couldn't really get it - not like I do now thanks to ledtester.
RJD
Offline sokoloff
Re: Noob: C port
« Reply #13 on: October 04, 2019, 01:43:30 pm »
I think K&R you cited is a great reference. It’s how I learned the formal part of C. Then, lots of coding teaches you the practical application while you occasionally need the reference material.
As far as I can see, most of what you’re going to see is bog standard C. The @ bit addressing is compiler-specific.
Offline Ian.M
Re: Noob: C port
« Reply #14 on: October 04, 2019, 05:54:19 pm »
+1 for K&R, 2nd ed. but that only covers C up to ANSI C89 standard.   Prior to the release of XC8 v2.0, that was fine for 8 bit PICs as the XC8 v1.x compiler was a C89 one with *some* C99 extensions.    However XC8 v2.0 upwards defaults to full ISO C99 mode.
You'll probably also want a copy of the applicable C standards.  The ANSI C89/ISO C90, and ISO C99 standards are payware but as they have been superceeded by ISO C11 and C18, you can probably find free eBook or PDF copies floating around.  The drafts of the standards are freely available and unless you are a C language lawyer are plenty good enough for everyday use.
See http://port70.net/~nsz/c/ for indexed HTML versions of the drafts.
Re: Noob: C port
« Reply #15 on: October 04, 2019, 06:30:59 pm »
Yes.
My additional tip: don't learn a language by fiddling with MCUs first. That will yield to improper learning, wrong notions, bad style, quirks, incomplete knowledge, etc.
It's like willing to learn architecture by playing with Lego. ;D
