Yes yes. And suddenly everyone is becoming a specialized copyright lawyer.
If you read everything I wrote, you'll see that I was being a bit more nuanced, then, than the part you just quoted.One doesn’t have to be a lawyer, to know and recognize often repeated misconceptions. You know, I am neither an astrophysicist nor a geologist, but I could say that claims about Earth being flat are wrong.- If you, as an author, share some work on a platform such as github which targets open source software, and you want to hold your copyright on it, and you leave it with no mention an no means to identify or contact you, you're an idiot. It's like leaving your front door open with a big sign "come in", and expect nothing bad will happen to your house.Where you host your code doesn’t void your rights. Neither does “being idiot”, even assuming “being idiot” is a concept recognized by your local law. You don’t need to offer signing any particular contract to make your work protected, even if you show your work to others. A copyrightable work is protected just because it exists. No further conditions.
Publication on GitHub might imply anyone can see the code without obtaining a license, but the question is not about seeing it. It’s about creation of derived works.Open source and copyrights are for a large part incompatible. That's likely to trigger huge debates, but all in all, the whole spirit of open source that I've gathered and understood goes against the idea of copyright. So as related to the above, sharing something copyrighted on some open-source platform is sort of mind-boggling. I'm sure many will find no issue with that though. Who cares about consistency, right?Yes, they are very incompatible. Yet the law still holds, even if someone doesn’t like it.As I explicitely mentioned, the person publishing some work on github may not be the author nor have any explicit authorization of the author to share it (unless it's explicitely open-source licensed, in which case the license SHOULD come with the work.) In that case, that basically means the person behind the github (or similar) account stole the work. Also as I said, it's unfortunately extremely frequent on those websites. There's a lot of stolen work with no means of knowing who ever did it.It may be, which possibility has included in my response, but that doesn’t address OP’s problem in any way. They still need to obtain permission from the copyright holder. Also note that the publisher may be the author, but not the copyright holder.- Which, as I also mentioned, makes using any such project, unless it's one of the well known open-source projects with no ambiguity, basically impossible for any commercial application, because you just can't know who owns it. There is a significant amount of projects in the same case as the OP's, but even when there's an explicit license, it's impossible to know whether it's legit or just stolen copyrighted work with an added license that the true author never intended to add or even knows about. A can of worms. So of course github doesn't want to be held responsible. It's almost intractable.You can never be sure, no matter where you obtain your dependencies at. What matters is how well you can protect yourself in the case of a fuckup. If you can prove that you were yourself a victim of a scam, it is a whole different story than ignoring copyright altogether. Which is why I mentioned finding someone, whose presence in the chain covers OP’s ass up.And with all that said, if again this is for pure personal use, wow. Are some of you serious for fretting? If you're really in doubt, just don't share your derived work until you know for sure where the original one was from and what kind of license it has. Keep it to yourself. Nobody gets hurt.Unless your jurisdiction has provisions in criminal law against using unauthorized software. Of course someone may be in a position where chances of discovery are very low, but do you think OP would ask how to do that legally, if that was their goal?
wow, some folks must spend all their time thinking about this stufff. wow.
wow, some folks must spend all their time thinking about this stufff. wow.You have some problem? Or perhaps have anything of value to say?
Discussion fora exist for, surprisingly, discussion. If you find weird that people use them for the intended purpose or try to help others, you are free to not participate. Similarly, if you find the act of thinking something worth of ridicule, you may be in a wrong place.
If the device has closed source code and some entity suspects copyright infringements is there some legal mechanism that forces the designer to provide source code for scrutiny?
Allow me to be Ralph Wiggum for a moment...
So you build and release a product containing code to carry out its intended function.
Regardless being able to protect the code from being read within the device, even if you could it would be a binary blob, at what point do you have to provide to others source code?
I ask because I have always found it strange on the insistence of code source stipulating that copyright notices in comments must remain and should not be used without prior consent etc
Is this simply a case of not being a thief and being honest about it and if you were how easy would it be to be found out?
The US Government wrote a demand for source code into its contracts.. Way back in the 90s. with DFARS.. Because they had been burned too many times.. I saw some of these source code gold CDs.
Thats where open source originated from.
Hopefully I am wrong as to these forces I describe as against open software. If that is the case, I wouldn't mind that one bit. Crossing my fingers..
