Yes, there is, but this is not what C specification says. And compilers implement the specification. So, your complaint is to the standards people, not the compiler writers.
I suppose you're right. I guess that's what happens when you try to mould a standard around a lot of existing and varied implementation.
Don't get me wrong, I'm not criticising the C language as a whole. If I were upset about this stuff, I wouldn't be using it. I know it's the programmer's job to avoid triggering undefined behaviour (e.g. check your divisor values first, your array bounds, that pointers are valid, etc.). I just wish in some areas (like this) there was more predictability and consistency. Speaking of which, further to my example above, I just remembered one more thing about this scenario: the routine for 32-bit
division (as opposed to modulus) doesn't even have the same issue! It uses a different algorithm and is perfectly fine with a divisor of zero! Even more inconsistency.
I think the whole thing about "undefined behaviour" meaning any random event could occur - up to and including your computer exploding, your hair turning purple, or being haunted by evil spirits - needs to have some kind, pragmatic consideration applied. Not for compiler or library writers to just shrug their shoulders and say "we're okay with letting random shit happen even though some of it is under our control".
Edit: That last sentence also gave rise to this thought: as I understand it, a lot of C undefined behaviour is due to having to allow for the idiosyncrasies of varied hardware. The circumstances that lead to undefined behaviour may be
uncontrollable due to the nature of the platform code is running on. But when the behaviour is entirely within an entity's control (e.g. add a line of code to a library routine to perform a zero check), I think that is when pretence of "we can't help it" needs to go away.
