Author Topic: Rust is political?  (Read 16475 times)
Online magic
Re: Rust is political?
« Reply #50 on: May 24, 2022, 09:28:11 am »
C++ templates don't require code duplication. Even if the compiler generates multiple functions, if they have identical machine code the linker will combine them into one. If you write the C++ templates as type-safe wrappers around the same void pointers you'd use in C then the machine code will all be the same.
Even if true (I don't know) it appears to be easily defeated by the compiler inserting different NOPs for alignment or whatever stupid reason:
0000000000001351 <_Z5qsortIiEvPT_mPFiPKS0_S3_Em>:
    1351:       55                      push   %rbp
    1352:       48 89 e5                mov    %rsp,%rbp
    1355:       48 83 ec 20             sub    $0x20,%rsp
    1359:       48 89 7d f8             mov    %rdi,-0x8(%rbp)
    135d:       48 89 75 f0             mov    %rsi,-0x10(%rbp)
    1361:       48 89 55 e8             mov    %rdx,-0x18(%rbp)
    1365:       48 89 4d e0             mov    %rcx,-0x20(%rbp)
    1369:       48 8b 4d e8             mov    -0x18(%rbp),%rcx
    136d:       48 8b 55 e0             mov    -0x20(%rbp),%rdx
    1371:       48 8b 75 f0             mov    -0x10(%rbp),%rsi
    1375:       48 8b 45 f8             mov    -0x8(%rbp),%rax
    1379:       48 89 c7                mov    %rax,%rdi
    137c:       e8 cf fc ff ff          call   1050 <qsort@plt>
    1381:       90                      nop
    1382:       c9                      leave
    1383:       c3                      ret
-- snip--
00000000000013c8 <_Z5qsortIfEvPT_mPFiPKS0_S3_Em>:
    13c8:       55                      push   %rbp
    13c9:       48 89 e5                mov    %rsp,%rbp
    13cc:       48 83 ec 20             sub    $0x20,%rsp
    13d0:       48 89 7d f8             mov    %rdi,-0x8(%rbp)
    13d4:       48 89 75 f0             mov    %rsi,-0x10(%rbp)
    13d8:       48 89 55 e8             mov    %rdx,-0x18(%rbp)
    13dc:       48 89 4d e0             mov    %rcx,-0x20(%rbp)
    13e0:       48 8b 4d e8             mov    -0x18(%rbp),%rcx
    13e4:       48 8b 55 e0             mov    -0x20(%rbp),%rdx
    13e8:       48 8b 75 f0             mov    -0x10(%rbp),%rsi
    13ec:       48 8b 45 f8             mov    -0x8(%rbp),%rax
    13f0:       48 89 c7                mov    %rax,%rdi
    13f3:       e8 58 fc ff ff          call   1050 <qsort@plt>
    13f8:       90                      nop
    13f9:       c9                      leave
    13fa:       c3                      ret
    13fb:       0f 1f 44 00 00          nopl   0x0(%rax,%rax,1)
And there is obvious objection that you are relying on optimizations that aren't in any way standardized nor guaranteed and will depend on choice of toolchain, optimization/debug level and phase of the moon.
Besides, I don't like wrappers. Instead of all this crap
template <class T>
void qsort(T *ptr, size_t n, int (*cmp)(const T*, const T*), size_t sz = sizeof(T)) {
        std::qsort((void*) ptr, n, sz, (int(*)(const void*, const void*)) cmp);
I want to write
generic <class T>
        // honestly type-checked implementation of qsort goes here
        // any use of sizeof(T) or T[] transparently employs sz
        // sz can't be overriden manually at the call site
        // exactly one instance of the function generated in this translation unit and none elsewhere
Bonus if somebody can figure out how to do type-safe intrusive containers (which are all over the place in Linux, for example).
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #51 on: May 24, 2022, 10:30:31 am »
Depending on the ISA, NOPs are placed to flush the pipeline before taking a long branch. Obviously that, if the non-templated code does not have them, indeed it is an implementation problem.
Offline brucehoult
« Reply #52 on: May 24, 2022, 11:17:39 am »
I don't know why you got different code, but then I also don't know why you used -O0, which should be banned not the default.
With -O1 I got exactly the same code.
https://godbolt.org/z/da66KT8dx
Also, with such a simple type-safe wrapper template I would normally not prevent the inlining of it.
Online magic
« Reply #53 on: May 24, 2022, 02:30:38 pm »
I can only guess it was a matter of alignment, which could depend on what stuff precedes and succeeds each of the instantiations. Also, one of them was at the end of a section, so maybe it matters somehow. I posted unoptimized code because otherwise everything got inlined and I didn't feel like writing a longer template that wouldn't.
Anyway, it nicely illustrates the point that you can't be 100% sure what you get because it's an optimization. A more reliable (and efficient) way is to have a language mechanism which avoids generating duplicate code in the first place.
ML had parametric polymorphism in the '70s, Java since the '90s (generic containers and sorting included), Rust designers still haven't heard of it in the 2010s ::)
BTW, speaking of Rust, is it even possible to write a similar wrapper for stdlib's qsort by any means whatsoever in that language?
In C++ I had to resort to function templates and default arguments, not sure if Rust has those...
Online SiliconWizardTopic starter
« Reply #54 on: May 24, 2022, 06:12:02 pm »
Why would you want to write a wrapper for the C lib qsort() if you're gonna write a generic sort function in another language?
Sorting is not rocket science.
Online magic
« Reply #55 on: May 25, 2022, 07:47:16 am »
It doesn't matter. Regardless of implementation language, a generic array sort needs to know element size. So do many containers and other things.
Question is, can it be provided by the compiler automatically each time such a generic function is called.
C++ can do it, with a footgun included (one comma too much and it breaks in most bizarre ways).
Java sidesteps the problem by not having nested objects - containers only hold pointers to heap items.
